Question about Canon Optura 50 Mini DV Digital Camcorder
Power cord and battery's support NO power to Video Camera
The camera was working fine as I was importing images onto my computer. Then the battery died. First, I tried to use my other battery but it did not work ... so I assumed that the second battery was also dead. Then I connected the power cord but accidentally (did not have my glasses) plugged the DC cable into the microphone plug. After I noticed my mistake, I connected the power cord correctly and now the camera does not turn on or charge the battery. When a battery is not attached to the camera (this video model charges battery when it is connected to the camera only) the power light blinks once and then stops. Nothing is being charged. Did I fry something internal in the camera? Or perhaps the charging adapter?
  • 5 more comments
  • sareyet Dec 22, 2007
    My camera stopped working after I had used it for, oh, about 30 seconds.  It does the same thing as far as power light blinking once (and it beeps once) then nothing.  Battery, no battery, plugged in, not plugged in.  POS, I'm afraid.  I am in the military and live oversees so it just seems like a much bigger hassle to send this to a repair facility- any owner troubleshooting or repair advice?
  • Anonymous Nov 24, 2008
    I have the same exact issue except for the fact that mine does not blink at all.
    I have the exact same issue except that the power light does not blink at all.
  • kcbel Feb 07, 2009
    I have the same problem now, one blink and beep then no power. Anyone know how to manually remove a tape??
  • gsknight959 Mar 03, 2009
    Had the battery in and power cord connected. During transfer to computer, camcorder turned off.
    Now, when plugging the adapter in or using the battery, will get a quick blink and a beep, when camera is set to camera or vcr mode on power switch.
    Adapter was plugged into correct power port.
  • Anonymous Mar 22, 2014
    Battery is fully charged and I have also tried the mains adapter without success. I was due to record a wedding later to-day
  • Mike Faurote
    Mike Faurote Jan 12, 2017
    Anyone ever figure out how to get this fixed?
I was using my Optura 50. It indicated a 1/2 battery left, then just stopped working. It has never turned on again and does the same thing you describe (one blink, then nothing).
Posted on Apr 13, 2007
    Novelist:
  • 154 Answers
This incident happens often and damages the camcorder's power board. Replacing power board and some adjustment should resolved the problem. Your cost may run from $175-$225 in US for this model. Whenever you are transfering and connecting to pc, it is recommended to connect AC adapter power for this. Do not rely on a charged battery. Good luck.
Posted on Mar 18, 2007
My fine pix viewer will not download my pictures it has always worked before
A few problems could be present. You may be low on battery. Make sure your camera battery is charged. Second, make sure you are using the correct cord to download. Third, make sure the cord is plugged into the computer. Restart your computer. Then, when your camera is turned off, plug the cord into the camera. Turn the camera ON. This should work. If not, there may be a problem with the cord or with the camera, or your software.
As a last resort....
If your camera works fine otherwise, you can purchase a memory card reader and retrieve your images that way...or take them into the drugstore photo department and have them printed or put on a disk for you.
Jul 26, 2011 | Fuji FinePix A345 Digital Camera
Camera won't turn on after downloading/deleting pics on MacBook
Do not delete files on camera memory using the computer, this may damage the camera. Use camera own delete menu.
Apr 05, 2008 | Casio EXILIM ZOOM EX-Z850 Digital Camera
Tip
Copy Pictures From INTERNAL MEMORY to Memory Card (solution for those who have...
Required:
Samsung D53 Camera
Memory Card (Clean with no pictures on it!)
Fresh batteries
Optional:
Computer
Memory card reader on your computer
Problem:
You have several (or more) photos that were taken with no memory card inserted into the camera, and they have been stored on the camera's internal memory. You have no USB cord to get the pictures off your camera.
Solution:
I don't know if this is in the manual (as this is a used camera I purchased with no manual or USB cord). In my frustration, I accidentally found out how to get my photos off the internal memory and onto my computer's hard drive.
Here are the steps I followed:
1. Ensure fresh batteries are inserted into your camera. You might lose data or get corrupted pictures if the camera dies while you're transferring pictures. Fresh batteries are important.
2. Insert memory card into the camera (where the batteries go) and close the lid.
3. Power camera on.
4. Press the Print/Review button (bottom button to the right of the LCD) once.
5. When you see the words "No Image!" appear, press the Menu/OK button.
6. A new menu will pop up, asking you COPY TO CARD -- use your buttons to highlight "Yes".
7. You will see your camera "Processing!" It will finish on its own, so do not interrupt the task.
(Optional)
8. Once it has finished "Processing!", remove memory card and insert into your computer's memory card reader to see and SAVE your pictures to your computer. Ensure all photos transferred properly before proceeding to Step 9.
9. With the memory card removed from the camera, power the camera back on and delete individual pictures, if you want to reserve internal memory for future emergency picture-taking situations (especially now that you know you can actually get the photos off of the camera's internal memory now!)
on Aug 12, 2008 | Samsung Digimax D53 Digital Camera
I have a canon A590 is camera. When I try to upload pictures onto the computer and plug the camera into the computer nothing happens.The camera does not power on like its suppose to. Why is this? I know...
Your USB cable is fine, I use a generic cable with my A590 with no problems. Connect the USB cable to the camera then your computer, make sure that the camera is set to the view setting instead of picture taking setting and then turn your camera an. Your computer should then see the camera. This is the only combination that works with my camera.
Best regards,
Bob
Nov 24, 2009 | Canon PowerShot A590 IS Digital Camera
My Canon FS200 DVC isn't transferring files
Hi mate, I had same problem as you, took the cam into store and teh guy helped me out.
Make sure you get the recharger for the camcorder, then plug it into teh camcorder and also to the wall power when you are uploading the files. It can needs an extra power boost to get the files onto your computer.
- so plug in your camcorder to computer
- also plug in the battery recharger cord to the camcorder
Should work fine!!
Jul 13, 2009 | Canon FS100 Flash Media Camcorder
Problem downloading image
One of the images did not finish writing to the card properly (usually in the last 4 or 5 images, or the last video)
Try selecting all but the last 10 images and chose import selected. This should work. Then delete those from the card.
This bit is important
Put the card back in the camera (if it's in a usb reader) if not, disconnect the camera and put it into playback mode. View the remaining 10 images/video.
Try re importing and it should work fine! I've had this problem since ilife '09 and this method always fixes it. It seems to happen when the cards get full. Try not to completely fill a memory card and you should not get the problem.
Apr 24, 2009 | Olympus FE-340 Digital Camera
Busy signal when trying to import images to my pc
I have had the same problem with getting a busy signal after plugging in the USB cord. Usually turning it on and off a few times, giving it a few seconds in between, works for me.
Also, have you tried just going into My Computer and clicking on the drive for the USB you've got you're camera plugged into and transferring the photos onto your pc from there? They only go onto your pc, not into a program but you can get them into one from there.
Dec 16, 2008 | Canon EOS 400D / Rebel XTi Digital Camera...
My camera stopped working after downloading pictures
I don't believe the usb cable had anything to do with it. That cable doesn't provide any power. Its a data line. If it did it would charge your battery for you at the same time.
Do you have a power cord for your camera for charging batteries with?
Aug 28, 2008 | Samsung Digimax S500 Digital Camera
PROBLEM WITH PENTAX OPTIO E10
It could be that the battery can't hold a charge anymore.
You will probably have to get a new battery.
Make sure the camera is working fine and that youre able to take pictures with the power cord plug in. If that works it isn't the camera, it's the battery.
Jun 20, 2008 | Pentax Optio E10 Digital Camera
Camera will not turn off/and no buttons are working...
hello, i had the same problem with mine recently. did this by any chance hapen after you had been deleting footage ? i let mine sit on with the black screen for a a hour or so and it came back on and just had to repair the managment file. hope it all gets sorted out, hope i helped.
May 28, 2008 | JVC Everio GZ-MG130 Camcorder
Canon Optura 50 Mini DV Digital Camcorder Logo
628 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Marvin
Marvin
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
