"Unable to Print 50" BROTHER MFC-440CN
My BROTHER MFC-440CN printer says, "unable to Print 50" on the screen and even after turning it off (which it wouldn't let me do. I had to unplug it!) it just won't work. It has also said, "Unable to Print 30".
It happened after I canceled a print job and it decided to **** the page up right after it started printing! I had to go in and remove the jammed paper. I turned it on and off again. I Tried canceling all printing projects and nothing! Please help me. I use this printer for my business. mfc-4400cn
  • rroverboy May 06, 2009
    same as above
SOURCE: "Unable to Print 50" BROTHER MFC-440CN
my brother mfc-440cn printer says, "unable to print 51" on the screeen after if off (which it woudn't let me do. I had to unplug it. It just won't work.
Posted on Aug 28, 2008
SOURCE: Printer ERROR "Unable to Print 50! Unable to Print 30!" ???
WONT PRINT UNABLE TO PRINT , PAPER JAM
CLEANED PAPER JAM, CANT SEEM TO FIND ANY THING MORE TO DO TO IT
Posted on Oct 02, 2008
wayneard
  • 1901 Answers
SOURCE: how to cancel print jobs on a hp deskjet d1470
Try these:
(1) Click Start>Printers and Faxes>
Doubleclick your printer icon
Click Printer>Cancel All Documents
(2) Turn the printer off and back on.
(3) Delete your printer and reinstall it.
(Make sure you have the CD.)
Posted on Oct 14, 2008
  • 12 Answers
SOURCE: stopping and clearing printing jobs
From the control panel, lower right corner, select "output queue", select "print" tab, select the job you wish to cancel, select OK.
Posted on Jan 06, 2009
  • 37 Answers
SOURCE: Machine Error 71, Brother MFC 8440
The problem is in the scanner motor.To cancel the trouble status follows these steps:
STEP1 .Press MENU *,2,8,6,4
STEP2.The machine beeps for approx. one second and displays “MAINTENANCE" on the
LCD, indicating that it is placed in the initial stage of the maintenance mode, a mode in which
the machine is ready to accept entry from the keys.
STEP3.Now you are inside the simulation Press 01 to reset the trouble status.
STEP4.To exit the simulation press 99
Pressing the 9 key twice in the initial stage of the maintenance mode makes the machine
exit from the maintenance mode, restoring it to the standby state.
Pressing the Stop button after entering only one digit restores the machine to the initial
stage of the maintenance mode.
I hope that this will cancel the error but if not canceled you should call the authorized serviceman to fix your machine.
Posted on Mar 01, 2009
"UNABLE TO PRINT 50" appears
Error: -------- Unable to Print XX
Problem: ------------ The machine has a mechanical problem. -OR- A foreign objects such as a clip or ripped paper is in the machine.
Solution: ------------- Open the scanner cover and remove any foreign objects inside the machine. If the error message continues, do one of the following: ?? (MFC-440CN only) See Transferring your faxes or Fax Journal report on page 139 before disconnecting the machine so you will not lose any important messages. Then, disconnect the machine from the power for several minutes and then reconnect it. ??
May 22, 2011 | Brother MultiFunction Center MFC-440CN...
Unable to clean 50 error
I have a Brother MFC-440CN fax machine and I am receiving error message "unable to clean 50". Can anyone help me to fix this error problem
Jan 13, 2010 | Brother Office Equipment & Supplies
MFC-665CW "unable to print" 50 error
Did you have a paper jam before this happened? If yes then the paper must have pushed the encoder strip out of alignment. You will need to turn off the printer and then push it back into slot to fix it. Let me know if you need more help. Sai.
Jun 11, 2009 | Brother MultiFunction Center MFC-440CN...
Unable to print 50
simple driver configuration problem linux is (the Cups printing system) is pretty universal just get your settings right or even cr even surrogate settings it should work
Nov 27, 2008 | Brother MFC-440CN InkJet Printer
Help
I say you throw it in the trash
Sep 23, 2008 | Brother MultiFunction Center MFC-440CN...
Sep 04, 2008 | Brother MultiFunction Center MFC-440CN...
Aug 26, 2008 | Brother MultiFunction Center MFC-440CN...
537 people viewed this question
k24674
jasbo
jasbo
