Highly unlikely that it can be repaired, salt water caused corrosion and
will short out electronic components when the battery is connected. I suggest you put your money towards a new camera.
The lens has probably got something in the retraction mechanism that is stopping it retracting. This can be something as simple as sand or grit or as a result of a drop or knock. In most cases the camera will need to be stripped apart to remove the lens assy before it can be repaired. This is best left to a professional camera repair shop.
The drop likely damaged the lens tube (housing) or jarred the zoom mechanism off of its track. Either condition causes the camera to shut down to prevent further damage. There is no safe DIY fix, but the camera can be professionally repaired. Contact Sony through their web site or visit a local camera shop (not the department store) and get a repair estimate -- you will need to decide if the camera is worth the cost of the repair.
IF YOUR PICTURES ARE BLURRY IN THE LCD, THEN YOU MOST LIKELY DO HAVE A PROBLEM. WAS THIS CAMERA BOUGHT ON AN AUCTION OR SECOND HAND, THAT YOU ARE NOT SURE IF IT WAS DROPPED? IF IT WAS DROPPED, IT MAYBE REPAIRABLE, BUT REPAIRS ARE USUALLY EXPENSIVE AND SOMETMES IT'S BETTER TO INVEST IN A NEWER CAMERA. SORRY, BUT I DON'T WANT YOU SHOCKED BY REPAIR ESTIMATES. FROM WHAT I HAVE BEEN ABLE TO FIND OUT, THE REPAIR COST WILL EXCEED THE COST OF THE CAMERA. SORRY. SO, CHECK THE LCD AND IF THE PICTURE THERE IS ALSO BLURRY, THE CAMERA PROBABLY HAS BEEN DROPPED AND OCCURRED SHOCK DAMAGE . IF THE LENS WAS OUT WHEN IT WAS DROPPED, YOU MIGHT TRY TO GENTLY PULL ON THE LENS WITH THE CAMERA ON. THIS SOMETIMES WILL ALIGN THE LENS AGAIN. HOPE THIS HELPS. IF YOU NEED MORE HELP, REPLY TO ARCLIGHT1217. IT THIS WAS HELPFUL, PLEASE RATE!
THANKS!
