Question about Palm TX Handheld
Can't sync palm tx with new vista based desktop
I loaded the desktop disc that came with the pda but couldn't get it to sync when it promted part way through the install. I then went online to try to get a version for Vista and downloaded Access 6.2 I think. Same problem. The computer stated it was looking for a driver for the device then stopped on waiting for user input. I attempted to hotsync but the the pda and computer weren't talking. What can I do?
Thanks
Jeff
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Offhand, it would be a matter of permissions and user privileges. Initially, pls try:
  • do a complete uninstall;
  • thereafter check for updates especially on the USB;
  • temporarily disable antivirus and firewall;
  • perform a clean install;
  • follow on screen directions.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 15, 2008
  • 6,487 Answers
You can try doing this steps in solving the problem....
Open your hardware manager, turn on your palm, and tell your palm to initiate a hotsync. Look for a device with a question mark or exclamation mark next to it, or look for a device matching something to the effect of Palm.
While the Palm device is connected, select that device, and uninstall the driver for it. Then tell it to install the driver, but this time, you need to specify where the driver comes from. The location should be /Program Files/Palm
    Genius:
  • 1,011 Answers
Sir,
Try to hard reset or check whether the computer is updated OS and also check this link for "How to hard reset"
thanks
good luck
Unable to connect hotsync with desktop
Palm 515 Hotsync unable to connect to Desktop - Expansys ...
www.expansys-usa.com > Forums > Palm > Palm m515
Jun 29, 2004 - 6 posts - ‎5 authors
I get the messsage "The connection between your handheld computer and thedesktop could not be established. Please check your setup and ...
Setting Up Palm OS Hot syncing with Windows 7 or Vista 64bit
www.turbostats.com/support/hotsync.html
Download Palm Desktop 6.2; Install Aceeca 64 Bit driver; Install ... Product Support; If you have Windows 7, 8 or 10 32-bit you should be able to Hotsync now.
unable to connect to computer to hotsync via network or cable
forum.brighthand.com > ... > Device Manufacturers > Palm > Palm TX
Jul 30, 2008 - 10 posts - ‎6 authors
i haven't been able to hotsync since i sent my laptop in for 'repair' a while ago. ... Make sure you do NOT connect the TX to the computer (even ... Cannot hotsync Palm lllxe with USB to Serial Adaptor ...
Jan 24, 2011
Hotsync problem - unable to establish desktop ...
1 post
Oct 19, 2004
Unable to Hotsync - Identifying user? ' Brighthand.com ...
Mar 16, 2004
Unable to Hotsync Palm IIIxe with a USB connection ...
Dec 18, 2002
More results from forum.brighthand.com
Jan 03, 2016 | Palm Tungsten Tx Handheld Pda 312mhz 128mb...
I cannot not get AviSys Palm Ops installed on a new Palm pda, suing Windows Vista. Jerry Blinn says that Vista is the problem and has no solution.
If you own Win XP, try setting up a virtualbox. Virtualbox will allow you to run XP within Vista, making it possible to install.
Feb 08, 2010 | Intel Palm Tx Handheld
Computer won't syronize palm m 515 handheld
Palm Desktop needs to be installed on the new computer to sync. The sync will copy most of the info on the pda onto the computer.
Jan 03, 2010 | Palm TX Handheld
Is there anyway to delete files from a Palm TX using the desktop?
Unless I'm not understanding your question, any entries that you delete from either the desktop or PDA will delete from the other device when you sync your PDA.
So, if you delete an item from your Palm desktop, the next time you sync your PDA to your desktop, the entry will be deleted from your PDA as well.
But, if you haven't backed up / synced your PDA to your desktop yet, install and run Hotsync Manager - do that first. And, perform that procedure often so that your info on your PDA will be safe on your desktop.
Hope this helps.
Sep 14, 2009 | Palm TX Handheld
Pda will not hotsync
assuming that you use your palm tx on a windows xp system, files from the emails could be corrupted. are you using palm desktop or outlook?
if you are using palm desktop, you can rename the back-up folder to old and try to resync
Oct 08, 2008 | Palm TX Handheld
Is MAC OS 10.5.4 compatible with
Palm was having trouble supporting but there is a new desktop available for the TX on Vista as well as Apple OS X. I don't know how well that machine will sync to both desktops though. It's probably a good idea to sync it on one machine or the other.
Aug 07, 2008 | Palm TX Handheld
Handheld Calendar Does Not Sync
Is KsDatebook compatible with Palm? Palm suggests only two programs to sync calender files with Microsoft Outlook and the one that comes with the TX CD.
Jun 04, 2008 | Palm TX Handheld
I'm lost already!
Sounds like your PDA is not communicating with the desktop software properly. (is it a refurbished unit?). I would recommend you un-install the desktop software completely, then do a hard reset on the unit. This should start you from scratch. Then, re-install the software and re-boot the TX and configure it, and try a brand new sync. If this doesn't help, you might have to return it. But first, try it with the desktop software on a DIFFERENT computer.
Good luck.
Nov 13, 2007 | Palm TX Handheld
Palm T/X won't hot sync on Window XP Media Center Edition
i had that problem too. sorry it is bugging you.
i know you probably want to sync your data rught now. So for now try to disable the syncing of documents to go (just for now)
on palm desktop, look for the conduits and temporarily disable the syncing of docs to go. Also ensure you plug in your pda charger as well as the usb cable (I found out this helps through experience) and sync. (Just to back it up)
as for the documents to go, there is probably a file(document) that is generating the errors. please look through documents to go on your palm desktop and remove any file you feel is not necessary. also take note that it is best if your pda has some free memory on it. you may want to save those documents on a disk (If you are not already that is..) clearing up ram made my tx more stable esp during hot sync.
please let me know it that worked for you. i still have some suggestions
good luck and enjoy
Nov 05, 2007 | Palm TX Handheld
Palm TX Handheld Logo
Top Palm Computers & Internet Experts
Michael Vincent Cruz
ray gallant
Raj Patel
Are you a Palm Computer and Internet Expert? Answer questions, earn points and help others
