Question about Mitsubishi WS-65513 65" Rear Projection HDTV
Mitsubishi DM fix
Would you mind sending the step by step to snowdowggy@aol.com?
Thanks
    Sergeant:
  • 233 Answers
CobJones... It is on it's way!
Posted on Dec 20, 2008
Green light flashing
The WS65813 is the V23++ series. The blinking led means the DM caps have failed you can get the V23 DM repair kit at the following link which contains the replacement capacitors and step by step instructions with pictures so you can do the repair. Heres the link its listed under the repair kits category.
http://servicemanuals.vstore.ca/
Feb 16, 2009 | Mitsubishi WS-65813 65" Rear Projection...
Blink green light of death - mits ws55613
you can get the repair kit which contains the replacement capacitors and the CD which includes detailed photos that show and explain how to do the repair, and the cD even contains the full service manual with full schematics manual as a bonus. Heres the link to the proper DM kit for your model.your model is the V23 chassis.
http://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-v23-dm-repair-kit/cName/repair-kits
Jan 24, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Green flashing light and tv will not turn on
that is usually repaired by replacing the DM capacitors. You can get the V21/ V19 DM repair kit at the following link which contains the replacement capacitors and step by step instructions with pictures on cd so you can easoally do the repair yourself. Heres the link its listed under the repair kit category as the V21/V19 DM repair Kit.
Sep 27, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Constant green blinking light Mitsubishi tv WS-65513
You can get the V23 DM repair kit at the following link which has the replacement capacitors and the instalation instructions on Cd which has pictures of the repair. Its listed under the repair kit category.
Aug 29, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi 65513 Blinking Green Light
Aug 25, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Need a repair solution e-mailed
Good Day, jnjetsn;
This a very common problem with model. Don't listen to other comments unless the use the correct replacement parts.
SYMPTOM: Power LED does not stop blinking after plug in.
CURE: replace C9B01, C9B02,C9B10, and C9B11 (1000 uFD 16V) on the DM PCB. Replace them with part # 181P734030 (680uFd 16V).
The DM Board (PCB) is located on the very left side of the TV looking from back. Caution on removing Board and note what cables you disconnect to access the Metal Shielded Board.
Good Luck, big IRISH.
Jul 13, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WS-65513 Flashing green light
Good Day, charliek1;
Jul 10, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WS-65513 Green Blinking LED Fix Request
you can obtain the service manual at the following link they email it to you and you will recieve free support and if you request they will send you the step by step proceedure for the DM repair through their tech support program. This is all free when you purchase a service manual. You would need the VZ23 series mitsubishi manual. Here is the link.
Apr 02, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi fix.....
http://www.chrisandnat.com/Projects/BlinkingTV/blink.htm
http://www.jeremyburns.com/Mitsubishi-Green-Blinking-Light-Fix.pdf
http://www.fixya.com/howto/h159332-mitsubishi_dm_board_repair
http://hdtvoice.com/voice/showthread.php?t=32186
replace DM
Picture of bad caps
http://www.auctioncreations.com/wd62525a.JPG
The DM board is the one with the digital connectors on the back panel. If you already have it appart, you may as well check the caps on all of the boards. The caps that go bad are typically Jamicon brand caps in 1000 uF and 330 uF values. There are also a couple of 3300 uF caps in the PS that cause problems.
Jan 13, 2008 | Mitsubishi WS-55513 55" Rear Projection...
WD-52725 Timer light is blinking and will not stop.
This part will cost you about 650 to 800 bucks my friend. if you have any soldering skills, and can follow directions, I posted a DM board fix. it may just be four small capacitors. Now this set that was used in the fix is not exactly like all the other Mitsubishi TV sets that still have a DM board, but if you can locate the DM board, follow the rest of the repair. if you do not know how to solder, do not take a chance, as this part is way too expensive to be experimenting around with. Get the Capcitors(there is a link there too for the capacitors)and take the DM board to a service shop, as this should not cost you a lot to have a pro do this for you. The DM board fix is located here: http://www.fixya.com/howto/h154057-mitsubishi_dm_board_repair Good luck
May 27, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WS-65513 65" Rear Projection HDTV Logo
20 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
