Computer tv-out (RCA) with no-color
I connected from my PC's tv-out (rca) to my the back of my small TV (rca - video-in). I only get black and white pictures. I changed to a new cable..no luck. Tried adjusting the TV setting to PAL, NTSC, AUTO... no luck. I even tried the TV's front sockets.. no luck. I then tried on a different TV, no luck. Later tried on the second set of video-in on this TV. It works! But the thing is I need to get the first small TV to work with color. Could someone please help?
SOURCE: Samsung CXD2512 TV/VCR Combo...Cannot hook up DVD player
We also don't have a remote. We hooked a DVD/VCR combo to the Samsung combo by attaching the cable from the cable line to the DVD player and an additional cable from DVD to TV and it used to work but after we lost the control, the DVD can only be listened to but not seen. The VHS from the DVD player works perfectly though.
When we had the remote (before connecting the other combo) we used line-in to see a DVD or VHS using the yellow red and white cables from the Samsung to the other player.
Posted on May 03, 2008
  • 28 Answers
SOURCE: blank and black image; sist. pal-m x ntsc
This TV can not be modified from NTSC to PAL.
Posted on Nov 16, 2008
SOURCE: Computer TV output (RCA) - no colour
I had the same problem and nothing worked for me until I changed laptop settings to NTSC_M
So, briefly what I have: S-Video to S-Video cable, laptop (Thinkpad R51, Windows XP, with Intel(R) extreme graphics controler ) and TV set (Samsung, quite old one). The problem was that after connecting my laptop S-Video (4 pin) with S-Video (4 pin) of my TV, I had black and white (no colour) picture.
Solution is the folowing:
- connect your laptop and TV (both S-video 4 pins)
- mouse right click on your laptop desktop screen
- in the popup menu select: 'Graphics Properties'
- "Output to"
- select "TV"
- properties "NTSC_M"
keep in mind that if your are not connected to TV, Graphics Properties don't show TV as an option. So, that was very confusing for me, as I saw similar solution somewhere but was not able to find NTSC_M settings on my laptop
Good luck
Posted on Jan 04, 2009
  • 2692 Answers
SOURCE: 17 yr. old 35" RCA loses color intermittently. Picture & sound ok
Three guns Red Blue and Green in the picture tube of an old CRT set. If one of the guns goes out it effects that color. Sounds like one of the guns inside of the tube is going out, To costly to replace for such an old antilog set that will have to have a convertor box next month anyway.
Posted on Jan 12, 2009
  • 213 Answers
SOURCE: Sharp 36 inch television-PAL to NTSC conversion
no.because it nota hdtv,
Posted on Feb 09, 2009
Connecting DVD player to spectre ledTV
It should be hooked up just like any other tv would be. The output of the DVD should match the input you're going to use on the tv. If you're going to use an HDMI connection then both units have to have HDMI connections. If not HDMI, then either composite connections (RCA plugs that are colored red, white and yellow). Each color go from and to the same color on each unit. You may also have an 'S' video (usually yellow colored). If you use this connection then don't use the RCA yellow connection. The S video connection has a better picture than the RCA connection. Either way, you still have to use the red & white (or black) RCA connections for the left & right audio. However, if you use the HDMI connector then you don't need the red & white audio connections because audio is already in the HDMI connection.
Aug 18, 2017 | Televison & Video
How to add an Exterior Speaker to Sony KV-13M10
Welcome to FixYa!
To add an exterior speaker to Sony KV-13M10, you have to have an AMPLIFIER.
  • At the back of your TV you will be able to see 3 RCA output namely = VHF/UHF, Audio and Video.
  • Use an RCA cable and connect to the Audio output.
  • At the back of your amplifier, connect the other end of the RCA cable to an RCA input labeled Audio - L (left, usually in white color).
  • Your speaker should be connected to your amplifier labeled output or audio out. The connection type depends on the make and model of your amplifier. The speaker wires usually come in red and black color. red goes to red, black goes to white.
A simple diagram will look like this:
TV audio out -------------> amplifier audio in (left, white color) amplifier audio out (left, white color) -----------> speaker (black wire) amplifier audio out (right, red color) ------------> speaker (red wire)
Thank you for using FixYa.
Have a great day.
Aug 26, 2011 | Sony KV-13M10 13" TV
For some reason anything I connect to the TV is only black and white. I tried both the Video connection on the side and in the rear of the TV. I know it's a color TV, so what could be wrong?
Tries another set of RCA component video cable to the tv cable out put holes.The RCA set of cable u are using now,the Yellow connection color wire that supported video,could be bad that why u not getting any colors video.
May 08, 2011 | TruTech T2000D TV
While streaming Netflix from my laptop (via S cable) to my RCA TV, the image on the TV is black & white. Whether streaming or not, when I hook up my laptop to the TV, the desktop image on my laptop...
If the cable is damaged then one of the pins can be bent inside or if it unscrews a solder connection may be undone. see the photo showing color on the left and bw on the right. Also plug everything in turn off everything then turn on the computer and then turn on tv. also try just opposite turn on tv and reboot computer.
Go to Bing homepage Video Wikipedia SVIDEO TV BLACK AND WHITE SCREEN Graphics Cards
Nov 12, 2017 | RCA F32649 32" TV
My dvd player only plays movies in black and white. When I watch tv, it's in color so I know its not the tv.
I suspect you may have connected a COMPOSITE cable (red/white/yellow RCA type) to the COMPONENT video input sockets on the back of the TV.
COMPONENT requires 3 RCA type video cables - the plugs and sockets are usually colour-coded red, green, and blue. COMPOSITE only uses one RCA type video cable - the plugs and sockets are usually colour-coded yellow.
If you connect the yellow video cable to one of the three component inputs you will get a black and white picture although you will still have audio if the red and white cables are correctly connected.
If you are using a COMPOSITE cable (red/white/yellow RCA type), please check your connections. Make sure you have not connected to any sockets - either on the TV or the back of the DVD player - under the heading of "COMPONENT" - or individually marked "Pr", "Cr", "Pb", "Cb" or "Y".
If you have verified that you are using the correct sockets on the TV and it still doesn't work or if you are using any other type of cable, please let me know which cable you are using and the model number of the TV and the DVD player. I will then be able to assist you further.
Regards,
BElectric
Jan 14, 2011 | Insignia DVD Player with MP3 Playback/JPEG...
Which accessories are a 'most have' for connecting my TV to a desktop pc?
You'll need:
•VGA cable
•S-Video Audio to 3 RCA Type Adapter Cable
•HDMI cable
•DVI cable
Check the connection options on your TV. If your TV has a VGA connection slot, plug the TV into the computer with a VGA cordlike a computer monitor. Connect one end of the VGA cable to the back of the computer and the other end to the TV. Switch between normal TV viewing to displaying your computer on your TV by selecting the proper mode from the remote control, some remotes will mark the proper mode as "VGA" while others will label it "Computer" or "PC."
Check the back of your computer to see if you have an S cable slot. Connect S cable portion of the S-Video Audio to 3 RCA Type Adapter Cable to the computer and plug in the green audio plug to the audio port of the PC. Plug the red white and yellow RCA cables into the matching colors of the RCA slots on the TV. With this method you will need to switch modes from TV to video.
Check the back of the computer and TV for either DVI or HDMI slots. The slots on your computer must match, you cannot connect a DVI to a HDMI. Plug one end of the corresponding cable into the the back of the TV and the other end into the computer. Choose the correct program mode, HDMI or DVI, from the remote to view the computer from the TV.
Aug 12, 2010 | Televison & Video
I am trying to connect an akai dvd player to directv, please help
ruettab,
good day. to connect your any DVD player to any TV screen always remember this color code
from DVD back part:
yellow = video out
red/blue/green( in a row) = component video out ( this can only be used for screen with component video inputs)
Black = digital audio ( rarely use unless)
Red and white (in a row) = Audio output (left and right audio)
where to connect from TV screen.
Locate where A/V INPUTS (audio/video socket) from your TV screen, you can see it either at the BACK/SIDE or somtimes in FRONT of TV screen , having marked as "AV1"AV2"AV3' .
Once you found TV input, you must first have RCA cable (color code cable to connect player to screen) then connect the RCA cable at the back of your DVD player, simply follow color code
RCA yellow marked cable = DVD yellow socket
RCA RED and WHITE marked cable = DVD RED and white socket (second row for your player)
then connect the other end of the RCA cable to TV screen, first select which input where you gonna place the DVD player ( either AV1, Av2 or Av3 if do have multiple inputs)
once decided which INPUT to connect the player.
ex. if you select AV1 as input there would be 3socket on its row (yellow/red/white)
now connect the other end of RCA cable to the screen by following the same color code:
RCA yellow cable = TV screen A/V1 input yellow socket
RCA RED and White = TV screen A/V1 input red and white socket.
cheers,
mark
Jan 31, 2009 | Akai DVD-3850S DVD Player
- "Output to"
- select "TV"
Good luck
Dec 15, 2008 | Computers & Internet
Color to black and white and back again
Since you're using a composite cable (yellow RCA) that carries both luma (brightness) and chroma (color) information, it's not the cable that is the problem.
That means it's either the DVD player itself, or the TV. If you have another video device (VCR, etc) that you can connect to the TV, try that. If the other device also goes from color to black and white, then it's your TV. Otherwise the problem is your DVD player.
Since your TV only has mono audio (white RCA, but no red) I would recommend getting a new TV if the TV is to blame.
Jun 13, 2008 | Sony DVP-NS57P
Televison & Video Logo
125 people viewed this question
Top Televison & Video Experts
