Question about Panasonic SC-HT740 System
I have a f16 failure on my panasonic sc-ht895 how 2 fix
I checked speaker cable connections like manual said but did not work
  • conman90 Dec 27, 2008
    suting off
    not turing on
4 Suggested Answers
SOURCE: PANASONIC Home cinema SC-DT100 - Flat cable connection
Hi, when you say it doesn't work, will it just not play/read the disc? Mine has to be "initialized" every time or it shows "No Disc". To initialize I turn the unit on then press and hold "Stop" on the unit and the "10-" button on the remote, then it works fine.
Posted on Oct 09, 2007
SOURCE: Simple question?? how do I connect my Panasonic subwoofer to my denon receiver?
I have a very similar problem with the same exact Panasonic sub. I went to Best Buy and Radio Shack looking for an adapter, and they basically told me that one does not exisit. Apparently, Panasonic designed the home theater system specifcally so that it could not work if any part of the entire system was ever seperated.
Posted on Nov 15, 2009
SOURCE: how can i get the system to work with my tv
if you have it connected with the HDMI cable to your tv, use the ARC on the receiver to hear audio out.
Posted on Jul 18, 2010
Panasonic sa-vk800 when the volume up the unit is shoot down than display f16
Check all of your speaker wire connections at both ends for looseness, strand wire fraying/breakage, correct polarity and corrosion. If all are ok, reduce your setting for the amount of bass it outputs.
Dec 15, 2014 | Panasonic Sa-ht70 Home Theater Receiver 5...
How do I connect the SC-BT228 Home theater to my new 50" Panasonic Plasma TCP-50S30 so that I can use the home theater speakers for both TV and Disc player?
You need a Digital Audio Cable connected as shown below from your SC-BT228 Manual.
Full setting details for the SC-BT228 Digital Audio In & TC-P50S30 Digital Audio Out are within the Manuals which can be downloaded from Panasonic at the following link.
http://www2.panasonic.com/consumer-electronics/support/
Please leave feedback.
Cheers
Andy
May 15, 2011 | Panasonic SCBT230 Theater System
Unit displays f61 and nothing works What component is related to this
"Check and correct the speaker cord connections. Page 7
If this does not fix the problem, there is a power supply problem. Call 1-800-211-7262 for support."
http://www.retrevo.com/support/Panasonic-SC-HT75-Home-Theater-Systems-manual/id/356ci969/t/2/
It's implying you have a shorted speaker wire.
Jan 22, 2011 | Panasonic SC-HT75 System
Getting code f16 . already reconnected speakers. also get code INIT and system shuts off. What new parts do i need and what is the problem
It's not that easy to diagnose over the web with what is given.
You mean "F61", right?
"≥Check and correct the speaker cable connections.
If this does not fix the problem, consult the dealer."
http://www.retrevo.com/support/Panasonic-SC-HT743-Home-Theater-Systems-manual/id/356ci966/t/2/
Generally speaking, an amp protects itself from heat, shorts and overloads.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Jan 21, 2011 | Panasonic SC-HT743 System
May 27, 2009 | Panasonic SC-HT930 System
Fornt speakers does not have any sound.
remove the front speakers cables from the rear-remove surround speaker cables from the rear and put them in the place of front speaker-run a music if you get good sound the problem in your front speakers(speaker or its cable)-if you got nothing you will have a problem in your system itself and need to fix in service center.
Aug 29, 2007 | Panasonic SC-HT930 System
Panasonic SC-HT740 System Logo
65 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
