Question about Refrigerators
Water leak under fridge, probably due to defrost cycle. Fridge model is TFG 20 JAWW
    President:
  • Refrigerators Master
  • 2,651 Answers
Sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Posted on Dec 15, 2008
It keeps running and is not cooling good enough, what can I do to fix it? I don't have the money to pay some one to do it, PLEASE HELP!!!!!
Hi Don,
Without a brand model number - specific help will be impossible.
These are the things I suggest - but cant tell you exactly where the parts are located or how to access them. Try vacuuming dust and dirt from the condenser coils on the back or under side of the fridge.
If the freezer is getting warm too - the cooling coils behind the back wall may be clogged with ice due to a defective defrost circuit timer, heater or temperature sensor.
I do not know your skill set - so I suggest simply transferring the contents of the fridge and freezer to another and then unplugging the fridge and allow to defrost for 24 hours. Stuff some towels on the floor of the freezer and fresh food compartments to wick up water from melting ice.
After defrosting, plug into power again. It should cool down quickly if empty. Monitor temperature and cycling of the compressor. Expect it to turn on and off with temperature rising and falling inside. If it continues to run non-stop you probably have a refrigerant leak and are now undercharged. Many fridges aren't designed to be recharged (but can be if you want to pay for a charge port to be soldered in the suction line) so it may or may not be worth your while pursuing repair (depending on age, etc.) when used fridges can be had on craigslist, yard sale sites, etc. often times for under $100.
If it cycles on and off you probably have a defrost issue. The fridge will work well but - will gradually start doing this again. You can handle the problem like this, buy another fridge, or delve into troubleshooting the defrost circuit. Come back here with your findings and make and model fridge and we can step through the process then.
Nov 09, 2015 | Refrigerators
My fridge model CTF2123AR leaks water under bottom pull drawer. this pools water on the floor
Water found under the tray is due to excess defrost specially when the fridge is set to a lower temperature due to heavy frosting.
So during defrosting the excess water flows into the tray and overflows out which incidently has flooded on the floor.
What could be done is to drain off the tank, fully defrost the fridge by shutting down for few hours and then setting the fridge/freezer to a normal temperature.
Jul 13, 2011 | Magic Chef Refrigerators
GLRT216TAW2 Model Number. Water under vegetable drawers, No other water leaking. Back is dry, Do i need a repair man or new refrig which is only 10 yrs old.
Its the defrost problem.In your unit the defrost cycle is not running on time.This is the procedure of the unit.--- The compressor starts then it cools the freezer section. When the freezer reaches its cooling level the defrost cycle starts functioning. In this cycle the fan in the freezer section starts running and the cool air in the freezer section is passed to the fridge section and the fridge section gets cold. The air from freezer to fridge passes from the section, in that section the damper is located.In your case the freezer gets cold, after that defrost cycle has to start, but in your case the defrost cycle is not starting on time so over ice gets internally build and when defrost cycle starts, this ice melts and this gets leaks in the vegetable and under vegetable drawer.-------- Get the defrost timer, and defrost assembly parts checked and repaired by the technician.Repairing will solve the problem.You can get required parts from from online sites like: --- www.repairclinic.com or from searspartsdirect online site. --------- This should help.Thanks.Helpmech.
May 04, 2011 | Frigidaire GLRT216TA Top Freezer...
Water leaks inside
It's due to wrong temp setting and malfunction of defrost cycling. Keep thermostat setting at 5 degree or little less. And don't keep it in minus,as defrost cycle will take longer time. And also you will get less cooling in fridge compartment and also water leaks.Check drain line hose may freezed. And also freezer tray get blocked due to over frosting around freezer. Defrost manually by unplug your fridge and after defrost all ices, plug again and keep correct temp setting. Thanks.
Feb 01, 2011 | Whirlpool 21.0 Cu. Ft. Frost-Free...
Rs2556sh model leakes water under fridge when ice maker cycles
If there was water in the water line it could have split. Check on the back where the water line goes from the inlet valve to the ice maker.
Oct 01, 2009 | Samsung RS2630SH Side by Side Refrigerator
I have a maytag refrigerator model# msd2456gew the freezer side water is freezing at the bottom of the freezer is there a leak
That is probably from your defrost cycle. Every 10 hours or so your fridge will run a defrost cycle and drain the water under the fridge into a pan. Your drain is probably clogged up or has ice over it. You will have to clean or defrost the drain.
Sep 13, 2009 | Refrigerators
We have a Kenmore Coldspot Model 106 70102000 with the water and ice maker, it is now leaking inside the fridge itself and we have turned the water off to the ice maker and dispenser. What is causing the...
It is probably your defrost cycle causing this. Obviously if you shut the water line off then it is not coming from there so there is only 1 other place it could be. Every 8, 10, or 12 hours depending on you defrost timer the refrigerator will defrost itself.......the frost melts into water and drains into a pan under the fridge. If the drain is plugged then it will just run into the refrigerator. If you have a freezer on top model then just remove the back wall inside the freezer, it will be a few 1/4 inch screws....If you have an icemaker then remove that too, it will be held on with 3 screws. Just look behind that wall and you will probably see ice at the bottom.....defrost the ice and pour a cup or 2 of water into the drain to make sure it is unclogged. If it is still plugged up then you have to find the clog....either in the back of the fridge behind the lower cover or in the refrig compartment near the back of the roof.
Sep 11, 2009 | Kenmore Refrigerators
Water periodically comes from the underside of refrigerator
This is probably water resulting from the defrost cycle. Normally the water drips into a pan under the fridge and evaporates. You probably have a leak in the drip pan.
May 04, 2009 | Refrigerators
Lickage of water from frost free fridge
actually a frost free fridge should leak water but it should not make it to your floor. every frost free fridge goes into defrost every 8 hours for 15 minutes where it will melt the ice off the coils. there is a pan underneath the fridge to catch this water. it should evaporate before the next defrost cycle there is not much water that comes out. you may want to pull the front cover and look under the fridge make sure the pan is in place and there is not a crack in it
Apr 27, 2009 | Refrigerators
Leaking fridge
my maytag had cloged defrost drain cleaned drain all ok
Oct 28, 2007 | Refrigerators
Refrigerators Logo
255 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
