Question about Samsung HCN529W 52" Rear Projection Television
Lines on TV
I have a Samsung rear projection TV and it is 5 years old this month. A few months ago it started having wavy lines that come and go. When they appear, the are constantly changing directions. Do you have any suggestions? My email address is JolieSmith2001@yahoo.com .
  • MANMANDEAN Feb 12, 2009
    the h line and the v line one my sponge bob tv aren't in the place i want them!!! PLEASE HELP PPPPPPLEASE HELP MEE!!!!!!!!!1
thecritter
  • 29 Answers
SOURCE: Thin Yellow Vertical Line - Samsung LNT4665F LCD TV
Unplug for 30 seconds from it's power source and then try it again. If that doesn't work, call Samsung for further troubleshooting and have your model number and serial number handy. Please be prepared to tell them how long the line is.
Posted on Mar 30, 2008
SOURCE: HL-P5063W Green lines when the tv warms up
My Samsung DLP is having the same problem.  Not sure what to do, but I will contact my warranty place for the second time.  Hopefully they'll fix it.  Any other suggestions?
Posted on Apr 06, 2008
SOURCE: LCD TV SCREEN PROBLEM RED HORIZONTAL LINES OF DOTS ALL OVER SCREEN PLEASE HELP
I unplugged the TV and now the picture is back.I read that the LCD's are vunerable to static build up so unless my daughter is using her TV I unplug it.
I was thinking about getting a large LCD for the family room but I'm not going to until they improve on this technology.
Good luck to everyone!.
Cheers.
Posted on May 08, 2008
  • 4234 Answers
SOURCE: SAMSUNG REAR PROJECTION TV PICTURE
This is a convergence problem. Please post the model number so I can give you details.
Thanks,
Dan
Posted on May 28, 2008
lukster
  • 217 Answers
SOURCE: vertical colored lines no picture.
if the tv is less than a year old , call 1-800-SAMSUNG for warranty repair, the lcd panel is bad
Posted on Aug 03, 2008
Samsung HLN507WX/XAA - Bad Picture
its sounds more like the digital board that needs to be replaced
May 04, 2009 | Samsung HLN507 50" Rear Projection...
Panasonic projection lcd pt-44lcx65 pink wavy lines
The problem is the computer in the TV is set to hold data for 2500 "On/Offs" Once you turn the TV on and off 2500 times, the dots start to appear as the computer cannot store anymore date. Call Panasonic, they will send a tech to your house for free and reset the computer and update it at the same time from 2500 to 1 million on/offs so it wont happen again. It takes maybe 10 mins to complete.
Hope this helps.
Mar 25, 2009 | Panasonic PT-43LC14 43" Rear Projection...
Video distortion
You need to take your tv in and have the picture deflector re-aligned.  This doesn't cost much, My dad had to do that to his a few months ago and it cost 30 bucks.
Mar 21, 2009 | Mitsubishi VS-60705 60" Rear Projection...
Green lines in TV
Take the TV cabinet apart and unplug and replug all the circuit board connectors, that may fix the issue.
Jul 06, 2017 | Samsung HLN5065W 50" Rear Projection...
Samsung rear projection tv
I think it could be a faulty diode on the power supply board. If you can check this for yourself otherwise call out a competant technician. Good luck.
Sep 30, 2008 | Samsung HC-P4752W 47" Rear Projection...
Vertical colored lines no picture.
Dec 17, 2007 | Samsung LNT3242H Television
Lines on tv
Set starts, horizontal and vertical deflection work, HT ok, crt heaters ok, but no sound or picture
I turned the G2 voltage up and noticed a white screen with flyback lines, frame ok. I detected two badly soldered double diode rectifiers in the secondary part of the power supply ! I checked all other joints, and everything was ok !! success
White horizontal line (no vertical deflection)
Check / replace R548, R549
Sound but no picture except for a couple of horizontal colour lines
Replaced the frame chip TDA8356, set now ok
Nov 23, 2007 | Mitsubishi WS-65511 65" Rear Projection...
Wavy lines
KIT10 $29.50
Repair Kit for Hitachi convergence Chassis DP-14G
KIT10 Includes 2 pcs STK392-150 , 1 each of the following 1W axial lead fusible resistors:
http://www.digitalhome.ca/forum/showpost.php?p=564268&postcount=220
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Nov 10, 2007 | Hitachi 53SWX10B 53" Rear Projection...
Red picture in panasonic 60" Rear Projection TV
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 27, 2006 | Philips 60PP9352 60" Rear Projection...
Wavy picture
this is caused by a bad convergence module, and there are probably some dried out electrolytic caps in the circuit as well. i have one in the shop right now that came in with the same problem. if you have it serviced, make sure they replace all of the convergence modules (there are usually 2, but sometimes 3 of them), because if one went bad the other(s) is likely to go out soon as well.
Jun 28, 2006 | Toshiba 65H82 65" Rear Projection...
Samsung HCN529W 52" Rear Projection Television Logo
Jerry Greenberg
Jerry Greenberg
