Not Detected HDD or CD
I have ASUS P5Q SE Iknow the conections are corect but,it not detect the harddrive and DVD rom.
    President:
  • 2,110 Answers
It seems that ur Cable might have some problem..pls change tha cable and check..
and also check the jumper setting backside of hard disk and cd rom for master and sleve...
Posted on Dec 15, 2008
Asus p5q se plus no sound
Hi sir/madam
First uninstall audio drivers which u installed.
Then download the drivers
Try this link from original site
https://www.asus.com/Motherboards/P5Q/HelpDesk_Download/
There download only audio drivers and install it..
If still not works , reply me
Sep 21, 2017 | ASUS P5Q SE PLUS Motherboard
Unable to boot internal devices? bug?
Did you go into the bios settings and check the status of the hard drive? it would seem that is where the problem lies.
Jul 06, 2012 | ASUS Computers & Internet
No detection of hdd or cd/dvd rom
try to delete upper and lower filters on the registry to make your cd/dvd properly working
Jun 24, 2010 | MSI K9MM-V Motherboard
My Gigabyte GA-945GZM-S2 motherboard is not detecting any CD/DVDROM attached to the ide port. it is also not detecting the rom in bios. cable and rom ate both working fine there have been tested on other...
IF THERE IS ANOTHER IDE PORT FOR A SECONDARY DRIVE i WOULD TRY TO SWITCH OVER TO IT . IF NOT THE MOBO MAY HAVE A PROBLEM WITH THE IDE PORT. VEIRFIED THAT THE DRIVES ARE CORRECT AND TRY TO CHANGE THE BOOT ORDER IN BIOS .
May 15, 2010 | Gigabyte GA-945GZM-S2 Motherboard
Asus P5KPL SE & Sata, Bios "Not Detected Problem"..
The Asus bios won't show SATA devices.
However if you are using Windows XP with Service Pack 2 (or newer operating system then the devices should be detected. If this is not happening then enter the bios -- Storage Configuration -- Configuration Enhanced and set the IDE devices to compatible. This allows all drives to be "seen" and you should then be able to load an OS.
Jan 22, 2010 | ASUS Computers & Internet
Hi all i have a asusp4p800 motherboard that was on and working till i shut it off to add more mem,and new video card,now when it boots up it wil stop at the asus bios screen unless i unplug the hard drive...
hallo friend
you should remove hdd ID cabals and after that hard disk jumper chak first jumper Hdd master and sacud jumper cd-rom jumper slave
so please chake hear
Aug 15, 2009 | ASUS Computers & Internet
Is it a bad mb ?
If the HDD is not recognized in the BIOS, windows will not be able to install on that drive. Did you move the HDD interposer from the old drive to the new one? (t is a small adapter that plugs on to the pins of the drive.) If you did, reinstall the interposer on the old drive, ensure it still works. If neither drive functions, then you may have a bad motherboard.
0x0000007B normally occurs when you try to install an older version of WIndows XP on a system with a newer HDD controller and the XP CD doesn't have the correct driver for the HDD controller. So if you get an error like this after getting the HDD to be recognized by the bios, then you may need the HDD controller driver too.
Mar 21, 2009 | Dell Inspiron B130 Notebook
Asus P5VD2-VM SE don't detect sata hdd
What processor are u using & which OS have u installed? Try using WinXP_ServicePack-3.........sodeep
Mar 20, 2009 | ASUS P5VD2-VM SE - Motherboard - micro ATX...
ACER ASPIRE 5100 DVD/CD ROM IS NOT DETECTED IN BIOS?
do you get an error 200 yet ? i got one here that does the same thing and its a bad motherboard. tried to replace cd drive and harddrive and was no help
the motherboard cost to much and not worth the part and labor
Dec 04, 2008 | Computers & Internet
Problems Installing my 160 GB Seagate SATA HDD
Check the SATA/RAID controller setting. It could have been set to [Disabled] Refer to your user?s manual for a detailed description on how to enable the onboard SATA/RAID controller by adjusting the jumper or BIOS settings. Regards SparkGap
Sep 24, 2007 | ASUS P5RD1-VM Motherboard
Computers & Internet Logo
362 people viewed this question
David Payne
David Payne
