Question about E-Machines eMachines Desktop PC
BIOS stops booting with two CD checks
Had a weird problem this morning with an eMachines T5246 -- computer had been running fine, a week after I upped memory to 4gb. No other hardware changes since just before I bought it this spring.
At boot it said something like the usual BIOS gobbledygook
Then
Checking for CD
Checking for CD
And it would hang. I checked BIOS -- First option is boot off CD, second hard drive, third network card. I'm wondering if the BIOS somehow got corrupted and it was really trying to check the CD the second time around and stalled ... ? I temporarily changed it over to boot off the hard drive first, and it's fine.
But I don't know if this is a good time to buy a new BIOS battery (computer's less than a year old), flash the BIOS again (no updates available, just to reflash) or what. I probably ought to go back and make it 1) cd 2) HD again, save it and see if it works, but I'm nervous about changing this now that I've got it working again. Any suggestions?
  • Boogerhead01 Dec 15, 2008
    Sorry, no, I had not flashed the BIOS again ... I just wrote poorly -- I meant flash it to the same version from which it came out of the factory.
    I'd rather have it check for a boot CD, but if I'm at that stage, it means something else is broken, and my wife isn't going to be able to fix it anyway. Maybe I will just leave it at booting off HD even after the steps suggested by stree, which I will try. Thanks so much, gnetlemen!
    Master:
  • 461 Answers
It is absolutely ok to have it set to boot the HD first.
When you say 'flash the BIOS again' - does this mean you recently flashed it? As this will reset the boot order to the default (1.CD, 2.HD)
Posted on Dec 15, 2008
  • 61 Answers
1. Chek whether the time and date is correct
2. If No, change BIOS Battery, if Yes, No need to change the Battery
3. Install the latest Version BIOS (if the existing is the L8st, then reinstall)
4. Selct "Load Optimal Default" in BIOS and try to boot
I have a eMachine t5246. My hard drive went bad, very bad, couldn't get it to even get wiped out so. my eMachine disc won't start up. It is the operating disc but every time it says install and...
If the hard drive failed you will first need to replace it with a working hard drive. One that is done, power on the computer with the recovery disc is the drive and enter setup. It should say something like press F9 or F10 for Setup. Look through the menus for "Boot Order", make sure your CD/DVD drive is above hard drive. Save the changes and reboot, you should get a message "Press any key to boot to disc" or something similar, do so, and follow the prompts to re-install windows.
Jul 07, 2013 | Computers & Internet
I bought a 4gb ram upgrade and its still running slow why?
If the upgrade was added to the 2 GB of existing RAM, your computer will run at the slowest speed. That's why some manufacturers recommend replacing existing RAM with the upgraded memory
Jan 02, 2013 | eMachines EL1360G-UW10P AMD Dual-Core...
How mutch ram can go into the emachines netbook?
Installed RAM: 1 GB RAM Technology: DDR2 SDRAM Max Supported RAM: 2 GB
if that will run a 64 bit operating system you can run more memory in the machine tho
May 14, 2011 | Acer eMachines eM2501162 Netbook
Our emachines el1200-06w runs very slow after sitting idle for any length of time - when we start it up, it runs OK, but later it almost stops - takes very long time to process. we run defender pro 2011...
You need to upgrade your memory to the maximum allowed by your motherboard which in your model is expandle to 4gb of ram max. You should be fine with the cpu that you have, just don't be running high gaming, digital editing, programs. You shouldn't multi task that much either too, because your cpu isn't meant to handle that much of a thread. But adding memory will solve the slow unresponsive promblem you are dealing with. Your computer should accept ddr2 memories. Remember don't go over 4gb, otherwise your computer won't function correctly.
Jan 30, 2011 | E-Machines eMachines Desktop PC
My emachine t5246 just beeps when i turn on why?
This could be a memory dump issue or a parity cheksum issue
what you need to do is open up the tower and take the memory strips out and reseat the same and reboot the system
Dec 26, 2010 | E-Machines eMachines Desktop PC
This machine is very slow and choppy when it comes to video editing & playback - any suggestions?
Without knowing the system/hardware configuration and softwares installed on your computer/emachine, it's not possible to assume which is the root of the problem. If you haven't upgraded the memory, i would suggest you to do it upto 2gb. Windows xp would run fine with adobe premiere and adobe photoshop, windows media player should not be having any problem if you are upto date with the codecs. Please also check the virtual memory and make it double the memory installed on your system. Uninstall unnecessary programs/applications, it's also important to run system registry cleaning everyday or every alternate day. I would suggest you to run a defragmentation every week so that there's no fragmented files. Run an full antivirus scan using an updated antivirus every possible days.
Good luck.
Thanks for using FixYa
Jun 25, 2010 | eMachines W3507 PC Desktop
Cannot log in to passwor protected Emachine T5246 after several attempts using original password.
you can reset the password using a password killer or any other resetter cd software. you can download from internet. burn it in a cd. boot from the burned cd. and then u can reset your individual account password. steps are easy.
Feb 28, 2010 | Computers & Internet
Windows xp will not install
If you don't see the message on start up "Press any key to boot from cd" Then you need to change the boot order.
Start the PC and hit delete a number of times. This will take you into the bios screen. (Set up screen)
You will have a tab called "Boot Priority" or "Boot order". Make sure that CD/DVD drive has 1st priority. Save & exit & your done. Upon restart if you have a disc in the drive you will get the option to press any key to boot from CD/DVD. By default, most motherboards are set to boot from floppy & then Hard drive so in most cases you will need to enter setup & change the boot order.
Don't forget to rate me.
Oct 19, 2009 | Microsoft Windows XP Home Edition
Stuck on BIOS Screen?
I would try to power off the machine completely and hold a key down on the keyboard and power on the computer while still holding down one key. Keep holding it (it might make an irritating beep sound, that is expected) . This is one trick that will almost always force a computer to go into the BIOS. I might also check that the power to the Hard drive was not accidentaly unplugged as I see the CD-ROM drive was recognized, but I do not see a hard drive which means a couple of things, either the hard drive died or it has no connection to either the power or data cable. Check these and see if your computer will boot.
Jun 08, 2009 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
99 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
