Question about Bissell SpotBot Robotic Wet/Dry Vacuum
I need a new pump for my spot bot
I took my spot bot apart and found the pump wasn't working. I need a new pump for my spot bot where can I find one!!!
  • veggiegurl Feb 02, 2009
    I need a new pump too!
  • Anonymous Feb 13, 2009
    SAme problem. It says it is an Invensys product, an Italin company
2 Suggested Answers
  • 52 Answers
SOURCE: Need a Bissell Spot Bot Manual
You'll find manuals for several Spot Bots at the link below. There should be any significant differences among the models.
Posted on May 19, 2010
My Bissell Spotbot Pet cleaner stopped working. Took it out of the closet, plugged it in, No power? It worked great the last time it was used.
Well, if cycling it manually doesn't work and replacing the controller board didn't make a difference did you check the flex hose sensor? Bots won't run unless everything is clicked into place.
"Testimonials" don't continue the thread :)
I managed to dig up a copy of the service guide since I haven't owned a spotbot in years.
Mar 22, 2017 | Bissell SpotBot Pet Spot Cleaner
How To Replace The Hose On A Bissell Spot Bot, SpotBot, and Little Green...
Replacing the Suction Hose on a Bissell SpotBot can be a challenging repair. We frequently get this question, how do you remove the old hose, so we decided to shoot a video repair demonstration on how to replace the hose assembly.
This repair works for all Bissell SpotBot models in the 1200 Series, as well as the 7887, and some Little Green Machines.
If you need to purchase a new Hose Assembly, you may find it on our website below:Bissell SpotBot Hose Assembly Part 203-6665
Here's the video showing how to replace the hose:
Please feel free to email us with any questions or clarification requests, and please be so kind and rate the video helpful if you found it to be.
Thanks so much,
Chris JonesGoVacuum
on Jul 26, 2011 | Bissell 12005 Spot Bot Handheld Vacuum
Spot Bot wont spray
Not having the machine spray when you need it is frustrating.
Here's a quick link to troubleshooting steps to assist you.
Feb 15, 2013 | Bissell 12005 Spot Bot Handheld Vacuum
Spot Bot leaves mold rings
Hey, the mold ring is showing the carpet is now clean in comparison to the rest of the room.
You may want to have the rest of the carpet cleaned using a BISSELL deep cleaning machine or by calling a professional.
Jan 27, 2013 | Bissell 12005 Spot Bot Handheld Vacuum
I need an instruction manual or booklet
I could not find a model 12005 but I did find a 1200. You'll find several different manuals for Spot Bots at the link below. There should not be any significant differences among the Spot Bot models.
May 18, 2010 | Bissell 12005 Spot Bot Handheld Vacuum
May 18, 2010 | Bissell SpotBot Hands-Free Compact Deep...
The cleaning solution on my bissell spot bot is not being pumped through....on the stationary mode or the manuel hand held mode with the brush attachment
I had the same problem, and found that the culprit was that the small filter element. about the size of a dime, that sits arount the nozzle activator (pin that depresses the clean water nozzel) was clogged with "gunk", and prevented cleaning solution from flowing into the unit.. It is easy to remove with a pair of tweezers or needle nose pliars.. rise it under water and reseat in the unit. You shoudl be aboe to perform the whole process in under a minute. This has happend to me several times... and am surprised the filter is not mentioned in the manual.
Nov 07, 2009 | Bissell 12005 Spot Bot Handheld Vacuum
SpotBot: Brushed do not rotate
I had the same problem everything worked except the brushes wouldn't move. I took the top off and tested the leads to the motor and it wasn't getting any power. So I took the power board out and traced it to a large ceramic 5 watt 1.5 ohm resistor right in the middle of the board. I got a replacement resistor from a local electronic store and soldered it in. So for less than a dollar its working perfectly again. Also I put some electical tape over the speaker to quiet it down. It seems funny to have a very very loud beep to tell you when a very loud machine is done.
Apr 13, 2008 | Bissell SpotBot Robotic Wet/Dry Vacuum
Spotbot is leaking...
Mine constantly leaked as well but I found that if I remove the container will the solution in it after every use it doesn't leak anymore. I store my container (upright - nozzle face up) under the sink with my other cleaning products and when I need to use the machine I pull it back out, pop it in and clean.
Dec 28, 2007 | Bissell SpotBot Robotic Wet/Dry Vacuum
Trouble with Spotbot
My problem wasn't a problem with a new unit. We have had ours over a year and it has been flawless up until a few days ago. Ours stopped pumping cleaner for both the manual hose and the automatic section. Other solutions of priming the pump described make sense, but that was not my problem. When I would press the manual hose button a very short squirt of liquid would occur and then nothing. When I looked at the receptacle for the cleaner tank on the Spot bot side, there was a gray fuzz in there. I tried cleaning that with an old toothbrush and it came right out. It was a filter of some sort. It was gray on one side, black on the other and about the size of a dime. I guess over time the filter has gotten clogged and didn't allow a full flow of liquid. I removed the filter and put the tank back in. The unit works perfectly. I am going to try to clean the filter, put it back in and see if the unit will work. If not, the filter is history.
Jan 14, 2007 | Bissell SpotBot Robotic Wet/Dry Vacuum
Bissell SpotBot Robotic Wet/Dry Vacuum Logo
115 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
