Question about Samsung ML-2571N Laser Printer
Paper feed problem
Samsung ML-2571N.
I had a paper jam and after removing the jammed paper the printer now always has warped paper come out the end. Some sheets come out OK but most are quite wavey/warped so much so that they are not suitable to use for a formal document/letter. I tried using fresh paper but no different. Because the printer will not operate when you lift up any flaps to check the rollers, I do not know if a roller is not working but that is what it appears like, as if the paper is being pushed rather than pulled through the machine ing out a bit crunched up. There are no different noises that I can hear, just bent-up paper on exit.
  • 81 Answers
It sounds to me like there is still a small bit of paper or something stuck in the printer causing the concertina effect on the paper. If you cant do it yourself, then you need someone to take the printer apart to clear any debris
Posted on Dec 16, 2008
Green and red leds are blinking
Hi
Try turning the printer off and on.
Clear any paper jam on the machine.
Disconnect it from the power supply and then re-connect it after a while.
Feb 27, 2012 | Samsung ML-2571N Laser Printer
My Samsung ML-2010 laser printer grabbed up 2 sheets of paper and now both are jammed. I can't pull them out. Now what could I do?
Removing paper jams from printers can be tricky. You'll want to be careful to not tear off the paper. Always try to pull the paper in the feed direction if you can. The Samsung should have a doo in the back or in the paper area that can be opened to assist in removing the jam. If this persists, you may need to replace the paper feed rollers.
Feb 03, 2011 | Samsung Monitors&Printers Monochrome Laser...
The paper does not feed into the printer
Sounds like you have a jam!
The jam always hides good!
Look carefully and get back with me!
Jul 16, 2009 | Samsung ML-2510 Laser Printer
Samsung ML-2510 Laser Printer Jams
printer only supports up 120gsm,anything thicker will jam.
Jun 08, 2009 | Samsung ML-2510 Laser Printer
Jammed paper Samsum ML1610
Take down the front cover, pull the toner cartridge out and pull the paper to remove it. Check the plastic wheel that feeds the paper (use a flashlight). It has a rubber band that might be broken. Replace it if necessary.
Apr 10, 2009 | Samsung ML 1610 Laser Printer
The paper has jammed in my ML-1610 printer.
The paper jams mostly, because the rubber band that feeds the paper to the printer is broken/split. Check the rubber band. It's located within the plastic wheel that feeds the paper.
Mar 09, 2009 | Samsung ML 1610 Laser Printer
Samsung ML 2010 won't paper feed
Lift up the front of the machine a couple of inches. I put a small bo under it. The paper then feeds slightly downhill.
Worked for me.
Jan 30, 2009 | Samsung ML 2010 Laser Printer
Samsung ML-2571N Laser Printer - paper jammed around roller
http://www.samsung.com/us/consumer/detail/support.do?group=printersmultifunction&type=printersmultifunction&subtype=monochromelaserprinters&model_cd=ML-2571N/XAA&mode=C
this link will guide you to the site with the user guides...but in short ..all ya have to do is to be careful and to open and remove the paper...there are not many things that may be damaged in the process...but there is a certain order you have to follow in doing it ...and a few devices that has unusual safety removing gadgets...
Aug 01, 2008 | Samsung ML-2570 Laser Printer
Paper jam
You could try cleaning the tires if you can get to them and check to see if there isn't any paper stuck in the paper path.
Jun 11, 2008 | Samsung ML 1710 Laser Printer
Samsung ML-2571N Laser Printer Logo
317 people viewed this question
Top Samsung Office Equipment & Supplies Experts
HEMANT GROVER
Victorman
Victorman
sahoo_sanjay
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
