Question about Acer Aspire 5003WLMi Notebook
Laptop cannot go into p.o.s.t. when it does.....
The laptop thur normal operation will turn on with the harddrive light and battery flashing on and off then load into windows. the problem is that the sometimes;laptop cannot go into p.o.s.t. when it does the screen turns white or does not show anything at all. it only shows the power light only. atfer turning it off and in like 10 or 20 times. it will evenually go thru post and then windows bootleg. however, there are some cases that it goes thur post okay but windows does not boot; the screen turn white or it goes into windows but it lasts about 10 minutes then the screen goes into different colors. so, i don't if its the motherboard built in video card is going bad or the memory is going bad or the harddrive it self. I personally think its the video card going bad but i'm not to sure please reply back to me.
    President:
  • 2,961 Answers
It could be the graphics, but it is a process of illimination as always. When you boot your pc keep pressing F8 and see if it will boot into safe mode. When in safe mode select 'Last known good configuration' as this may cure the problem. If that doesn't work boot into safe mode again, but this time select start windows in safe mode, if this works ok then it maybe a driver problem, probably either the wireless card or graphics, try uninstalling the graphics driver first in add/remove programmes. Restart the pc and windows should find it again and install the driver, if on the next restart the problem returns then it is the graphics driver so download a later version from the acer web site.
Posted on Mar 17, 2007
SOURCE:
( Dell xps m1530 laptop ) Monitor blank, powers up but screen won't come on.
It ISN'T the LCD screen. Since you diagnosed with an external VGA monitor, you now know the problem is the laptop.
(When you connect an external VGA monitor to a laptop, you are bypassing the Video Cable, and LCD screen. You are connected directly to the laptop )
The basic Windows files aren't being found. The boot files. This may mean a bad Harddrive.
Do you have the Restoration CD Disk? Laptop on insert it into the optical drive tray, close the tray.
When asked choose - Repair. (Non-Destructive Installation)
If a checkdisk is done, you have bad sectors on the harddrive.
There IS a special procedure in replacing a harddrive.
[ More information on Harddrives,
http://computer.howstuffworks.com/hard-disk.htm ]
Regards,
joecoolvette
Feb 26, 2012 | Dell XPS M1530 Laptop
Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Jul 16, 2011 | Toshiba Computers & Internet
Dell Inspiron 1525 laptop, no power light, battery light flash orange, wifi light flash blue and orange I bought the Dell Inspiron 1525 laptop in 2008. I use the laptop as a desktop, so I never plugged...
Since it sounds like an issue with the Power first try to release flea power.Disconnect the charger,remove battery,press and hold down the power button for 30 seconds.Reconnect the battery and charger.Turn on system and check if it turns on. For further help please check Dell Inspiron 1525 Manual. Also confirm if the light on the charger stays on,when connected to the system.
Mar 06, 2017 | Dell Inspiron 1525 Notebook
My Toshiba laptop battery light flashes 6 times but wont turn on? Dead battery?
Most laptop battery can be normal used in 400-500 charge and discharge cycles, in another word, a laptop battery should be normal in 2 year.
maybe your laptop battery is dead....
you should buy a new one.
here is the replacement toshiba laptop battery online shop for you to consider to buy one there:)
May 23, 2010 | Toshiba Satellite A205-S4617 Notebook
Dell 1525 lights flash when power button is pushed but no
Even if the hard drive is bad you should still see the normal bios post screens and then an error message saying "no boot device found" or something similar. If you have a monitor in your home you should attach the vga cable from it onto the vga connection on that laptop. Then turn on the laptop and see if you get a picture on that monitor. If you do then either the laptop lcd inverter is bad or the lcd itself is bad. If you don't get a picture you may have to press a toggle button or buttons on the laptop to switch to the external lcd. Usually this is Fn plus another F button on the top.
Feb 07, 2010 | Dell Inspiron 1525 Notebook
My laptop does not start again. what is my laptop problem?.
Are you trying to start it on battery power, or is it plugged in?
Do you see any lights light or flash?
Do you hear any noise, such as the harddrive spinning up?
Jul 10, 2009 | Computers & Internet
Replace hard drive on Gateway laptop
get a New 2.5'' laptop hardrive, and follow the steps: - Turn off the Laptop - Take off the Power Supply - Remove the Battery - Remove the Screw from the Harddrive cover plate - Once cover removed,romove the other (2) screws that hold the harddrive - Slide the Harddrive toward the Screw Hole - Lift the Connection End. - Slide the New Harddrive towards the connection end, Put back the Screws & cover plate - install a new copy of Operating System.
hope this is helpful 'suraj'
Oct 10, 2008 | Computers & Internet
My TOSHIBA laptop won't turn on
flashing three times means something physically wrong with ur laptop. could be fault with ur power supply, Hard drive or ram.
- with the battery, plug in ur power supply and check if ur LED is glowing and the laptop is charging well.
if the problem persists,
- reset the RAM and the Hard drive, [ for this take out the ram and Hard drive and put them back again].
if still the problem persists, take it to repair. ---------------------------------------------------------------------------------------------- u dont have to worry bout the backup in ur laptop. a simple solution would be to get a 2.5 inch hard drive enclosure, install ur harddrive into that, connect it to a different computer and back it up!, but be sure what type of Harddrive u have , is it a IDE harddrive or a SATA harddrive.
cheers suraj
It won't turn on!
Could be a power board problem. Anyone home at that time alone, possible internal damage due to spillage???? Pull harddrive, reseat memory and pull battery and try again.
Jul 05, 2008 | Gateway MT3705 Notebook
Zd8000 Trouble...Again (power)
a lot of the zd 8000 overheat and turn off, mine constantly does this on hot days of i i dont have enough airflow under my laptop. Also Hp just released a recall for the zd8000 batteries which i just ordered today. I was notified through my email so check yours too
Mar 20, 2008 | HP Pavilion zd8000 Notebook
Acer Aspire 5003WLMi Notebook Logo
104 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
