Question about Miele Touchtronic G892 Built-in Dishwasher
Do you have a meile g892 dishwasher? - Miele Touchtronic G892 Built-in Dishwasher
    Problem Solver:
  • 7 Answers
Yes,
a G892SC - for over 6 years now. It's so quiet that many a time I've opened the door to put something in it, only to discover it'd been running (rinsing, etc., not drying!) the whole time! Despite 3 years in the Army and lots of Rock concerts, I have no hearing loss ;-)
One year ago, the little orange plastic detergent lid latch broke. And considering how well-made the rest of the unit is, it was not as robust as the rest of the DW. I Emailed Miele, and they sent out a repairman who replaced the entire soap unit on the door for FREE, even though it was well out of warranty. You pay more, and you get more.
Brad Wolff
Posted on Jun 28, 2009
Hi, I have a Meile G892 that has the Intake/drain light coming on. The unit fills with water, then errors out. After trying to restart it, it does drain well so I know the drain might not be an issue. ...
Hi qkoz1 - theres afew things you can try- by intake/drain perhaps should be inlet/drain same thing..
Just be careful with the dangers involved with electricity......
Perhaps the pump is faulty however - the basis of operation is as it fills the pump engages. Theres a capacitor that drives the pump accessed from the right side - panels needs removal with torqx if you're unlucky. remove top either from side/front a bung screws there or front door open look up.
remove screws on top one rear bottom & along front with door open.
if it flashes at intervals then the flowrate unit is defective - need to be savvy to sort this one out.
if flashes continously then there possibly a blockage in the inlets - remove inspect filters.
one other thing - remove trays- steel mesh on bottom-locate the steel wire spring - deflect & pull housing upwards - this reveals the front of the pump - perhaps there some unpleasant surprises.
I can guide you to replace the flowrate - but the question is if you can obtain one. Miele supplies there agents/service contractors only as far as I know.
Jun 16, 2011 | Miele Touchtronic G892 Built-in Dishwasher
Miele G892 dishwasher stopped working. No lights at all. There is power from the outlet to the block behind the kick plate. According to manufacturer, there should be lights even with the door open so this...
This seems to be a failure of the main program controller unit.It needs to be confirmed that the unit received power, if so the controller is faulty.
Check if there is any fuse , check if there is line break to the unit.
Mar 12, 2011 | Miele Touchtronic G892 Built-in Dishwasher
Miele intake light on since new sink,disposal installed
check and see if the disposer drain port plug was removed. intake/drain light means slow drain or no drain
Feb 04, 2009 | Miele Touchtronic G892 Built-in Dishwasher
G892-SC Miele water intake/drain light blinks
The intake/drain light blinks. How do I fix this problem?
Aug 11, 2008 | Miele 24 in. G665 Built-in Dishwasher
Miele G892 SC Touchtronic
check drain pump impelar is free, it can be found under the non-return valve below filter. also make sure drain hose and S trap is clear.
Mar 29, 2008 | Miele 24 in. G638 Plus Free-standing...
Miele Touchtronic G892 SC Water leak at base of door
check the rubber seal around the door to see if its torn or smashed. if it is replace it, could someone have set somthing heavy on the door while it was open that would have stressed the hinges. it is most likely one of these problems take a nail file and slid it gently between the door and the body of the dishwasher if it slides in easy where it leaks you know the seal is bad and replace it.
Dec 09, 2007 | Miele Touchtronic G892 Built-in Dishwasher
Miele G892 SC dishwasher not heating/cycle won't stop
Miele have cold inlet only. Either element is open circuit, or the relay that switches the element has failed. My money would be on the element first, then the relay. The machine will sit in that mode forever as it is waiting for the temperature of the water to reach a certain temp before telling the electronic unit to move to the next part of the wash. If you need assistance in how to test & how to get to these parts just let me know. But you will need an ohm meter to test the element. Regards
Aug 20, 2007 | Miele Touchtronic G892 Built-in Dishwasher
Dishwasher ran with wrong soap
add some salt in the cabinet and a bit of water. salt acts as a foam suppressant
Feb 18, 2007 | Miele Touchtronic G892 Built-in Dishwasher
Miele Touchtronic G892 Built-in Dishwasher Logo
263 people viewed this question
Top Miele Dishwashers Experts
mpservices
Craig Butler
Craig Butler
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
