I bought a sub woofer from a thrift store used and even though my existng computer speakers have a sub woofer jack, after hooking it up, it doesnt play. I bought the digital chord which fits well in the speakers. Why doesnt it work. I even bought a bigger power supply and the sub woofer still doesnt work, it only has a very low volumed hum. Any suggestions would be appreciated. Thanks. Paul Brady.
  • Dshack
    Dshack May 11, 2010
    Is the sub woofer a PC speaker subwoofer, or a generic subwoofer for a multimedia setup?
    Also, what speakers do you have?
    What jack does the subwoofer use?
    What sound card do you have?
    President:
  • 2,692 Answers
Different sound system use different voltages for their speakers. Look up in your computer manual what the electricial requirments are for the speakers and see if the one you bought matches.
Posted on Dec 15, 2008
Where should I plug in my sub woffer
There should be two jacks on the back that say SUBWOOFER in the "preout" section of the back panel that is directly above the speaker jacks. Either of these jacks should work for your sub hook-up. Also make sure that you set your front speakers to small in the speaker setup menu, otherwise there will be output to the subwoofer jacks.
Dec 27, 2012 | Pioneer Elite VSX-52
I want to install a self powered woofer and tap it to the rear speakers. Can you please tell me what are the colors and polarity of the rear speaker wires for 2006 Honda odyssey right hand drive
FIRST OF ALL --- THERE IS A FEW THINGS YOU NEED TO KNOW BEFORE HOOKING UP
A WOOFER LIKE THIS ---- IS THIS A STORE BOUGHT POWERED SUB WOOFER ? DOES IT HAVE IT'S OWN CROSSOVER BUILT INSIDE ?? I WOULD GUESS IT NEEDS TO BE HOOKED
UP TO A SUB WOOFER OUTPUT FOUND ON THE BACK OF THE IN DASH PLAYER ..
THE WOOFER NEEDS TO RECEIVE ONLY LOW FREQUENCY AUDIO WHICH MOST OF THE NEWER CAR STEREOS PROVIDE BY AN RCA JACK ON A SHORT WIRE COMING OUT OF THE STEREO ...
IF YOU TRY AND TAP IT TO FULL RANGE SPEAKERS THAT ALREADY ARE CONNECTED TO AN AMPLIFIED SIGNAL THE SOUND WILL BE DISTORTED .......
POWERED SUB WOOFERS NEED A LINE LEVEL INPUT WHICH IS MUCH LOWER THAN SAY
SPEAKERS ALREADY RECEIVING AN AMPLIFIED SIGNAL.
POWERED WOOFER WILL ALSO NEED TO HAVE A 12 VOLT ELECTRICAL CONNECTION AND A GROUND WIRE TO OPERATE THE AMPLIFIER BUILT INSIDE.
IF YOU HAVE NO EXPERIENCE WITH THIS TYPE OF HOOK UP I WOULD STRONGLY RECOMMEND SOMEONE WHO DOES [ CAR AUDIO SHOP ]
Jun 29, 2011 | Car Audio & Video
What you use to hook them up? i dont know how to hook them up to my pc or tv
you connect all the speakers to the amp sub woofer and run a single or multiple jack plug lead into the back of the pc
Mar 05, 2011 | Sonic EV SonicXS 4.1 Computer Speakers
I have two Harman Kardon speakers that came with my computer. I bought a subwoofer and would like to hook it to the speakers and computers. How do I do this?
You will need a sound card which supports more than stereo sound say a 5.1 or 7.1 then you will have the extra jacks to plug in even rear, centre and side speakers if you wish as well as a sub-woofer. Cheers from Scott....pls vote
Jun 24, 2010 | HP Computers & Internet
How do I hook up a non powered sub woofer on my htr-5630?
You will need an amplifier or 2 channel receiver. Hook the sub out rca jack to the rca inputs on this new amp or receiver and hook the speaker terminals on sub to speaker terminals on same amp or receiver. Your Yamaha receiver doesn't have any power for a passive sub.Just pick up any old fairly high powered receiver for fifty dollars and you're good to go.I use old dolby pro logic receivers as they are a dime a dozen today. Good luck.
Feb 20, 2010 | Yamaha HTR-5630 Receiver
Cube speakers w/ no subwoofer
I have the acoustimas systrem and the speakers do need the sb. That's the heart of the system.
I dropped my two front cubes and neither work. If you would be willing to sell yours at a reasonable price I would be willing to buy.
Please contact Bose customer support and I believe they will tell yiou the same thing.
Please let me know.
May 02, 2009 | Bose Acoustimass 5 III System
Subwoofer to receiver hookup
In general, there are two ways to hook up your sub-woofer. First using the high level outputs from your receiver ( speaker output from the front R & L speaker terminals ) run a set of wires from the outputs to the speaker inputs on the sub-woofer, you do this in concert with the speaker wires going to the front R & L speakers which you then attach to the R & L speaker outputs on the sub woofer amp. Note that the sub woofer doesn't power your front speakers, the connections from the sub amp are just a pass through connection where the signal needed by the sub is parasitically taken from the inputs.
Second is via a low level output from your receiver / amp to the low level input on your sub amp. This is normally done via a RCA type of patch cable and connected to the sub woofer RCA jack on the rear of the source receiver or amp, Next run the patch cord to the sub amp an into the RCA jack input. IF you have a right and left input, use the Right input.
john
Aug 18, 2008 | Audio Players & Recorders
735 speakers
Use the "Analog In" jack on the sub-woofer and NOT the " Digital In". That's when they start working.
sumother set of these SAME speakers DOES NOT have an "Analog In" jack. So give them to a local thrift shop.
note: Boston makes 2 different speaker sets with the same name,
BA 735: one with and one without the "Analog In" jack.
Jul 04, 2008 | Boston Acoustics MicroMedia Computer...
Sub Woofer does not work
hi there are fast checkings for you: Quick Connect Card http://www.alteclansing.com/downloads/641QCC.pdf manual: http://www.alteclansing.com/downloads/641_MAN.pdf is the system working fine exept the sub? my guess: the headphone jack works fine then the speakears are too if soo then the sub amp is bad or some connection is torn try opening the sub and see if everything is hooked right and if soo then the amp is the problem every electronics shop can fix this good luck
Mar 21, 2006 | Altec Lansing 641 Computer Speakers
Computers & Internet Logo
109 people viewed this question
Alun Cox
David Payne
David Payne
