Monitor won't turn on
My dell lcd monitor won't turn on. There are no lights. It's just dead. It worked fine until I moved, and had to disconnect everything.
I plugged in a different monitor which is working fine.
Is there anything I can do ?
Thanks for your help.
  • mrsb153 Dec 15, 2008
    Thanks for the responses. Dshack, unfortunately this monitor is well out of warranty.
    I will check out the fuse situation.
    Scholar:
  • 40 Answers
Depending on when you bought the monitor, and the warranty...
I would suggest contacting Dell for an RMA. If you bought it in-store it's possible they will let you RMA it. Also, if it is something simpler, it may be worth taking it in to a computer repair store and letting them take ten minutes to look at it. Most will not charge to simply look at something - if it's something they can't figure out, and thus cannot repair, you will need to contact Dell.
I would start searching for the papers that came with your computer, specifically warranty papers.
Posted on Dec 15, 2008
    Genius:
  • 1,226 Answers
If there is no power indicator to the monitor, then maybe please verify the inside fuse, maybe got busted. else consult the nearest repair center.
melnavz
My dell e173fp monitor has quit working. The power light continually blinks when power is applied, even without having to turn it on. An identical substitute monitor works fine on the computer system. ...
Is the power blinking amber? This is a DPMS power-save mode. With the computer disconnected and the monitor on, do you see the colored self-test block floating around? With the monitor on, computer connected, and you still have no image displayed, take a bright flashlight and examine the screen closely. If you can see a very dim display in the screen, the fluorescent tubes which light up the *background* and provide the vivid picture(sort of like a how an x-ray picture viewer works) are defective. The power light blinking may be the power supply sensing the non-functioning tubes or it could just be bad. If your display is under warranty, replace it. If not, trying to have the monitor repaired for this type of problem is almost as costly as a new one--and there won't be an active warranty on anything else that might fail. Hope I helped you.---Rick
Sep 10, 2009 | Dell E173FP 17" LCD Monitor
No power to Dell E173FPc monitor; power light doesn't come on
It sounds like you are not getting any power. I would try another power cord to see if it makes a difference.
Jun 16, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
Dell LCD TV won't turn on
check the cable who comes from the cpu
May 07, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
Monitor black screen prob
disconnect the monitor from the back of the system and see if u see the colour scheme or anything if u do see something that means monitor fine ... problem with system
Sep 19, 2008 | Dell E172FP 17" LCD Flat Panel Monitor
Dell Minitors has lost power
small cable to button/control lights may be disconnected
Sep 18, 2008 | Dell UltraSharp 2405FPW 24" Flat Panel LCD...
Dell E151FPb 15" LCD with power LED blinking.
The problem may be a loose connection. When I turn on my monitor, the green light blinks and a flickering white screen appears for a brief second every time. There must be a loose connection on the power board which may be causing this. The easiest solution is to tap at the back of the monitor. This will reconnect the loose end and the monitor will work fine until it gets disconnected again. I will open my monitor soon to find the real problem. But it will take some time to find it.
Aug 17, 2008 | Dell E151FPp 15" Flat Panel LCD Monitor
Dell monitor dead
If all your lights are on on the front on the 2000FP then the logic board is bad and the eeprom at49bv8192at will need to be replaced and reprogrammed. Check out www.lcdrepair.us for Instruction videos on the 2000fp as well as parts
http://www.lcdrepair.us/Installation.html
Nov 29, 2007 | Dell 2000FP 20.1" LCD Monitor
Dell E173FP 17" Monitor
I just had the same problem as well - mine happened during a windows update, related? Also, for me the monitor doesn't come one even after disconnecting from computer, nothing, just blinking green light.
Nov 04, 2007 | Dell E173FP 17" LCD Monitor
Half Dead Monitor
Dear
This problem is caused by keyboard switches which are bad quality they are easy to replace, so if you are able to work with solder you can finish replacement in 15min.
Good luck.
May 18, 2007 | Neovo F-417 17" LCD Monitor
Computers & Internet Logo
David Payne
David Payne
