Question about Brother IntelliFAX 560 Plain Paper Fax
Machine Error I keep getting a machine error 8A and can find nothing in the manual as far as I can see. Is there a solution to this error?
  • 3 more comments
  • Anonymous Nov 14, 2007
    I need to change the cartridge - help
  • pracha95 Feb 09, 2008
    I have the same problem. My machine is Brother MFC-210C. Can somebody help please?
  • Anonymous Sep 05, 2008
    Brother Fax 236: I am having same problem. How can i get rid from it?
    Thanks in advance.
  • Anonymous Oct 10, 2008
    MACHINE ERROR 8A OC 770
  • nverre Feb 03, 2009
    Error message 8A; what needs to be done??
checkitright
  • 1362 Answers
SOURCE: machine error 7C
here is the manual
http://www.retrevo.com/s/brother+4100+manual
Posted on Jan 16, 2008
  • 12 Answers
SOURCE: fax machine problem
This is the error :
8A- Wrong or weak contact of the recording head connectors.
The cost of repairing it would likely exceed the cost of a new machine.
Posted on Mar 28, 2008
leroyal
  • 2120 Answers
SOURCE: error message
Try lifting the document feeder to see if a switch actuator is held down.
Posted on Oct 26, 2008
  • 89 Answers
SOURCE: machine error 41
Very likely your print head is faulty. You can get it replaced or try the economical solution below.
I had the same problem after replacing the print head. I removed the ink cartridge and then unclip the two metal two clips by the side that hold the print head. Then I used WD40 to spray through the ink holes until the clear liquid comes out from the print head.Then I replaced everything back and start the cleanning process, do a few test prints. It works ok now, no more Machine Error 41. Therefore, sometime the problem might just be clogged pin heads!
Posted on Jun 24, 2010
  • 89 Answers
I keep getting the error code 211. the point is on the red mark at the sde of the machine and everything else in line. but when i start the machine the needles keep getting jammed in the hooks below.
Search for:
Make Model error 211
sometimes the owner's manual will contain information on error codes in the troubleshooting section.
Sounds like the machine may be out of time. Professional service may be required.
Jun 26, 2017 | Sewing Machines
I have a Brother HL-4070CDW printer and the display shows "Jam Tray 1 - Remove the jammed paper from Tray 1". We have followed ALL of the troubleshooting instructions from the Brother manual and...
hello, sorry to say that your machine will need the entire front door assembly, whats happening, is that the guide for paper feed, well it now has problem, so far the only way to fix it, is to replace this part, i have tried alot of temp. fixes, but only last a few days, and then it comes back, sometimes worse.
Oct 27, 2010 | Brother HL-4070CDW Printer
I have a Futura CE150 and error 19 keeps popping up but nothing seems to be wrong with the thread or bobbin thread
Jan 16, 2010 | Singer CE-100 Futura Computerized Sewing...
My Singer 7436 keeps getting an error code 88
I have been having the same thing happen. I just discovered the bobbin winder was in the wind position. I moved it and I am in business again! Hope it works for you!
Apr 11, 2009 | Singer 7436 - INGENUITY
Fax machine problem
This is the error :
Mar 17, 2008 | Brother IntelliFAX 1270E Plain Paper Fax
Canon NP-6035 persistent E002
e002 error normally indicates that the heater {fuser} is off
to clear that in most canon models there is a small press switch is to be activated to reset the error
at the rear right side of machine there is a small cover take it out and look for that small black button, press it while or immediately after switching the machine ON , switch OFF and ON again
if the error still exist may a real damage in fuser e.g. blown thermo fuse or lamp
Jan 25, 2008 | Office Equipment & Supplies
Will not run
I had the same problem with my machine, there is nothing you personally can do to fix it. You'll have to find a service tech who can work on it to solve the problem.
Dec 23, 2007 | White Sewing White 4400 Computerized...
Brother IntelliFAX 560 Plain Paper Fax Logo
189 people viewed this question
James Cagle
James Cagle
ctnozil
Victorman
Victorman
