Have been given a Lanier015spf photocopier and would like to know how to use the scanner function?
  • 157 Answers
Hi netz:
I found a couple things to help you out. First of all, youre going to need to install the driver (if you didnt get the CD)
If you are using Vista, click here
If you are still using Windows XP, click here
After installing the copier (nice gift, by the way), you can operate the scan function by:
1. On the device's operation panel, press the [Scanner] key.
2. Press [Original Feed Type].
3. Select [Batch] or [SADF].
To scan originals using the exposure glass, select [Batch]. To scan originals using the ADF, select [SADF].
4. Press [OK].
5. Place originals.
6. Press [Start] to scan originals.
7. If [Batch] is selected, place additional originals, and then press [Start].
8. If [SADF] is selected, scanning starts automatically when you place additional originals.
9. Repeat this step until all originals are scanned.
10. After all originals are scanned, press [#].
11. Storing or transmission starts.
If you have any additional questions, dont hesitate to ask. Also, for future reference, here is the manual for your copier.
NOTE: your model number is actually LD015
and most manuals and drivers associated with your product can be used for the LD015f ; LD015spf and vice versa
Hope this helps,
Posted on Dec 15, 2008
Why can't I phtocopy?
The scanner light or sensor might be faulty. As you have not provided the model number please check if it the scan function is working. If not then that confirms the sensor may be faulty.
Aug 25, 2014 | Epson Stylus Office Equipment & Supplies
Hello, The scanner & photocopier were not working and the screen was just stuck on the "scanner bulb warming up". Then, after days of trouble shooting, it finally began making a noise,...
From what you described it sounds like you need to get the "scanner assembly" replaced.
The bulb is probably bad and won't come on to full power.
Not knowing what kind of printer you have, probably won't change the fix. If you can look at the event log you may be able to see an error code which could make it a definite scanner assembly replacement.
If you want to throw money at this unknown printer, get a tech to look at it and give you an estimate.
Jan 17, 2011 | Office Equipment & Supplies
Scanner function does not appear to work. All
i would say possibly you are missing out on something..because if the other functions particularly photocopying are working then this should in if the photocopying function works then the scanner is ok cause basically in photocopying the machine scans then prints... perhaps check whether you are correctly following procedure to scan..most hp all in ones have a button on them that you press and it automatically initiates scanning and simultaneously the software on the pc is initiated..try this,if not then try reinstalling the hp software..hope this helps..regards
Jun 04, 2010 | HP Photosmart 2575 All-In-One Printer,...
My printer works as does the photocopier but the scanner wont scan to the PC
My copier and my fax function work but the scanning function does not work. My computer previously crashed and I downloaded what I think was the correct driver. I have a multifunction MP530 unit.
Nov 06, 2009 | Canon Office Equipment & Supplies
I want to know all error codes for nashua tech dsm618 photocopier AND ITS TROUBLESHOOTING.....
Wow, you'll need a service manual for all of that info. Contact the manufacturer to see if it is available to you, as this information is generally only given to dealers or qualified service techs. However I was able to get a service manual for a Panasonic printer I won without too much trouble ($40 US).
Oct 29, 2009 | Gestetner DSm515pfd Digital Copier -...
No gradition
try replacing the transfer belt cleaning blade.
Apr 14, 2009 | Canon imageRUNNER C3200 Copier
LSU ERROR MESSAGE ON little screen when photocopying
The LSU error stands for Laser Scanner Unit error. The probable cause/s:
The Polygon motor in the LSU does not rotate.
The LSU’s laser beam is functioning properly.
What you can do:
Try to unplug the machine for a couple of minutes or maybe a little longer and then plug everything back in. Power on and then test.
Mar 11, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Photocopying problem in All-in-one Hp printer
have him check for density, brightness, contrast. if that doesn't work, scanner gone bad
Oct 05, 2008 | HP Photosmart C3180 All-In-One InkJet...
Ricoh Aficio 1018 photocopier
Nov 30, 2007 | Ricoh Aficio 1018D All-In-One Laser...
85 people viewed this question
