Question about GPX HTD2804DT System
DVD Player How can I open the door to my DVD player?
  • 944 Answers
Here is the link for the user manual if you need it; http://www.gpx.com/supp_dnld.php?&cod=146&code=DVD# I am assuming that power is on and you have tried the eject button. If you feel confident to try, then unplug machine and take off the top cover (looks like 5 screws at the back and then it should lift forward and up (just possibly the volume knob will need pulling off too, but maybe not) being careful not to touch anything inside, plug the machine back in and try eject and see if anything moves inside at all. sometimes cables can get bent in such a way as to block the tray form coming out. If you get nothing at all then i suspect either the tray drive motor is faulty, or the section of the power supply that powers it has failed. Just have a look in the back left corner where the power cable goes into the box and see if there are any fuses and check them. try plugging the machine into a different power socket in a different room just in case the supply voltage is the problem, if that works then call an electrician. Hope this helps :)
Posted on Mar 17, 2007
  • Nigel Ridehalgh
    Nigel Ridehalgh Mar 17, 2007
    http://www.gpx.com/supp_faq.php
    This link explains the repair process if you have no luck with the rest :)
How to Unlock a Sony DVD player DVP SR320 which displays "LOCKED" when eject/open button is pressed?
Apr 22, 2012 | Televison & Video
DVD player doesn't work
you can open the top cover and take the cd out.
Jun 04, 2008 | Sony SLV-D350P DVD Player/VCR
Problem: How do I get my RCA DVD player door to open? I tried unplugging the DVD player, plugging it back in, and then pushing stop on the DVD player and then open.
you put a small long pin in to the holl which you can see just below the door and push to the lever so that the door lock will open, then you check and replaced the rubber belt if required
Apr 07, 2011 | RCA Televison & Video
The door of my dvd player will not open. It sound like it wants to, but nothing happens.
This sounds like a problem with the mechanism of your player,it is probably stuck.
What you should do is to open up the player and try to open the door with your hand by pulling it,check to see what is stopping it from opening and clear the object stopping the door from opening automatically
Please note that it might just require oiling the door wheel to make the door open and close automatically.
Aug 20, 2010 | Sanyo DVW-5000 DVD Player/VCR
Dvd player wont open
try a paper clip opened and put on dvd door hole (small hole), and push slowly the paperclip inside and realease the dvd door to open, normaly is a defective dvd laser mec. and needs to be replaced. send to repair
Jan 03, 2010 | Panasonic DVD-RV26 DVD Player
The player will not work and I can't open the door?
Grab a screw driver , remove the case of the dvd player, remove teh DVD, then junk teh DVD player.
Aug 25, 2009 | Sanyo DWM400 DVD Player
Jvc dvd player
press and hold stop button more than 5 sec and ur player will be unlock
Nov 08, 2008 | JVC XV-N320 DVD Player
DVD player door won't open
took out the dvd player and inverted it and pushed the advance disk button . There was a disk stuck between the disk slots. The door opened and I removed the disk.
Sep 20, 2008 | GPX D2816 DVD Player
Sungale dvd player 2026
I have the same problem many times. I simply rotate the player 90 degrees on it's horizontal axis, so that the opening is facing toward the ground. Then, hold the door open and press the "Open" button. It's pretty ghetto but it always works for me.
May 27, 2008 | Sungale DVD-2026 DVD Player
GPX HTD2804DT System Logo
146 people viewed this question
Top GPX Audio Players & Recorders Experts
Sandy Moore
Sandy Moore
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
