Washing machinge isnt using cold water
Washing maching worked fine before we moved and sine we moved we can't get cold water to enter the machine.
The cold water tap is fine, we can even get it flowing through the washing machine hose but there semes to be a problem when it is attached to the machine. we used the bolts when we moved which were supposed to keep everything in place.
  • Washing Mach... Master
  • 3,463 Answers
Maybe a wire has pulled off cold valve you need check and look,if o/k. See if you can hear valve buzzing, if you can and still no water comes in, then replace valve.
Posted on Dec 15, 2008
Why is my Kenmore elite three speed top loader washing maching model number 110.23022101 only washing on HOT water? The cold will not work. We recently had workers remodeling that room and the washing...
Make sure the cold water supply is on and not blocked.
If the machine fills but does not wash try to find a thermal switch that is supposed to come on when the cold water has heated up.
Jul 20, 2014 | Kenmore Washing Machines
Maching not taking in water
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
Washing Machine Problems No Water
Washing Machine Fix Washing Machine No Water
heatman101
Apr 26, 2011 | Siemens WXL132GB Front Load Washer
When iput washing on it seems that the hotwater isnt hot the pipes are on ive checked
Some washing machines allow hot water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally. If you're sure the machine isn't working the way it used to--or should--try these tests: Is the hot water turned on? If not, turn it on.Is the washer getting cold water but no hot water? If so, check to see if the control panel settings are correct.Is there hot water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, completely replace the Valve.
Nov 30, 2010 | Hotpoint Aquarius WD640 Front Load...
My Frigidaire Galaxy Washing maching will not allow water into the tub.
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
heatman101
Sep 07, 2010 | Washing Machines
The cold water is not working
Most likely the solenoid on the cold water side has failed. The water inlet valve must be replaced as a unit. They are inexpensive and easy to replace. Here is a link that should help http://appliancehelponline.com/topwaterinletvideo.html
Jun 26, 2010 | Admiral 32 cu. ft. Washer
The washing machinge is not completing the complete cycle
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Jul 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing maching won't rinse in cold water
hi is this hot and cold water piped machine? ie two connections on rear of machine for hot and cold pipes ? if so are your pipes connected properly on machine and the water supplies? if cold supply is connected to hot supply then wash inlet allows water in washer then washes in cold? but when rinse is due? the elec valve that has hot water pipe connected?? is failing to open allowing water flow of hot on rinse so advise recheck pipes for flow of water from both? when disconnected from machine if flow ok then possible valve blocked/faulty hope you can understand above? if you can give more info on your machine it would help to offer a remedy?
Nov 01, 2008 | Hotpoint Washing Machines
We own a older Maytag Washing machine that has worked great over the years. We have been living in IL with our own well water and have found just the cold water to be slow in entering the machine. Now,...
You have to check your faucet coming to the machine. Is there good pressure from the cold pipe, there shd be; maybe a valve not fully open? While you are there clear the screens on your hoses and machine. Check for leaks after refitting.
Jun 04, 2008 | Maytag Washing Machines
Washing machine
HOT WATER VALVE IS FAULTY
Nov 29, 2006 | Indesit W 123 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
