Question about Panasonic PT-51HX41 51" Rear Projection Television
Panansonic rear projection TV Convergence needed
The convergence I need is more in depth than the user manual covers. A tech came out and replaced the part that does the convergence and then went into a menu using the front control button and did a very intricate convergence. He decided it was taking too long and that I could live with the non covergence in HD mode. Now I would like to finish his job but doen't know how to access the detail menu.
Panasonic 47W rear projection. 5 years old.
  • 1 more comment
  • mtvandeman Dec 19, 2008
    Yes, I have the remote that came with the TV. If that's what it is called, then yes, it is the service menu I need to get into. The normal convergence through set up is not good enough, and I saw the service tech go into a deeper menu. He just didn't want to spend the time to complete a dull convergence.
    So, how do I get into the service menu, and what next?
    Thank you.
  • mtvandeman Jan 04, 2009
    Thankyou. That is exactly what I was looking for.
  • ladywinn
    ladywinn May 11, 2010
    Do you have hand unit that came with TV? you must have panasonic hand unit /none of those one for all units will work for setting convergences.Some sets when setting convergence to do it right can take up to 6-hours to correctly set all adjustments.So are you wanting information on getting into service menu?
  • Panasonic Master
  • 5,138 Answers
Go to this web site and Print out information on How To Enter Service Menu http://www.freelist.org/archives/techassist/09-2005/msg01111.html Read this very carefully when trying to get into service menu its no easy walk in the park, i hope i never have to set convergence on another myself. (1) Switch to cable (2) Set sleep timer 30min ,exit menu , now enter channel 124, Press vol- on tv ,at zero volume a Red Ck should appear , Re enter menu turn sleep timer off ,Now Press power untill you see oVoo using ch+ Adjust to OV1 ,now Press vol+ You should now be in convergences---- Mute locks- cursor to move- vol-&vol+/ch- ch+ to ajust lines---- Press R-Tune to switch color to adjust When done Press (7) to save then Press Then Press and hold power and action for 5 sec . GOOD LUCK.
Posted on Dec 24, 2008
  • ladywinn
    ladywinn Jan 04, 2009
    Website is under Techassist / archives. the one i posted was off of pages i printed out for how to enter convergences service menu.
I have Samsung SP42W5HF rear projection tv and
You have either a bad convergence IC on the power supply/convergence board or the whole board is bad and needs to be replaced along with doing a Full Convergence Alignment by a very experienced tech.
Apr 09, 2010 | Samsung Televison & Video
Convergence PROBLEM pHILLIPS mAGNAVOX 60" rEAR pROJECTION
All i can say is that this is very common.May be it is not the convergence circuit in this case. it is the power supply not giving the convergence circuit the power it needs to run. there are several parts that need to be repalced here.
Or may be the convergence amplifiers need to be replaced. They're on the Small Signal Board (the one with the tuner[s] on it) and the part on the amp's (there are two on them, replace both) start with STK and will be followed by some numbers and pssosibly letters, such as STK392-110.
Goodluck,
Please don't forget to rate the solution.
Apr 11, 2008 | Philips 60PP9202 60" Rear Projection...
What part do I need to replace to fix the convergence on my TV?
There are two big black ICs mounted with aluminum heat sink, these are convergence out chips, replace it with same numbers written on it to fix your tv problem.
Let me know if you have additional question.
Thanks.
Apr 05, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Convergence problem and cropped picture
your tv is under convergence problem usually we need to replace 2 big integrated circuits in the convergence section, at this point you may need a good tech to come over to your home
Nov 13, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Remote LOST - need info on what button to press...JVC AV-48WP30
There might be some features that the universal remotes aren't able to do. To perform the convergence alignment you should have the original remote.
Do you have the user manual or service manual?
The service manual will explain this process better.
Apr 10, 2008 | JVC AV-48WP30 48" Rear Projection...
Toshiba tv model # tp55h60
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Feb 04, 2008 | Toshiba TP55H60 55" Rear Projection...
Pioneer rear projection 51inch tv
moving big screens around may throw off the convergence, look to see if you have red,blue or green or all.. ghosts or edges in the picture. you will need a tech manual ..not owners manual to fix it, I would call a local tech and hear what he thinks for just a service charge. good luck
Sep 01, 2007 | Televison & Video
Convergence off on PT-47WX49E
If it's really bad and happened all at once, your convergence amps have failed would need to be replaced before you could correct the issue with an adjustment.
May 22, 2007 | Panasonic PT-47WX49 47" Rear Projection...
Power comes on then goes back off.
More than likely, the two convergence IC's have to be replaced.
Jan 28, 2007 | Panasonic PT-53WX53 53" Rear Projection...
Panasonic PT-51HX41 51" Rear Projection Television Logo
108 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
