Question about Holux GPSlim236 GPS Receiver
Holux GPSslim 236 charging problems
Hi I have a Holux 236 paired with my M3100 PDA. All works well, except for a problem with in-car charging. The Holux charges fine in the car with the supplied mini-USB connector. The Holux charger does not though charge the M3100. I bought a mini-USB Y cable to charge both. It charges the M3100 fine (through either connector) but hangs the Holux so I have to take the battery out to reboot. There seem to be two possible reasons: I found the following on a forum, "We measured voltage coming from different charging cables. Both USB-miniUSB cables for our two GPS's has the same output (pin 1 +5V, pin 5 ground). Both RJ11-miniUSB cables (for our two PDA cradles) also has the same output, but the 5V and ground were opposite (pin 1 ground, pin 5 +5V). It explains why cable didn't work with Holux GPS's and worked with our PDA. It looks like the PDA might have a built-in rectifier so you can charge it either way, but Holux model doesn't." I am not sure about that. I think the problem may be to do with pin 2. The Holux spec notes: A/1 = GND B/2 = NC C/3 = +DATA D/4 = -DATA E/5 = +5v I think the PDA cables have pins 1 & 2 linked - telling the phone "This is not a USB power supply" so the phone charges the battery at its maximum safe rate. I think grounding pin 2 causes a problem for the Holux, despite it noting pin 2 "n/c". I have thought of trying to disconnect pin 2 inside the Holux to see if it fixes it but it would not be easy without risking damage. Can you throw any light on this? Thanks in anticipation Michael
Go to the Holux support website at:
NOTE: All quote marks are added by me for emphasis only.
Under the "Select products Catagory" dropdown choose "GPS Receiver/Data Logger".
Under the "Select products series" dropdown choose "Mouse Type GPS Receiver" and
click on Submit. A new page opens showing various receivers. Scroll down to the GR-213u
GPS Receiver and see the one called "GR-213u Driver Program-Vista Driver". It is of a type
of file compression called "rar" which may require a unzip program. I use a free program,
"Secure Zip for Windows". Click on the little yellow box at the far right of the "GR-213u
Driver Program-Vista Driver" line. It will be labeled "9618869.rar". Save the file.
It should be found by clicking on the Vista START and then your user name & should be in
the "Downloads" folder as "9618869.rar".
Creat a new folder for the actual unzipped file by clicking on the the Vista START Icon
& then "Documents". Click on the "Organize" tab & then on the dropdown "New Folder".
Name the new folder "Holux Vista Drvr" & then open it.
Now back at the "Downloads" folder open (Unzip) the "9618869.rar" file. Copy the new
folder "GR-213u Driver Program-Vista Driver" to the "Holux Vista Drvr" folder you created
in "Documents", so that you can later delete all those files that may have built up in
"Downloads"folder from doing lots of downloading.
Open the "GR-213u Driver Program-Vista Driver" folder & see the setup file
"PL2303_Prolific_Vista_3301.exe". The size should be about 2724 KB. Open it to start the
driver install. Now you are almost done.
After Vista has done its driver install, go to "Control Panel" & open "Device Manager".
Now plug in your Holux GR-213 & the "Device Manager" should now show a new entry
called "Ports (COM & LPT). Click on the little + sign to expand it & you should see
"Prolific USB-to-Serial Comm Port (COM#)". The # represents your Comm Port number
used by the Holux. Right click on "Prolific USB-to-Serial Comm Port (COM#)" & click on
the dropdown "Properties". Click on the tab "Port Settings"at the top of the "Properties"
window. Change the value in "Bits per second" from 9600 to 4800 & click OK.
Hopefully you have installed the Holux Utility "GPS Viewer" with a shortcut on the
desktop. Open the "GPS Viewer" & click on "Scan". A new window "GPS Scanning" opens
showing GPS found at the same Comm Port # that shows in the "Device Manager". Click on
OK & the scan window closes now showing the same Comm Port#. Click on "Open GPS" &
then on "Cold Start or Warm Start" & all the satellites found should show up. You can close
the "GPS Viewer" & all the other open windows. If all went as described any software you
used with Win XP using GPS should work OK now with Vista.
Now run your software (MS S&T or whatever) & make sure its GPS Settings show the same
Comm Port# as in "GPS Viewer" & baud rate of 4800.
Jan 17, 2009 | Holux GR 213 Sirf Star III GPS Receiver
Orange SPV m3100 not charging
Hi I've got the same problem well did have you need to do a hard reset so save all your files a bit of a pain I know, the other alternative is simple turn off the phone and it will charge fine.
Hope this helps anyone
Dec 18, 2008 | Orange SPV M3100 Smartphone
Connect PDA TO GPS
you can start using one you have paired them.
connect your pda to your systems port.
Sep 28, 2008 | GPS
Paring problem
I had the same problem with my Laptop. Try having the laptop ask and send the security code. try to use any number higher that ZERO. That fixed my problem. I love my E61.
Jul 01, 2008 | Nokia E61 Smartphone
Spv m3100 phone pda
Have you tried doing a hard rest. Here is the procedure;
Caution if you perform a full reset, your phone returns to its default settings and looses all information that is saved on phone (Like contacts, messages, emails, mms etc).
Hard reset: Press and hold the Left SOFT KEY and Right SOFT KEY, and at the same time, use the stylus to press the RESET button at the bottom of your device. You will be presented with a menu saying 'press R to reset, X to exit', if you press R Your device will be set back to factory default settings.
(The L/R soft keys are the "- -" keys just above the start and OK buttons)
May 01, 2008 | Orange SPV M3100 Smartphone
Orange SPV M1000 GPRS problem
My post to you stated I had messed with my settings, as a result of this my PDA searched, but was unable to find a network. after several days and many hours trying various things in settings then connections the problem was solved But I don't know which action solved it, but it was in CONNECTIONS.thanks for your help anyway
Mar 30, 2008 | Orange SPV M3100 Smartphone
Cant get phone to work
The G88 generally comes with a desktop charger too. The connector at the bottom of the phone does not work properly very often. So you may try charging the battery with the desktop charger and then fix it on the phone. It may solve your problem
Dec 18, 2007 | Group Sense PDA Xplore G88 Handheld
SPV M3100 - sync problems
Pleset let me know that are you using MIcrosoft Active Synk...if not you can download the this form with the help of this Active synk you can explore your PDA from your computer.
i hope this would help you
wish you luck
Was this solution helpful? Show your Appreciation by rating it:
Oct 11, 2007 | Orange SPV M1000
PDA would not turn on...
try to charge it for longer time, then try to turn it on, i'm not sure that its gonna work.
Jul 24, 2007 | Dell Axim X51v Pocket PC
Bluetooth GPS Tom Tom to operate with PDA Xda IIi
Have you tried using 'other wired device', try each com, rather than bluetooth, on tomtom configuration settings, works for me with TT5 and a Holux BT GPS reciever
Jan 28, 2007 | O2 Xda III
Holux GPSlim236 GPS Receiver Logo
93 people viewed this question
Top Holux GPS Experts
Oloyede Monsuru
Are you a Holux GPS Expert? Answer questions, earn points and help others
