Question about Toshiba 53HX71 53" Rear Projection HDTV-Ready Television
Color 'bleeds' or smears when watching HD channels on Toshiba 53HX71
When watching HD stations I see very obvious 'bleeding' of the color blue. The blue color will bleed or smear from left to right across the screen and overpowers other colors, giving the images (which are still clear) a blue overtone. Only the color blue is exhibiting this and depending on the intensity of the blue is more noticeable. The problem is noticeable but only barely when watching standard TV stations as well. I've adjusted the convergence and nothing changes.
Sounds like the same problem i had recently, Take the front off, (its safe so your ok) You will see the 3 lenses which are ajustable, Just keep adjusting 1mm at a time until it solves this, Took me about 45 mins to get it perfect, Persist and you will get there!! Hope this helps
Posted on Mar 18, 2007
Color bleeds
test first a) Video detector, then 2) AGC, adjust control, circuit 3) color Sync 4) color occ 5) color killer 6) color i-f 7)DEM red-gree-blue+videoamp red-gree-blue finally YOKE.see the b.diagram attached.
God bless you
Oct 17, 2012 | Televison & Video
The color is distorted and the picture blinks. I've replaced the lamp twice before and i don't think this is a lamp problem.
color distortion (bleeding colors, or overwhelming of one color)on these tv's is commonly the optical engine. that might make it unecinomical to repair
Mar 27, 2010 | Toshiba 52HM95 52" HDTV Projection...
Trying to hookup vhs analog player to hd proscan
your toshiba player should have output composite video and audio which are color coded Yellow for video, red and white for audio same goes for proscan hdtv. connect between the two keeping in mind color of cables. If the toshiba player is really old you can connect the RF cable output to antenna input to the proscan tv and watch taped programs from the player on channel 3 of the proscan tv. If then you want to keep the hookup and still watch HDTV connect the antenna to the toshiba vcr and when you shut off the vcr you can now watch the hdtv channels as usual because now you are bypassing the antenna to the Proscan tv. Hope this Helps..
Dec 29, 2009 | Proscan 32LB30QD 32 in. LCD TV
I have color bleeding or washout in solid colors? does that mean the lamp is going bad?
I am not sure which set you have, but, when colors are bleeding on a projection set that is a good indication that the tube is going bad. The color that is dominate, red, green or blue, this will tend to bleed across the screen. If I had more information on your set I could give you a better suggestion, but if it is a tube it will be a costly repair.
I hope this information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
Thanks for using FixYa
asnowman
Nov 25, 2009 | Mitsubishi Televison & Video
I've got a toshiba 53hx71 that the screen rolles when the tv is on in the video inputs or the ant inputs. when there is nothing on the tv it has red squigle marks on the black screen. When you watch a...
Most of the time the Hyper Board failing is the cause of this problem. It will eventually get worse where it also affects the HD ins. Unfortunately the Hyper Boards are no longer available from Toshiba and have not been available for quite some time. My suggestion is to coast with it and replace the Set when the HD ins fail.
Sky Assoc
Nov 24, 2009 | Toshiba 53HX71 53" Rear Projection...
Toshiba a205 color off on screen, it seems that the colors are bleeding
Try this first. Start your Laptop in Safe Mode. Are you still having the problem. If you are try reinstalling your graphic card drivers..the color bleeds are mainly due to improper installing of graphic drivers...the blue screens are usually due to memory dumps(RAM problems)...
Sep 12, 2009 | Toshiba Satellite A205-S4607 Notebook PC
Toshiba Estudio 311C Bleeds red
Sounds like your color Photoconductor unit's cleaning blade is dirty/bad/worn out.
Sep 10, 2009 | Office Equipment & Supplies
Kv-36hs20
Have you tried disabling SVM (scan velocity modulation)? Often touted as a "feature" of TVs, it's a way of artificially making a picture appear sharp. Totally unnecessary. When SVM (sometimes called VM) is on, it can lead to some color bleeding around edges.
Mar 24, 2008 | Sony FD Trinitron WEGA KV-36HS20 36" TV
42" philips plasma flat panel television
same problem anyone know what his is please send me an email. real unhappy!!! this tv cost me $900!!!!! rami7344@bellsouth.net
Oct 22, 2007 | Philips 42PF7320 42 in. EDTV-Ready Plasma...
Toshiba 53HX71 53" Rear Projection HDTV-Ready Television Logo
326 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
