Question about Compaq Presario Notebook
Mouse pad U sent me a comment about my mouse pad today. Do you know of any other solutions I may try?
  • sxxxs May 11, 2010
    What?
  • Boogerhead01 May 11, 2010
    I got an e-mail that I should reply to this posting, but I don't remember anything about helping with a mouse pad. ... ?
I can't find any information re Windows CE. All I want to know is how to use the help page and how to disable the mouse pad.
Hi ms_k7582,
To "Disable" the Mouse Pad, or ("Pointer Device")!
Select the Control Panel, in the 'shortcut menu.
paul7of9_142.jpg Next, select the Device Settings, in the [Devices] block.
Click on, to "highlight the item you want to [Disable]."
The "Pointer Device, this will also 'Disable' the "Touch Pad"
Click the "Disable Button," just below.
"Always, ("click") on the, "Apply, and OK buttons before exiting."
*Note: Restarting the computer will configure system changes.
"Please let me know if you 'need' further assistance; by posting a "Comment 'or' Rating the Solution." Thanks, your 'response' is important!"
paul7of9
Mar 07, 2011 | Sylvania G-Netbook
How do i disable the touch pad on my Dell Lattitude E5400 laptop? Thanks, Tom tc@tc-talent.com 917-733-5968
You can turn off the touch pad through the mouse settings in the Control Panel. I was a little frustrated by this too, but if you go to the Control Panel and click 'Mouse', the first tab of this new window is 'Dell Touchpad'. Simply click anywhere in that window and you'll be able to configure the touch pad settings. One great option for many people is 'Disable Touchpad/Pointing Stick when external USB mouse is present' as there is no easy one-button solution to disable it.
* Please rate this solution with Thumbs up and comment to help us improve providing support
Nov 30, 2010 | Dell Latitude E5400 Laptop
Sir, i want to know about the optical mouse in detail. what is the important point of it to use. thanks, tin
Optical mouse was developed by Agilent Technologies and introduced to the world in late 1999, the optical mouse actually uses a tiny camera to take 1,500 pictures every second. Able to work on almost any surface, the mouse has a small, red light-emitting diode (LED) that bounces light off that surface onto a complimentary metal-oxide semiconductor (CMOS) sensor.
The CMOS sensor sends each image to a digital signal processor (DSP) for analysis. The DSP, operating at 18 MIPS (million instructions per second), is able to detect patterns in the images and see how those patterns have moved since the previous image. Based on the change in patterns over a sequence of images, the DSP determines how far the mouse has moved and sends the corresponding coordinates to the computer. The computer moves the cursor on the screen based on the coordinates received from the mouse. This happens hundreds of times each second, making the cursor appear to move very smoothly.
Optical mice have several benefits over wheeled mice:
No moving parts means less wear and a lower chance of failure.
There's no way for dirt to get inside the mouse and interfere with the tracking sensors.
Increased tracking resolution means smoother response.
They don't require a special surface, such as a mouse pad.
Although LED-based optical mice are fairly recent, another type of optical mouse has been around for over a decade. The original optical-mouse technology bounced a focused beam of light off a highly-reflective mouse pad onto a sensor. The mouse pad had a grid of dark lines. Each time the mouse was moved, the beam of light was interrupted by the grid. Whenever the light was interrupted, the sensor sent a signal to the computer and the cursor moved a corresponding amount. This kind of optical mouse was difficult to use, requiring that you hold it at precisely the right angle to ensure that the light beam and sensor aligned. Also, damage to or loss of the mouse pad rendered the mouse useless until a replacement pad was purchased. Today's LED-based optical mice are far more user-friendly and reliable.
Thanks and regards,
Anil.B.R
Aug 18, 2010 | Computers & Internet
Lenovo n500 laptop ... mouse pad not working
The mouse pad maybe faulty or the ribbon cable from the mouse pad to the motherboard may not be properly connected. Reseat this cable.
You can connect an USB optical mouse to the laptop. I prefer you use a USB mouse all the time over the mouse pad.
Sep 29, 2009 | Lenovo 3000 N500 Notebook
Scroll bar on asus mouse pad not working
Try removeing any external devices and reboot the unit.
Next, look at your device manager for flags..
Remove any if shown in manager.
Restart the unit.
If you still don't have control of the scroll bar, try booting into safe mode and see if you have control their.
If you still do not have control of the scroll bar, try reloading the drivers for the mouse and touch pad.
Buy any chance do you have a mouse lock or switch on the unit that may be on.
I know, on the center of my touch pad, I have a switch to engage and dis-engagae.
Sep 24, 2009 | Computers & Internet
Mouse Setting Problems
First right click on my computer then properties then system restore should be at the top
it's there somewhere try and restore your pc to an earlier date when you know it worked.
Then restart your pc
If that did't help I would definitely do a virus scan
Jan 15, 2009 | Toshiba Satellite A100-S8111TD Notebook
Turn off touch pad
When you are booting up from a cold shutdown, Tap the F2 key until you enter the Bios/System Setup Pages. Usually you use the Alt+P key combination to navigate in these pages, but there should also be a legend at the bottom of these pages to indicate what keys change pages. In these pages you will come upon your option to choose pointers. One is usually, glide pad + mouse. I'd try that first, as it senses when a mouse is attached and disables the glide pad. However, this doesn't always work with Dells. So, if that is the case, choose Mouse Only for a PS2 Mouse and or Serial for a USB Mouse.
The Glide Pad is found in the Control Panel, Mouse where you have a property tab that has the settings for your glide pad. Besides setting pressure sensitivity you can also disable it in some Dell Systems.
If none of this works for you, look on the bottom of your laptop for the Service Tag number and send that set of numbers and letters to me using the comment box below and I'll find you the driver update that should repair your Glide Pad.
As always, please rate all our solutions on FixYa.
Always here to help,
Worldvet
Aug 21, 2008 | Computers & Internet
I have an Acer Aspire laptop 5520g-301g16nb xc4119 when moving the pointer around the screen it skips and jumps erratically and can be difficult to control. It has been sent away for repair once but is...
Mouse error! please try to clean the mouse or replace it with new one.
if using touch pad tthen you have to install all the driver of your laptop this will resolve errors.
may this help,
melnavz
PS:
pls do not rate me if my solution not solve the issue and you need more further information. but if is invaluable solution rate me fixya.
May 02, 2008 | Computers & Internet
Toshiba laptop touchpad click not working
Ok so here goes.... I had the same problem:
Go to the 'start' button and then hit the 'control panel' option, then click 'mouse' then go to 'Device Settings' and then to the 'settings'. When you get to this screen it shows a list on lthe left hand side choose the 'tapping' option and then ok.
Hope it works for you...it did for me.
Feb 09, 2008 | Acer Aspire 5610-4648 Notebook
Compaq Presario Notebook Logo
19 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
