Sony rear projection light flashing 10 times
Hi there..
We have a sony KP-FX432M31 rear projection TV its no go. When turned ON TV on remote can hear channel noise from speaker for 3,4 second with out picture and a red LED in front of the TV flash 10 times could you please advise us what does it mean.
hope you can help me with this problem.
Regards,
Soman
  • 10,594 Answers
Please check my reply over here...
Posted on Dec 15, 2008
    Genius:
  • 1,199 Answers
The flashing is a repair code to tell the repairman where the problem area of the tv is !10 flashes means a power supply problem,I would have a repairman look at it because the problem lies in a high boltage area!
CAN ANYONE HELP i'm having a problem keeping the timer from going off and shutting the whole tv off. My kp-46wt510 sony widescreen from 2003 is doing the same thing, picture is bowed in the middle and...
Most likely you have turned on the sleep function. 2nd button from the left on the top of the remote hand unit. Keep pressing until "sleep off" appears on-screen.
Or
Timer in user's menu is activated to turn off TV a specific time. Go to timer menu and adjust timer, then push cancel on the remote, this should reset timer to zero. Same with current time, adjust and select cancel, this should reset current time.
If you do not have the original remote, you are in trouble. Service tech will have remote.
easyab
Feb 23, 2011 | Sony KP-46WT510 46" Rear Projection HDTV
We have a Sony rear projection TV (model KP/FX432M31) - it wont stay on. sure it is a timing issue as it will turn on at odd times all by itself but once we have turned it off we can not turn it back on...
The problem on your tv is the leaky electroltytic capacitor on the regulator section.
Replaced the capacitor on that area and your unit will be back to normal again.
If you don't have an experience in electronics find a qualified technician to do the job for you.
Have a nice day!
Thanks for using fixya.
JDVillanueva
Feb 03, 2011 | RCA F27450 27" TV
No picture ,standby flash 10 times and tv turns off
10 times standby flashing indicates problem of High Voltage Protection and need to check following parts in Sony KP-51WS520 rear projection tv.
Q8014 or Q8013 have shorted replace along with R8051 on D Board
IC8005 is damaged (D Board)
Hope these info will help you. If you have no experience of electronics stuff repair then local tv repairman is an option to get help.
Thanks.
Nov 27, 2010 | Sony KP-51WS520 51" Rear Projection...
Sony tv rear projection screen 10 blink
change the switch and check for bad connection, Job must be done by some one who has basic electronics background.
Jan 03, 2010 | Sony KP-FX532M91 TV
65" projection tv will turn on and shut off before picture comes
the service light is blinking because you in fact need a new bulb also is why u have no picture
Oct 06, 2009 | Sony KP-53V75 53" Rear Projection...
Sony KP-46WT520 Standby Blinks 10 Times
High voltage in TV got problem and thats why TV gives 10 time blink error code.
Qualified TV tech will fix it as its bit complicated fix.
Apr 15, 2009 | Sony KP-46WT520 46" Rear Projection...
With sound but no video only raster with vertical lines
The resistor (r9335) on the blue crt base board is open and burned thats why the 200v is missing. replacing the resistor will solve the problem. cheers!
Apr 08, 2009 | Sony KP-FX532M91 TV
Hello..i have a sony kp-61v80 tv year 2000
I have a sony codes for sony TVs that tell what is wrong by the blinks as soon as a can will ck it to see what it says.
Dec 03, 2008 | Sony KP-57WS500 57" Rear Projection...
10 flashing lights then 9
make sure it is 9 blinking it may be 10
Aug 15, 2008 | Sony KP-46WT520 46" Rear Projection...
Sony 57" rear prijection TV has a fast flashing light and will not turn on
turn on tv, after a few minutes picture goes black, but still have sound. red light blinks 5 times,turn set off same thing happens when you turn set back on. some times it want do it for 10 min.
Apr 25, 2008 | Sony KP-57WS500 57" Rear Projection...
Televison & Video Logo
174 people viewed this question
Top Televison & Video Experts
