Question about Kenmore 63942 Dryer
Kenmore dryer model #86870100 runs but no heat
Runs thru the whole cycle but does not heat at all
  • josephparvid Jan 12, 2009
    The exhaust hose came off yesterday. I reattached it and worked fine. Worked fine today as well and now is not heating at all. I see the post that says that it is the small and large doors or flaps or something. How do I fix this...?
  • Kenmore Master
  • 8,220 Answers
This kit mounts on the heater element chamber. The small one will be open. The big one failed also because it is rated to shut down @250°F. The little guy is rated at 300°F. NOTE: when this limit fails it is a sure sign of a blockage of lint somewhere.kenmore dryer model #86870100 runs but no heat - 8e8a912.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Dec 15, 2008
Does anyone have a online manual for the kenmore electrical dryer model number: 110.86870100?
Thanks
Ron
Posted on Aug 29, 2009
86870100 Kenmore dryer won't heat but goes through cycle
Dear Diane Bassett,
I recently had a problem of the exact nature. The answer to your second question is yes, these are awkwardly located at the rear of the machine, so you will have to pull the dryer out from its recess. isolate the dryer from the mains for an hour or so, press the reset button in for a few seconds and you should be fine.
If that doesnt solve the issue, then your thermostat is up dawsons' creek without a paddle.
Anway I hope this is the fixya for you and I look forward to hearing how you get on with this.
Yours sincerely
Ouszen
Feb 07, 2012 | Kenmore Dryers
Hi Ginko. I have a Kenmore dryer model 11086810100 that has some wires removed from inside. The only HOT I can find is the red wire. I have 2 wires that have femals push-on crimped terminals, but I have no...
Hi Robert.
Thanks for the pics. I operate in UK and color codes here are different.
From what I can see the wiring in your picture does not match the US standard either.
The thermal fuse for example should have two blue terminals, not red and blue. The thermal fuse wires goes on one side to start, and on the other to the drive motor through the broken belt switch (if present).
The wiring at the blower must be revised and done again.
Here a service manual covering Kenmore 70 series dryers.
http://www.applianceblog.com/mainforums/attachments/sears-kenmore/3298d1196129125-kenmore-dryer-model-110-86870100-wont-heat-ldrwp-checkpoints.jpg
There is a wiring diagram at page 25.
Here a picture showing correct wiring: http://www.applianceblog.com/mainforums/attachments/sears-kenmore/3298d1196129125-kenmore-dryer-model-110-86870100-wont-heat-ldrwp-checkpoints.jpg
See also the pictures in this blog:
http://www.satfix.net/showthread.php?931-How-Dryers-work.-Whirlpool-Inglis-Kitchen-Aid-Kenmore-Admiral-Roper
About the red and yellow cable, the only red yellow wire in the diagram operates the switch for the guard function. The wire becomes hot and powers the motor when the guard switch is closed.
Parts (including wiring harness and terminals) are available here:
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Dryer-Parts/Model-11086810100/0582/0151200?pathTaken=&prst=0&shdMod=11086810100
Jan 02, 2012 | Kenmore Dryers
My grandmothers dryer wont heat up. It is a Kenmore, (model) 86870100, with (serial no.) MX1661182. Would like to know how i would know for sure if it is either the element or a fuse.
you will need to open the dryer and look at the element, if you have a meter you will need to ohm it out, but more then likely the thermal fuse is bad. In order to test, test only after test disconnect the bypass, you will need to bypass the fuse: take the two spaded ends off the thermal fuse and tape them together then turn dryer on if you have heat you will need to replace fuse, can be purchased online. eBay is the cheapest but can be purchase from a appliance sales/repair shop, Tim:
http://www.ehow.com/how_5044534_open-kenmore-dryer-panel.html
http://www.ehow.com/how_6746180_bypass-fuse-kenmore-drying-machine.html
May 27, 2011 | Dryers
My dryer model # 86870100 is running but is not heating up to dry clothes is there a way to fix it
i have the same dryer with the same problem let me know if you find out how to fix it. i think it is the heating element.
Feb 22, 2011 | Kenmore 63942 Dryer
Kenmore Heavy Duty. Don't know the age of it but the model number is 86870100 How old would this Dryer be?
We bought ours new in 1989 but have seen posts stating this model started in 1987.
Aug 27, 2010 | Kenmore 63942 Dryer
I have a Lady Kenmore electric dryer (40 years old maybe?), model 110 6508923, which I cleaned the vents, strong air, tumbles fine. The heating element glows orange for a few moments, then as it finally...
The element is supposed to cycle on and off thru out the drying cycle as not to burn clothes. Is it just taking too long to dry. If it is your exhaust from the wall behind the dryer to the outside is clogged somehow. I like to use a leaf blower stuck inside the exhaust behind the dryer and blow the whole line out to the outside of the home.
Jan 31, 2010 | Dryers
Whirlpool gas dryer makes buzzing sound when started, stops mid-c
Maybe something fell down into the filter housing. Get the back off and inspect it with the power disconnected.
Feb 17, 2009 | Kenmore 62602 Electric Dryer
Kenmore 86870100 not getting hot.
Check the thermal fuse first, then the heating element.
Feb 06, 2009 | Kenmore 63942 Dryer
Replacing Kenmore dryer parts
that one is old enough to vote..if filter on top remove back find small hole on right just below top may be hidden by pasted on tech sheet..through hole insert long socket 5/16 or reach up from underneath with short ratchet and socket remove screws and attached wires lift element housing up slightly and pull bottom of housing out and down..5/16 screw on backside holdes element in
Jun 18, 2008 | Dryers
Kenmore 72602100 gas dryer runs but no heat
gas dryers would have an igniter to start the flame. check it first to see if its still ok. be carefull in handling them, they are very fragile. check also for availability of gas. could have a closed valve.
Jan 30, 2008 | Kenmore 63942 Dryer
Kenmore 63942 Dryer Logo
1,399 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
