Question about Philips DVDR980 DVD Recorder
Power on no response
Can someone please help. my dvdr980 shows ab fo 9214 error cord how can i solve this? thank you in advance
  • 944 Answers
Here is the link to the manual if you need it; http://www.p4c.philips.com/files/d/dvdr980_051/dvdr980_051_dfu_eng.pdf best i could come up with is: unplug machine, then plug it back in while holding down "open/close" and "stop" (Page 49) run through the diagnostics as explained on page 51. This link below gives you available drivers and updates, try updating/reinstalling the driver just in case it is a software issue; http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?scy=GB&slg=ENG&sct=DVD_RECORDERS_SU_GB_CONSUMER&cat=DVD_HOME_THEATER_CA_GB_CONSUMER&grp=HOME_ENTERTAINMENT_GR_GB_CONSUMER&session=20070317090311_81.47.146.201&ctn=DVDR980/051&mid=Link_Software&hlt=Link_Software If you still have no luck, please post again. Hope this helps :)
Posted on Mar 17, 2007
Printer shows 83c00020 on the screen and I can't trun it off.
Unplug usb ,phone cord then power cord for a few seconds. While holding down the (OK) and (ON) buttons plug power cord back in. It should get you out of the error code screen. Then you should be able to do the number (6) and (#) button reset as found on HP site!
I hope this works for you.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jul 26, 2011 | HP Photosmart C6180 All-In-One InkJet...
Hello. We have a Xerox 6110 that is printing fine, but all of a sudden, just stops and keeps showing this message: Deve home sensor error Please help. Many Thanks Melanie Golby
There is a problem in the fuser unit.
Unplug the power cord and plug it back.
If it continues:
Check the fuser , you may need to take it out and verify that it does not have paper debris stuck on or in it. If this does not fix it:
If it is under warranty, call support. If not, you need to replace the fuser.
Thanks, Joe
Feb 18, 2011 | Xerox Phaser 6110 Laser Printer
Error 5B00
Error 5B00 on Canon Pixma Solution:
  1. Turn on the machine
  2. Press MENU
  3. Press SCAN COPY SCAN to enter service mode
  4. USE > to got to NVRAM ACCESS
  5. Set ABS-M LEVEL to 0
  6. Set ABS-P LEVEL to 0
Thanks, Joe
  1. Press STOP to EXIT
Feb 18, 2011 | Office Equipment & Supplies
Am getting error 5b00 dont know what cause
Error 5B00 on Canon Pixma MP310 Solution:
  2. Press MENU
  7. Press STOP to EXIT
Thanks, Joe
Feb 03, 2011 | Canon PIXMA MX310 All-In-One Printer
Hello, my CANON MP500 gives error 5B00. Please help me!!!!!
Try this:
5b00 error
press MENU button, SCAN button, COPY button, SCAN button.
wait a minute.
it may be enter into special mode: service mode
(3) USE > to got to NVRAM ACCESS
(4) set ABS-M LEVEL to 0
(5) set ABS-P LEVEL to 0
(6) Press STOP to EXIT
Thanks, Joe
Jan 29, 2011 | Canon Office Equipment & Supplies
Error 5b00 occur how to solve it
Hey welcome to Fixya.
Error 5b00 means the waste ink counter is full, you need to reset it.
First of all to solve it you need to download PCM Service tool. Download it from Here
After downloading follow these instructions
Step 1
: Enter in service mode in order to used the re setter:
  • Turn off the printer without pulling the power cords.
  • Hold down Resume button and press Power button
  • Keep holding down Power button and let Resume button go
  • Then Press Resume button 5 times then let both buttons go
  • The Alternate Blinking error is gone, the printer is in Service Mode state
Step 2:
  • Extract the PCM servive tool resetter and then double click "servicetool.exe"
  • Click Reload Button and you will get a new USB port.
  • Load some papers in your printer and press the "Main" Button, wait until it shows "error 001" then press OK.
  • Then press "EEPROM" button and the printer will print some text, after that click OK
  • Then power off the printer (sometimes you have to press twice the power button to turn off) and turn on again.
  • You have done.
I hope this solution will helpful for you
Please don't forget to click on Four thumbs which are given below & then write testimonial in your words for appreciation if it is helpful
THANKS & Keep Using fixya
I have a kyocera FS-2000D with error code: Call for service 0150:0000049. Help...thanks in advance
Error code 0150 is an engine EEPROM communication error. The engine board might need to be replaced. I have heard that sometimes a defective developer unit could cause this same error code. I would try swaping a develper from a working FS-2000D first.
May 20, 2010 | Kyocera FS-2000D Laser Printer
F 6 ERROR
I think it is a fuser error on this model but cannot be sure if so replace fuser unit.
Thanks J
Oct 12, 2007 | Sharp FO 3800M All-In-One Laser Printer
Here is the link to the manual if you need it; http://www.p4c.philips.com/files/d/dvdr9... best i could come up with is: unplug machine, then plug it back in while holding down "open/close" and "stop" (Page 49) run through the diagnostics as explained on page 51. This link below gives you available drivers and updates, try updating/reinstalling the driver just in case it is a software issue; http://www.p4c.philips.com/cgi-bin/dcbin... If you still have no luck, please post again. Hope this helps :)
Mar 17, 2007 | Philips DVDR980 DVD Recorder
Monitor switching to standby - CV735 monitor with Presario 5000 series desktop
my compaq crt monitor not showing color. its shows only blue, green colors . u please tell me. what is the problem in.how to solve it.
is the monitor fault or any other.
Oct 30, 2006 | Compaq CV735 17" CRT Monitor
Philips DVDR980 DVD Recorder Logo
73 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
