Question about Ryobi Factory Reconditioned 18" 40cc 2-Cycle Gas Powered Chain Saw #ZRRY10532
Ryobi PCN 4040 will not start up
Used my Ryobi PCN4040 chainsaw about six monthes ago but now it will not start up
    President:
  • Ryobi Master
  • 1,392 Answers
When I was going to college I worked at a tool rental center and learned may tricks about tools. At this rental center chainsaws were seasonal thus sat in the warehouse probably as in your situation. Well one is supposed to store a chainsaw without any fuel and discard any old fuel mix because it will not keep. To easily start a saw that was in storage we would install a new spark plug, add fresh fuel mix and spray carburetor cleaner directly into the carbureter to get it started. Once started fresh fuel would be drawn into the engine from the tank and keep running. If you forgot to drain the old fuel, do it now and use the trick above. For best results, always use a fresh plug. Enjoy
Posted on Dec 15, 2008
Ryobi pcn 4040 chainsaw won't start What is the
1st add fuel/oil mix to fuel tank , then top off oil tank with bar oil , place saw down on flat surface , press 'ON" button above trigger handle to ON (its marked on case) then pull out blue choke handle till it clicks and stays out , press primer bulb with thumb 8 to 10 times bulb will become harder to press as it fills carb , push chain brake forward (on) ` place left hand on top of saw and right hand on start cord , hold saw down firmly and pull cord vigorsly several times till it sort of starts (sound) , squeeze trigger in and pull cord once more , saw should take off running , chain wont move ,walk to wood pile then disengage the chain brake and cut wood , if saw fails to start after this procedure then there must be a fault in saw , consult a exp small engine dealer for repairs
Sep 01, 2013 | Ryobi 18-inch Electric Chainsaw Chain Saws
Chainsaw chain brake on Ryobi PCN 4040
remove the cover and check the spring
Apr 13, 2012 | Ryobi Garden
Repair manual for ryobi pcn4040 chainsaw
Got the same problem. narrowed it down to the tension spring in the brake handle you can buy then for around £4 of the internet. as yet i haven't figured out how to replace it yet.
Ryoby pcn 4040 tuning
I believe on low its 1 turn from closed and high is 1 and half turn from closed if not try the opposite way if you cant tell the difference clean carb and try again
Apr 01, 2012 | Ryobi Factory Reconditioned 18" 40cc...
Timing adjustment for Ryobi Petrol Chainsaw Model PCN 4040. Flywheel has come loose and timing nees to be set up again. Are there timing marks to do this?
No timing marks I'm afraid.
But if you play around with the adjustment, you'll soon get the jist of it.
Also don't forget, you can adjust the timing, by opening, or closing the gap on the plug too;)
FixedYa!
& plz don't forget to give me a nice rating ;))
Thankyou,
Jul 07, 2009 | Garden
Ryobi pcn 4040 chain saw
I have the same model chainsaw with the same fault. The brake is not releasing when the brake handle is pulled right back. I can only run mine if the brake handle is pulled back to the main handle with a tyrap - defeats the object of the auto-brake completely. Design fault I reckon.
Sep 28, 2008 | Ryobi 18-inch Electric Chainsaw Chain Saws
Ryobi Factory Reconditioned 18" 40cc 2-Cycle Gas Powered Chain Saw #ZRRY10532 Logo
1,191 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
John Wilson
Level 1 Expert
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
