Wachine machine bangs when on spin cycle.
Currently have a GE GHDSR316H0WW washer. The problem I have is that when it's on a spin cycle, it bangs around like the load is not centered. Even when there is very little in there. When you lift the lid to check (and no nothing to the load) and the put the lid back down after it comes to a complete stop, it works fine. Any ideas??
  • 373 Answers
Unless your top loader is set firmly on concrete and leveled to perfection, the force of a heavy wash load spinning in excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Also due to the earlier movements during the spin cycle, the shocks that are used to dampen the spin cycle might have been broken or damaged.
If the problem persists inspite of proper levelling, please do check for the shocks or might have them replaced them for good.
Posted on Dec 15, 2008
Ge washer bangs while washing
Make sure it's level. That's step one. If it is, you may have a broken drum suspension spring. Or hopefully one that was never reattached after the motor was replaced. Unplug it and take the back panel off and take a look. You may be able to reattach it yourself and save a bunch of money. Good luck!
Feb 04, 2017 | GE Washing Machines
Have a GE washer that has small, medium, large, and super load size. It's a top loader. When machine starts wash cycle, it bangs on the cotton and permanent press setting?
Probably out of balance, if in the spin cycle. If not, a "bang" corresponding with agitator reverse, you may have a transmission problem. Override open lid off switch with a pencil or used toothbrush in the small hole upper left location just under lid when closed so you can see the agitator action. If so run it till it breaks. Then replace. Otherwise, call your friendly appliance repairman and ask for a repair estimate first. If it is an ageing machine consider repair cost versis a lightly used one or new.
Oct 30, 2014 | GE G.e. Gtwn4950lws He Top Load Washer
Banging drum when spinning
if the drum in the washer klunks/bangs in ANY brand of washer when it is spinning, your load is off balance. stop the machine, re-distribute the wet clothes so that the weight is evenly distributed, then restar the spin. u may have to do this more than once if u did not evely distribute the weight. this is an easy one. just be sure to stop the spin soon as it starts banging. letting it bang thru an entire spin cycle could result in actual damage to the machine. some of the new machines auto shut off at an imbalance so u can correct the problem. think of spinning a top. u unevenly add weights to it then spin it again, it WILL wobble.
Feb 22, 2014 | GE G.e. Gtwn4950lws He Top Load Washer
Banging noise during spin cycle
weight not distabuted in washer move cloths around so its even
Feb 10, 2010 | Washing Machines
I have a GE top load washing machine. During the
there are springs under the machine that attatch to the tub in 3 to 4 places if one of these springs break it will cause the tub to bang.
Dec 22, 2009 | GE WBSR3140DW Top Load Washer
GE Profile - Loud knocking on spin cycle
Just random input, I apologize if this is of no help to you. I've only experienced this with my washer when clothes somehow get bunched up on one side of it.  The best I can tell you at the moment is to make sure there is relatively equal distribution of clothes around the "washer bucket thingy" if you hear the bang bang bang again.
Jul 06, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
GE WCSR2080B4WW - After wash cycle the washer does not spin and..
your washer must drain to may have a blocked or failed get to it thru the frount.use a putty knife between the lid and the frount ,push the comes up take frount off.pump has two hose .pumps white or tan smaller.God bless,tom
Jan 01, 2009 | GE WSM2700W Unitized Spacemaker Washer and...
Noise when ge washer put in spin mode
this could be one of two problems.
The first which is fairly cheap to repair would be to check the carbon brushes in the motor, they may need replacing, especially if your washing comes out wetter then it should.
The second is the bearings on the drum which is more expensive to replace and would need to be done by an engineer.
Nov 16, 2008 | Frigidaire GLTF1670A Front Load Washer
Washing Machines Logo
278 people viewed this question
Top Washing Machines Experts
