My Numark TT1625 and it's clicking sound
I just noticed my TT1625 makes a clicking sort of sound whenever it's is ON and i am queing or move the table in the reverse direction until it resumes a forward motion. Sound does not happen when table is off. I've taken the thing apart several times but can't find any evidence of anything touching or in the way or and wear in the bearing. Any ideas?
djproaudio
  • 515 Answers
SOURCE: my numark tt1625 turntables keep
If you could be a little more specific, we might be able to help you out better.
Does it slow down, when you do anything, or after a long period of time of being on/used? Or as soon as you turn it on, it slows down?
Any specific information would be greatly appreciated.
- Davis
DJ Pro Audio
www.djproaudio.com
Posted on Jul 15, 2008
djproaudio
  • 515 Answers
SOURCE: NUMARK TT 1625
Any of the following cartridges will fit your turntables:
CARTRIDGES @ 1200s.com
I don't suggest using the originals that came with the turntables, as they aren't of the greatest quality. For a small investment (about $50), you can get some better quality cartridges/needles.
- Davis
DJ Pro Audio
www.DJPROAUDIO.com
www.REPAIRNYC.com
djproaudio
  • 515 Answers
SOURCE: numark tt1625
These are direct drive turntables, so if your having speed issues, the problem is probably one of the drive circuits. Unfortunately, not an easy fix. So I suggest taking it to a service center for repair.
- Davis
DJ Pro Audio
www.djproaudio.com
www.repairnyc.com
www.1200s.com
Posted on Jul 23, 2008
djproaudio
  • 515 Answers
SOURCE: numark tt1625 keeps on jumping
If your weight and such are correctly set, then the only other issue might be a worn stylus, or your tonearm might be damaged.
- Davis
We are the Turntable Experts!
DIGITAL ANALOG THERAPY
Posted on Aug 10, 2008
rockdiarylv
  • 27 Answers
SOURCE: numark tt1625 speed issue
hi nikki,
when you say ages to get back to speed how long is that exactly? even on my technics for cueing i give a slight throw to hit my cue points.
also your slip mat may be an issue. do not use the rubber mats use the soft nylon foam one that came with it only.
Posted on Feb 27, 2009
My numark tt1625 blew a fuse,have changed fuse ,but wou'nt turn on now,no red light, any ideas,thanks
Fuses blow when there's an overload. Mostly caused by a semi-conductor device that shorted out. If it's a transistor or diode it will be easy to spot with an Ohm meter as touching the terminals will be just like you have touched the two test probes together!
Aug 17, 2013 | Numark BATTLE PAK v.4 Turntable
How do I get my sound from my Numark TT1625 to play through my DVD/CD speakers?
You need a magnetic cartridge preamp. You then plug your turntable into it and the box into the CD/aux imput of your amp.
May 21, 2010 | Numark TT1650 Turntable
My tables (tt1625) slow down after about 20 min of play, or 10 min harder scratching.The sound quality is still great but I really want to scratch more.What can I do?
i wish i could help, it seems no-one can answer this, ive just scowered the internet, coz i got the same problem, but nothing! probly just need a new motor! sounds expensive
Jan 19, 2010 | Numark BATTLE PAK v.4 Turntable
When I scratch with my numark tt1625 its very slow to spin again
Try Changing The Slipmats Gemini Slipmats Are More Slippery Than Standard Numarks I Use ThudRumble Frosted Plates In Place Of My
Original SlipMats On My 1650's
I'm having problems setting up my numark tt1625 turntables with the mixer. I can't hear any sound even with volume on full. do I need an amp or is the equipment broken?
Double-click the Volume Control icon (beside your computer's clock, on the System Tray) to open the "mixer". Ensure that you have no "sliders" that have been set to "zero" ("no sound").
Connect the turntable-output to the "blue" (audio-in) socket on your computer's sound-card.
If you get no sound, move the connector to the "pink" (microphone-in) socket on the computer's sound-card, and try again.
Nov 26, 2009 | Nu Mark Numark (CD2CD) CD-RW Burner
Numark tt1625 turntable wavey sound
Your belt is probably worn and needs replacing. Lift felt on platter and and lift the platter section off the unit by putting your thumb and forefinger through the two large holes and pull upwards.There should not be any special routing for the belt and should go directly onto the spindle motor to your platter. Place the belt around the inside rim of the platter while it is still off the unit. Now replace the platter and move the platter around until you see the spindle motor through one of the holes. Use some tweezers to manouvre the belt onto the spindle motor. On some units you will have to lay the belt out inside the unit, replace the platter and manouvre the belt onto the platter. Hope this helps
May 28, 2009 | Numark BATTLE PAK v.4 Turntable
Numark tt1625 speed issue
hi nikki,
Feb 27, 2009 | Numark BATTLE PAK v.4 Turntable
Numark tt1625 keeps on jumping
- Davis
Aug 08, 2008 | Numark Audio Players & Recorders
My numark tt1625 turntables keep slowing down
- Davis
DJ Pro Audio
www.djproaudio.com
Jul 14, 2008 | Numark BATTLE PAK v.4 Turntable
NUMARK TT 1625
- Davis
DJ Pro Audio
www.DJPROAUDIO.com
www.REPAIRNYC.com
Apr 22, 2008 | Numark BATTLE PAK v.4 Turntable
104 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
