Question about KitchenAid KERC508LSS Electric Kitchen Range
Replace cooktop I have a ceramic cook top on a KitchenAid range that is broken. How hard is that to replace? Do I need to buy new gaskets along with the cook top?
    President:
  • KitchenAid Master
  • 2,651 Answers
Looking at the part breakdown for this unit, doesnt appear to be much a of a problem in replacing the top, teh gasket should come with the new top if not there is one available for purchase, but looks as if all you need to do is remove the frame(look as if 2 screws in either rear corner will release this)afeter that the glass should lift right up simply replace with new and re-secure the screws, be gentile however the new glass can be fragile, so make sure ut fully sits flat in the spot before trying to tighten back into place
Posted on Dec 15, 2008
Range Ceramic Cooktop 1 burner not working
I would try replacing switch for that burner. But it also could be a defective burner.
Oct 20, 2017 | KitchenAid Kitchen Ranges
CRACKED GLASS GE - JB968
1 Unplug cooktop or disconnect power.
2. Remove the cooktop from its mounting
location, (see “Installation Instructions” in
Section 2). Position the cooktop so that
you can access the bracket screws below
the cooktop glass
3. Remove the fourteen flat-head screws
from the front, rear, and side ceramic glass
brackets.
4. Remove the two small side brackets from
the cooktop base.
5. Lift and remove the ceramic glass from the
Oct 13, 2008 | GE Profile JB968 Electric Kitchen Range
I have a Kitchenaid electric range Architect Series II. Seems every time I use the large burner on the right side there is some sort of residue left that is very hard to get off. I have already made a...
What are you using to clean the stove? Only cleaners made for ceran type tops should be used according to directions. Do not use enamel coated pans or glass pans on your cooktop.If you have a boil over, turn off the burner and change to a different burner immediately. Clean up the spill completely before cooking on that burner again. Use a flat edge razor to clean tough residue. Your cooktop will look new for years to come, even with heavy use.
As far as the scratch, don't use abrasive cleaners on the top and only use pots and pans with flat bottoms. If you do use cast iron pans, never scoot them around on the top.
Nov 30, 2009 | KitchenAid KESC307 Electric Kitchen Range
How do i replace my burner on my jenn air ceramic cook top . it has the down draft feature in the centre
1) turn off power at the breaker. 2) remove hold down screws 3) pop up cooktop out of counter top 4) remove knobs and downdraft grille 5) remove ceramic top (screws around outside and also in side grille opening) 6) unplug burners replace with new burner
Sep 17, 2009 | Jenn-Air JED8430 Electric Cooktop
Broken ceramic top
hi...no nid to replace the ceramic top,coz it is very expensive compare to buy a new one.the price of the glass ceramic top is mostly half or 3/4 of the actual price of the new one.much beter to buy an new one,get an new & the warranty but the glass is not covered in waranty for all brand.
Sep 10, 2009 | Cooktops
I have a whirlpool drop in ceramic stove and a burner isnt working. i had a repair man come and he was trying to pry the stove up but was having trouble because the person that insatlled it years ago...
When you dont replace the ceramic top that ios cracked could cause issues in your circuit board. The best thing t do is buy a new stove. The parts nad labor along is going to cost you about the same price as a new one.
Apr 25, 2009 | Stoves 23 in. Premier TC600I Electric...
Replacing the ceramic cooktop on my frigidaire slide in stove
there is no need of any instruction booklet for your problem, but a cooking range repair man.
He will replace it for you.
Mar 20, 2009 | Frigidaire 30" Self-Cleaning Slide-In...
REPLACE CRACKED GLASS COOK TOP
First of all, if the cook-top broke as a result of a manufacturer defect, the repairs should be covered under the manufacturer's warranty. In this case, the repairs would be done at no cost to you. If, however, the glass top was broken as a result of the consumer, the repair will not be covered (even if it is still under warranty). If this is the case, it does not require an engineer to replace a glass cook-top. It can be time consuming, though. If you are somewhat savvy with fixing things, it can be accomplished by the average do-it-yourselfer. The following link explains how to replace most glass cooktops:
http://www.fixya.com/support/r391448-replacing_glass_cook_top
The tedious part of replacing the cook-top is carefully removing and handling each burner element. These are usually ceramic and are very fragile. You must be handled with care. If there is no common disconnect, you also will be required to unplug each burner assembly one at a time and label the wires. A digital camera can come in very handy for this as well. The easiest way to do this is to remove the old shattered cook-top, first and lay it side by side with the new one. Remove and install one burner element at a time.
If you wish to pursue this and require additional assistance, please let me know before you rate the solution. I hope this helps you.
Jan 28, 2009 | Whirlpool GR773LXSS - Stainless Steel...
Glass cook top has cracked ...
They are expensive but not very hard to change if your carefull. They are about 300-400 on the norm , You may be able to get a new oven on sale for that much ,its up to you. Check with sears parts first. good luck
Dec 30, 2008 | LG Kitchen Ranges
Replace ceramic top on gas range
yes the part number that you need to order is 316251903
Apr 13, 2008 | Frigidaire FEF366 Electric Kitchen Range
KitchenAid KERC508LSS Electric Kitchen Range Logo
277 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Marvin
Marvin
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
