Question about Philips DVDR980 DVD Recorder
Power on no response
Can someone please help. my philips dvdr980 shows ab fo 9214 error cord how can i solve this? thank you in advance
  • 944 Answers
Here is the link to the manual if you need it; http://www.p4c.philips.com/files/d/dvdr9... best i could come up with is: unplug machine, then plug it back in while holding down "open/close" and "stop" (Page 49) run through the diagnostics as explained on page 51. This link below gives you available drivers and updates, try updating/reinstalling the driver just in case it is a software issue; http://www.p4c.philips.com/cgi-bin/dcbin... If you still have no luck, please post again. Hope this helps :)
Posted on Mar 17, 2007
SOURCE:
Printer shows 83c00020 on the screen and I can't trun it off.
Unplug usb ,phone cord then power cord for a few seconds. While holding down the (OK) and (ON) buttons plug power cord back in. It should get you out of the error code screen. Then you should be able to do the number (6) and (#) button reset as found on HP site!
I hope this works for you.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jul 26, 2011 | HP Photosmart C6180 All-In-One InkJet...
DVDR980 DVD RECORDER
try to keep the recorder off for an hour
and then again turn it on
Apr 06, 2008 | Philips DVDR980 DVD Recorder
Hello. We have a Xerox 6110 that is printing fine, but all of a sudden, just stops and keeps showing this message: Deve home sensor error Please help. Many Thanks Melanie Golby
There is a problem in the fuser unit.
Unplug the power cord and plug it back.
If it continues:
Check the fuser , you may need to take it out and verify that it does not have paper debris stuck on or in it. If this does not fix it:
If it is under warranty, call support. If not, you need to replace the fuser.
Thanks, Joe
Feb 18, 2011 | Xerox Phaser 6110 Laser Printer
Error 5B00
Error 5B00 on Canon Pixma Solution:
  1. Turn on the machine
  2. Press MENU
  3. Press SCAN COPY SCAN to enter service mode
  4. USE > to got to NVRAM ACCESS
  5. Set ABS-M LEVEL to 0
  6. Set ABS-P LEVEL to 0
Thanks, Joe
  1. Press STOP to EXIT
Feb 18, 2011 | Office Equipment & Supplies
Am getting error 5b00 dont know what cause
Error 5B00 on Canon Pixma MP310 Solution:
  2. Press MENU
  7. Press STOP to EXIT
Thanks, Joe
Feb 03, 2011 | Canon PIXMA MX310 All-In-One Printer
Hello, my CANON MP500 gives error 5B00. Please help me!!!!!
Try this:
5b00 error
press MENU button, SCAN button, COPY button, SCAN button.
wait a minute.
it may be enter into special mode: service mode
(3) USE > to got to NVRAM ACCESS
(4) set ABS-M LEVEL to 0
(5) set ABS-P LEVEL to 0
(6) Press STOP to EXIT
Thanks, Joe
Jan 29, 2011 | Canon Office Equipment & Supplies
I have a kyocera FS-2000D with error code: Call for service 0150:0000049. Help...thanks in advance
Error code 0150 is an engine EEPROM communication error. The engine board might need to be replaced. I have heard that sometimes a defective developer unit could cause this same error code. I would try swaping a develper from a working FS-2000D first.
May 20, 2010 | Kyocera FS-2000D Laser Printer
Error message on my LCD
download proper firmware for your model from philips website and complete firmware upgrade. That should solve your problem.
Dec 03, 2009 | Philips 42PFL3603D/27 42 in. LCD TV
Philips AJ3040 suddenly shows error code 3040
Mine had the same problem but fixed it byh replacing the capacitors inside the alarm clock. It works like brand new now!
Apr 04, 2009 | Philips Audio Players & Recorders
Here is the link to the manual if you need it; http://www.p4c.philips.com/files/d/dvdr980_051/dvdr980_051_dfu_eng.pdf best i could come up with is: unplug machine, then plug it back in while holding down "open/close" and "stop" (Page 49) run through the diagnostics as explained on page 51. This link below gives you available drivers and updates, try updating/reinstalling the driver just in case it is a software issue; http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=GB&slg=ENG&sct=DVD_RECORDERS_SU_GB_CONSUMER&cat=DVD_HOME_THEATER_CA_GB_CONSUMER&grp=HOME_ENTERTAINMENT_GR_GB_CONSUMER&session=20070317090311_81.47.146.201&ctn=DVDR980/051&mid=Link_Software&hlt=Link_Software If you still have no luck, please post again. Hope this helps :)
Mar 17, 2007 | Philips DVDR980 DVD Recorder
Philips DVDR980 DVD Recorder Logo
81 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Steve Allison
Steve Allison
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
