Question about KitchenAid KHWS02RMT 3.7 Cu. Ft. Ensemble Front-Load Washer
Power to dishwasher
My dishwasher was working fine, now everytime i go to wash dishes the power kicks off in my kitchen when it gets to the wash cycle. I can rinse the dishes but I cannot run them through a full cycle.
    Habit-Forming:
    New Friend:
  • 70 Answers
17th Edition Multifunction Tester
Make electrical testing easier with a wide range of 17th edition multifunction testing accessories and ancillaries. Order your genuine tester, accessories Now!
Know more here: Accessories for 17th Edition Multifunction Testers
Posted on Nov 25, 2015
    President:
  • 2,692 Answers
Their is either a Short or an Electricial grounding taking place during the wash cycle. Don't take a chance on buring out your circuit  breaker in the house  panel box . Quit using it until the electricial problem is found.
Posted on Dec 15, 2008
My Bosch SuperSilent dish washer stopped halfway thru a wash cycle and now does not want to come on, yes the power supply is on.
1. No power to the dishwasher
Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced.
2. Door switch
Replace if defective.
3. Timer
Replace if defective (note: uncommon problem).
4. Selector switch
Replace if defective (note: uncommon problem). Dishwasher Repair Help Troubleshooting and Parts
Mar 29, 2015 | Bosch Washing Machines
I have a KitchenAid model KUDI01ILBT2. It was working fine until recently...The lights work fine, but when I push the start button it's delayed before it actually kicks on, and then it will...
sounds like you have a bad or clogged fill vavle,,you have water running to unit but not in unit,,,its still trying to dry dishes as if they wash...most dishwasher are hard wired to breaker and or not grounded,,,but only if you can shut of power pull dishwasher out remove water connection,,see if any **** is blocking vavle use flash lite if present...if so replace it..good luck you can not clean a dishwaser vavle..
Sep 03, 2011 | KitchenAid 24 in. KUDI01IL - Multiple...
Dishwasher racks squeak
WD 40 on the rack wheels and the tracks this will get rid of the squeak. cycle the dishwasher through a quick rinse b4 washing any dishes.
May 16, 2010 | Frigidaire 24 in. PLD2850 Built-in...
Can I take the bottom part of the dishwaher apart
Mkae sure you are running kitchen hot water faucet before starting dish washer. If not you are getting mostly a cold water wash thru out the cycle. Also make sure the jet dry dispenser is full. Always use the liquid jet dry as the small cubes you can get do not work nearly as well.
Jan 31, 2010 | Kenmore 15762 Dishwasher
Dishes dont get washed soap left on door something not right
Soundl like you're not getting water going into the dishwasher. Check out the water inlet valve.
Nov 19, 2009 | Whirlpool Dishwashers
Food particles are on dishes after washing
Try adding bicarb of soda/baking soda and vinegar in the detergent dispenser. Bicarb fizzes off hardened particles and vinegar strips off grease and aids rinsing.
Jan 26, 2009 | Maytag 24 in. PDB1420 Built-in Dishwasher
Dishwasher smells like pond scum
I have the SAME problem with our dishwasher. It's disgusting. Between the fishy glasses and the garlicky ice cubes (NO, we don't have garlic in our refrigerator or freezer -- purchased ice doesn't smell), I'm embarrassed to pour our guests a glass of ice water!
Jun 05, 2008 | KitchenAid 24 in. KUDI02IRBS Stainless...
Won't empty, does'nt wash well
Most likely your product is fine. However those little gel-packs r the worse on dishwashers they get stuck in the system and clog and ruin dishwashers I always recommend using powder it foams less and breaks down easier in the dishwasher. Also u might have a clogged or kinked drain line. If all is fine there it is possible your motor is locked up in that case make sure the dishwasher is off take off the bottom panel. Then reach under and find the fan blades on the motor turn them a few times to unlock it replace panel. U can also try a small amount of C.L.R to clear up any grime in the system.
Nov 07, 2007 | GE 24 in. GSD4000J Built-in Dishwasher
Poor/Uneven Wash Quality
there is a new product out that filters the water going into your dishwasher. it works great and my dishes look fantastic. they use to look dirty with a white film on them. after the first load when i hooked up the dishwasher filter my dishes looked brand new. it is affordable and works everytime. you can get it at www.dishwasherfilter.com.
Oct 11, 2007 | Kenmore 15529 Built-in Dishwasher
Washing Machines Logo
89 people viewed this question
Top KitchenAid Washing Machines Experts
kj henriksen
kj henriksen
gbob59
Mike
Are you a KitchenAid Washing Machine Expert? Answer questions, earn points and help others
