Question about Epson Stylus CX3200 All-In-One InkJet Printer
Paper jam folowed by error message "printer error" switching off, when switching back on ink carrage seems to jam a third the way down carrage and wont go to the right hand side but make a whining noise dos anyone know how to reset
  • 944 Answers
Here is the link for the product information guide (user manual)if you need it; http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=14082&prodoid=24875245 page 11 for epsons answer. if the product is under warranty (details on same link) then best to contact them. If out of warranty, if you wish then try to push the carriage to one end or other gently by hand (turn off first) you will be able to see if the toothed belt and it's pulleys move normally, if you are able to push it all the way to the side, see if this solves the problem, checking if it is catching on anything. else i suspect the drive motor or one of it's gears is to blame, which is probably best replaced by an authorised service centre. although on the uk epson site they don't show support for your model, contact them for local service facilities http://www.epson.co.uk/ Hope this helps :)
Posted on Mar 17, 2007
SOURCE:
I had a paper jam , now i have a loud clicking noise left , red light screen says door open . ive checked all doors taken toner out and put back in removed paper drawer and replaced still nothing
THE LOAD CLICKING NOISE COULD BE THE CARRAGE JUMPING IN AND OUT, DUE TO THE CARRIAGE BEING JAMMED,SWITCH OFF POWER AND TRY MOVING CARRAGE ALONG SLIDE, REASON FOR THIS ANSWER IT HAPEND TO MY PRINTER AND I CLEARED IT BUY DOING AS ABOVE
GOOD LUCK
Sep 22, 2016 | Samsung ML-1910/SEE ML-1910 Mono A4 Laser...
Carrage won't calibrate - more details
Hello! There are many types of error in Canon Printers like P07,P08, E15etc. So please notify the error or check it through your computer notification. After you see the error number (s) please send me a message. Let me try my best for you. Thanks
Jun 20, 2012 | Canon PIXMA iP4700 InkJet Photo Printer
Someone gave me this printer and I just purchased ink for it. Unfortunately all it does is give me error messages. The first message is the I need to turn it off correctly by using the On button. I have...
actually there is a carrage jam problem in you printer.switch off your priner .remove the power card and try to move the carrage block to the other end and try
Aug 02, 2011 | Office Equipment & Supplies
As soon as I started using recycled ink cartridges, I started getting a paper jam error on my printer. The control panel message instructs me to remove the back panel and clear paper jam. I've done this...
As soon as I started using recycled ink cartridges, I started getting a paper jam error on my printer. The control panel message instructs me to remove the back panel and clear paper jam. I've done this several times but there is no paper to clear and the message keeps coming back. I've tried turning of the printer and unplugging it to clear the memory, but that doesn't help. Could it be that the chip on the ink cartridge is messing with the printer's operating system?
Oct 14, 2010 | HP Photosmart C7250 All-In-One Thermal...
HP PSC 1610 printer gives error message: Carriage Jam, clear carriage. I open the door and there isn't a Jam. I tried the solution (clean cartridge, turn off/on couldn't reset) posted by nanotech 9 Aug...
If you are getting a 'carriage jam' error as soon as you turn on your printer with no tasks in progress, then check for any piece of paper stuck in the carriage. Remove the paper carefully. If the paper tears, part of it might remain inside the paper path and damage the product.
Follow the steps for fix HP Printer Carriage Jam
  • Turn off the printer and open it to see where the paper is stuck.
  • Manually move the carriage toward the opposite side.
  • Check the paper path and remove any piece of paper or any other object that is stuck in the path.
  • Reconnect the power cord and turn on the printer.
Aug 21, 2010 | HP PSC 1610 All-In-One InkJet Printer
When i try to print something, a window pops up that says I have a paper jam and the printer has an e then a 3 flashing. there is no paper jam. I've un-installed and re-installed with no luck and I can't...
Dear Sir,
plzz folow this step to solved your problem
  • Step 1 Turn the printer off and on to see if it can automatically clear some or all of the jam. Many printers provide an error-code listing on the front panel display for the area where the jam occurred. If your printer shows an error code, be sure and check the printer manual to see if that identifies the area of the printer where the jam occurred.
  • Step 2 Turn off the printer.
  • Step 3 Remove any paper trays. Inspect them for wrinkled or damaged paper.
  • Step 4 Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  • Step 5 If necessary, remove the toner or ink cartridge. Place it in a bag or away from light to avoid damaging it.
  • Step 6clear-printer-paper-1.6-120x120.jpg jQuery(document).ready(function(){ jQuery('#jsArticleStep6 span.image a:first').attr('href','http://i.ehow.com/images/a00/3f/31/clear-printer-paper-1.6-800X800.jpg'); }); If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly (see A). The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  • Step 7clear-printer-paper-1.7-120x120.jpg jQuery(document).ready(function(){ jQuery('#jsArticleStep7 span.image a:first').attr('href','http://i.ehow.com/images/a00/3f/31/clear-printer-paper-1.7-800X800.jpg'); }); If the paper does tear, try rotating the roller gears manually to free the paper (see B). Don't force anything, though.
  • Step 8 Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  • Step 9 If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path
  • Thanks For Your Time,
    Apr 08, 2010 | Canon PIXMA MP150 All-In-One InkJet...
    PAPER JAM / CARRAGE JAM
    Hello there this may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
    First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
    If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
    And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
    Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
    All The Best: Pineworks
    Jan 05, 2010 | HP OfficeJet 6310 All-in-One Printer...
    MFC-640CW Switch on error message: "Unable to Init! - User Guide says this is a mechanical fault or jam - not a jam all clear. There is an empty Cyan ink cartridge message as well which is correct. Also...
    If there is no jam it is generally a mechanical issue such as...
    1. The planetary arm assembly not engaged correctly
    2. Ink cartridge/purge switch harness not connected correctly
    3. Purge cam switch broken
    4. Gear(s) on maintenance unit broken
    5. Paper feed motor broken
    6. Main PCB defective
    I find that if there was a paper jam, and the user pulled the paper out, option 4 is most likely. It is the smallest of cracks but ruins everything!
    You will need to contact your local ASC for repair, find it here.
    Thank you for using FixYa! – Don’t forget to rate our service.
    Nov 09, 2009 | Brother MFC-640CW All-In-One InkJet...
    Carriage Jam
    If either a paper jam or blocked carriage error message appears on
    the control panel display, there might be some packing material inside the HP allin-
    one. Lift open the print-carriage access door. The orange shipping lock might
    still be in place on the left side of the HP all-in-one. Pull out the orange shipping
    lock and throw it away
    Jan 04, 2009 | HP OfficeJet 6210 All-In-One InkJet...
    I keep getting an error (81:01)
    The problem refers to basically a paper jam. I thing your problem could however be the carrage movment. There is a special oil required for the carrage, but failid this use a very thin oil such as sewing machine oil. The trick is to not use too much oil, only a drop or two over the entire length of the carrage. Also needs to be oiled is UNDER the rail towards the back. Look carefully at the back of the carrage where it has the back slider. This rail needs to be clean and lubricated. Probable easier to clean and lubricate if you remove the encoder strip.
    Regards
    Dave
    Dec 10, 2008 | HP DesignJet 500ps InkJet Printer
    Epson Stylus CX3200 All-In-One InkJet Printer Logo
    113 people viewed this question
    Top Epson Office Equipment & Supplies Experts
    Inky Fingers
    Inky Fingers
    Clive
    Clive
    Alun Cox
    Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
