HP G62144DX Laptop Logo
Posted on Jul 30, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Hp G62 laptop.. From last 3 months, i am getting this error message.. Consider replacing your battery... Tell me some solution..Thanx
Banjade
Level 3:
  • Master 430 Answers
  • Posted on Jul 30, 2012
Banjade
Master
Level 3:
Answers
430
Questions
Helped
88092
Points
1382
Here is the Software through which you can check your battery life.
ftp://hp.com/pub/softpaq/sp54001-54500/sp54256.exe
If this software tell you that you need to replace your battery then you can't do anything other then changing it with new one.
Best of Luck.
4 Related Answers
Anonymous
  • 121 Answers
  • Posted on Nov 16, 2007
SOURCE: unable to log in hp compaq persario laptop
get to the mainboard
there is a jumper near the cmos battery usually shows the
word (jbat) near it , try to change its position for some
seconds while power is off , this way will clear cmos and set the
mainboard bios to default settings.
start the system hit delete or F2 to enter setup then exit saving changes.
Chuy505
  • Posted on May 04, 2008
SOURCE: lap top battery dead?
Probably the extreme heat and dryness out there drained it out, and or not being able to recharge it to full capacity. Did you charge it the recommended hours to charge when first used as stated in the manual the battery?. If you have access to a freezer put the battery in a ziploc bag seal and leave in the freezer overnight then take out and charge your battery overnight it might come back to life and hold it's charge once again.
Anonymous
  • 100 Answers
  • Posted on May 27, 2009
SOURCE: message that battery needs replacing last week but it was still going
Remove the battery and ac adaptor. also remove any peripherals.
Make sure that ac adaptor is working ok
Then press power button and hold that for 20 seconds to statically discharge the notebook. Then plugge that into the mains (without battery) and try to turn on. IF Notebook will not boot. Call service as mainbord needs to be replaced.
Anonymous
  • 1116 Answers
  • Posted on Jun 08, 2011
SOURCE: I did not get a
Without know your exact model (real model number) here is the manual for the unit closest to your model. If you provide the model number off of the tag on the bottom of the laptop I can direct you to the exact page for your specific model. These are essentially the same units:
Here are the manual pages for the laptop:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=3860153&
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
HP G62-355DX CMOS battery failure?
just replace the cmos battery, if you do not know how, take it to the shop of repairing
How to replace HP G62-435DX Notebook PC internal battery?
Good news its that its detachable
Bad news is that you have to take it all apart
See a guide about dissasembling the g62
Need to see keyboard of HP vision
It's an HP G62-367NR Notebook PC
Has the 'VISION' technology from AMD
http://bizsupport1.austin.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c02511485&prodSeriesId=4247529&prodTypeId=321957
When referencing to a computer; desktop or laptop; the inference should be to the model number.
With an HP it's the Product Number.
P/N in the white Service Tag.
Back of a desktop computer
Bottom of a laptop.
http://www.amazon.com/HP-Athlon-2-2GHz-Notebook-G62-347NR/dp/B004F1VM66
In the following link, SET your mouse cursor in the middle of the photo. This enables the Zoom In feature. Move your mouse around,
http://www.ebay.com/itm/Notebook-Keyboard-FOR-HP-G62-347CL-G62-347NR-G62-347-G62-352US-G62-352-G62-348CA-/120960880161?pt=PCA_Mice_Trackballs&hash=item1c29d48e21
http://www.laptoprepair101.com/laptop/2007/03/20/key-fell-off-keyboard/
http://www.laptoprepair101.com/laptop/2009/12/05/how-to-disassemble-laptop-keyboard/
For additional questions please post in a Comment.
Regards,
joecoolvette
2answers
HP g62-340us Notebook not working
I'm not clear on some of the question. When you say "suddenly not working" , explain what you were doing? Is the Laptop overheating? Does the fan and vents need cleaning? Is it getting sufficient air flow from the bottom through the laptop? If you unplug, remove battery, leave battery out, plug in, try to reboot, post what happens. Fan spins? LED's blink? What's on the screen at boot? Post the OS you are using. Windows 7 32 or 64bit? Take a look at HP Support: http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?tmp_task=solveCategory&cc=us&dlc=en&lc=en&product=4308554
1helpful
2answers
"Consider replacing your battery"
Modern batteries do talk to the laptops and provide information on health. Ordinarily, this message would mean that your battery is on its way out. If however, it holds its charge then fine, but at some stage you may find that you only get a few minutes use even on a full charge and you will need to find a replacement.
Leon
1helpful
3answers
Whenim on my hp g62 for awhile the screen will go white
There is probably a intermittent problem in the actual LCD display or the built in board, either case the screen down the road will need to be replaced. Check www.ebay.com type make and model of laptop, refine search to screen, this will a idea of pricing.
3answers
My power cord seems to not be working with this computer. I have tried all the outlets in my house and nothing is charging my laptot.
I'd call HP and request a new power adapter. I've had a few of them go bad before and it's just a short in the cord. Your plug might be loose also...but a good place to start is by calling HP and getting a new cord.
How long should a lithium-ion battery last in a hp notebook model G62-354CA
Depends on a number of factors:
1.) If you used the laptop on mains with the battery charged, it reduces its life
2.) How many recharges it as had
3.) How old the battery is
4.) What temperatures the battery has been stored in (adverse temperature changes affect Li-ions)
A Rough guess would be 12 -18 months, the batteries deteriorate progressively with age. If its less than a year and you have a warranty, I'd be contacting HP
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
