Question about Dell F3534 Touchpad
Inspiron 1525 keyboard and touchpad locked at bootup. Unable to enter user password to load Vista. HELP!
  • 20 Answers
My friend has one of these and I really Dont know why but VIsta is always the Operating system that causes this.
Try this: at the log in screen press the F9 key see if it unlocks. unfortunately i doubt that that worked but hey it was a try
Now
try this: at the bottom of your laptop there should be a lever that releases the battery (remove the battery) leave it out and use your power cord only to boot the system. that usually works for me.
Hope that fixes your problem. Thanks for posting on Fixya.com
Posted on Dec 15, 2008
Dell touch pad not working
The touchpad on a Dell laptop is usually located under the keyboard. Moving the finger on the pad moves the pointer on the screen. The buttons near the pad act as a right and left click. Windows includes a method to troubleshoot the touchpad. In addition, if the touchpad is still giving you issues, Dell recommends draining the "flea" power the standby power from the computer to restart it. Both methods are simple and only take a few minutes.
Open the control panel from the Start menu. Click on "Mouse." This will open a window with several tabs. On the first tab, click the touchpad to open a new window to change the settings for your touchpad. You can customize the settings to how you want your touchpad to work. If this does not solve your issue, proceed to the next step. Click the Hardware tab on the screen that pops up. Select the Dell Touchpad and click "Troubleshoot." A new window will open with the Windows Help and Support Center to bring you through methods for troubleshooting the touchpad. Follow the methods described until your touchpad is working properly. Drain flea power Shut down the laptop and disconnect all external devices, such as a thumb drive, headphones and the AC adapter power cable from the system. Take the battery out of the laptop. Hold down the power button for at least 5 seconds without releasing it. Return the battery back to the laptop. Power the system on. If your touchpad still is not working properly, call Dell for customer support.
http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?c=us&cs=19&dl=false&l=en&s=dhs&docid=59EB83ED2E4B1243E040AE0AB7E1468E&doclang=en b> Dell Inspiron 1525 Touchpad That Is Not Working
Turn your Inspiron 1525 off and remove any power cables that are connected to the device. Close the computer, turn it over and slide the battery lock button down to release the rectangular battery from its compartment on the underside of the computer. Turn your laptop right-side up and open the computer so the monitor is facing you. Insert the tip of your flat-head screwdriver in the seam between the plastic keyboard guard and the side of the computer. The keyboard guard is located just above the keyboard. Pry up on the guard until it pops out of place. Be sure to do this gently, as you do not want to damage the guard. Remove the guard from the computer and set it aside. The two keyboard screws will now be visible underneath where the guard used to sit. Use your Phillips screwdriver to remove the two keyboard screws and use the tips of your fingers to lift the keyboard up from the top. Place the keyboard facedown over the touchpad and locate the thick connector ribbon that runs from the motherboard inside the computer to the back of the keyboard. Use your fingers to gently unplug the ribbon from the back of the keyboard and set it aside. Insert the tip of your screwdriver in the seam at the bottom of where the keyboard used to rest and gently pry it up. This will release the top plastic frame from the Inspiron, revealing all of the broken touchpad. Use your fingers to disconnect the thick ribbon from the side of the damaged touchpad and slide the touchpad out of the Inspiron. Slide the new Touchpad (available from your Dell retailer or online) in its place, fit the top frame in place and reassemble the computer in the reverse order you took it apart in.
http://www.insidemylaptop.com/replace-damaged-keyboard-dell-inspiron-1525-laptop/ Replace keyboard in dell inspiron
Feb 01, 2013 | Dell Inspiron 15 (N5050)
DELL INSPIRON 1525 HELP
It should be a simple fix. Start your laptop and pay attention to the screen. Press the F12 key (or F11) to enter "SETUP" then find the NUMLOC command and make sure that its DISABLED or OFF. This will turn this option off andyou will only be able to use the number's keys on the top of the keyboard. Be careful when entering SETUP. You don't want to change anything you don't have to.
Dec 26, 2011 | Dell Inspiron 1525 Notebook
Dell Inspiron E1405 Keyboard and touchpad stop responding when bootup gets to Windows password screen. Any ideas as to why? Thanks in advance.
could be a problem with drivers. Try to start windows in safemode. To start in safemode keep pressing F8 imediattly after the laptops starts and will show up a screen, choose safe mode. If in safemode works use system resotre and restore to an earlier time when worked.
Jul 18, 2009 | Dell Laptop Keyboard for Inspiron 500M
After enter password for windows, a black screen comes up and all you can see is the mouse
Are you using Windows 7, there is a separate hidden account called administrator. The easiest way to access it is to go into safe mode. You do this by tapping F8 just after the self test, and before windows starts to load. Once on the start up menu choose safe mode. Click on the administrator account. From there you can change any passwords in the control panel under user accounts. You do not have to know any of the passwords to change them, or you can use utility to delete the lost password. Download Windows Password Unlocker
Jul 15, 2009 | Dell Keyboard for Inspiron 1420, 1520,...
Locked out by password on dell inspirion 1525 how do i re install vista
If you have the vista disk, then just put it into the drive, and reboot. You may need to change bios boot order, which can be done by pressing f8 as the computer starts up, and selecting the dvd drive. If this does not work, then please refer to your user manual for the correct key to press. If you can boot, then the installation is self explanatory. Give it you country and keyboard layout, and then when the screen shows "install vista" button, undeneath it is a repair vista button link. Click this, and select your existing installation. From there it may ask you about "system restore" press cancel, and then hopefully, it will restore.  Hope this helps.
May 24, 2009 | Dell Inspiron 1525 Laptop Jet Black
My dell inspiron 1525 is not allowing me to log in!
Restart the computer and get in to safe mode and login and do system restore. It will fix it.
Any issues, email me: apremkuma@gmail.com
Thanks, PREM
Mar 31, 2009 | Dell Inspiron 1525 (dndppa1_3) Intel Core...
Scrolling
did it always have vista
check settings for mouse in control panel
also update driver in device manager
Feb 01, 2009 | Dell F3534 Touchpad
Inspiron 1525 keyboard/touchpad locked.
Press ctrl alt del together then try to enter your password. If it doesn't work. restart your computer by holding down the power button for 10 seconds or until the computer turns off. Restart and tap F8 repeatedly as soon as the light comes on. Choose 'Last known good configuration' using your keyboard. Then press enter. Try if you can login now.
Dec 15, 2008 | Dell F3534 Touchpad
Touchpad/mouse problem
Same thing here, I can not find out how to diable the touch paid. I spent an hour chatting on-line with Dell Tech support and they did nothing to help!! I am starting to think it can not be done on this machine. Please someone tell use how to do this?
Jul 10, 2008 | Dell F3534 Touchpad
Computers & Internet Logo
421 people viewed this question
Alun Cox
mukhtar21 shaikh
mukhtar21 shaikh
