Question about Panasonic CT-27SF25 27" TV
How do you exit service mode?
Had a problem with the vertical settings and used advice from website to get into service mode but information incorrect to exit service mode. Have pressed exit twice, turned it off for a while, and even left it unplugged overnight and no results. Tried to go back into the settings but no results. When I turn the power off with the remote it goes into the next servicemenu item and the tv has to be turned off manually.
  • Animas Dec 05, 2008
    In my remote there is no action. What is the equivalent value of action in panasonic t.v.?
    President:
  • 3,130 Answers
PANASONIC: Panasonic TV's after 1996 can be set to "Serviceman Mode" with the following remote control sequence: First, select the SET-UP icon and select CABLE mode. Then, select the TIMER icon and set the SLEEP timer for 30 minutes. Next, press the ACTION button twice to get out of the menus. Now, change to channel 124. Then, adjust the volume to minimum (0). You're almost there - Hit the VOL down button on the TV itself (not on the remote) and a red "CHK" should appear in the upper corner. Now, if you press the ACTION and VOLUME DOWN buttons (again, on the TV, not the remote) you will toggle between AGING and SERVICEMAN modes. Select Serviceman mode. The POWER button on the remote control will select one of the five Serviceman Adjustment modes. The modes are: B - Serviceman VCJ SUB Adjustments. These include sub-tint, sub-color, sub-brightness, sub-contrast, colorkiller/ABL/gamma,audio and video adjustment, and vertical size. C - Serviceman VCJ Cut-off adjustments. These include Red, Green and Blue cut-off, red and blue drive, automatic fine tuning(AFT), RF AGC (RF gain control), horizontal center, beam limit,etc. S - Serviceman Options Adjustments. These involce the PIP and clock. M - Serviceman MTS (Stereo/SAP) adjustments. CHK - the mode you first entered. Normal picture and sound, lets you check things over and still have a hotkey into the service menu. There is one more adjustment that isn't in the five modes, it's global. When in either the yellow or red CHK mode, you can press RECALL on the remote control to enter the purity firld check mode. This lets you select a pure white, red, green, or blue screen. A good thing to walk away from if you just want to temporarily freak out the floor manager, but it will be fixed as soon as the TV is turned off. To get out of Serviceman mode, press ACTION and POWER on the remote simultaneously for at least 2 seconds. The TV will momentarily shut off and then comes back on. If this does not help you will most likely need to get the service manual as you should always have that anyway before ever attempting any serve mode adustments. Also do not forget to ALWAYS write down all of the values that you change incase a problem arises. Good Luck
Posted on Mar 17, 2007
How do I adjust the Vertical size or position?
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful. Note how to "EXIT" the service mode; after entering and adjusting data. This is very important.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Apr 23, 2016 | Zenith SY2765S TV
Tip
SERVICE MODE AND ADJUSTMENTS
Accessing Self Diagnostic Menu
1. While LCD TV set is on standby mode, press the following
sequence on the Remote Commander key. (RM-GD020)
For more check the following link. Use the search tab on the top right corner on the page to find your product.
www.electro-medical.blogspot.com
google.com/+AjinGopakumar
on Feb 18, 2015 | Sony Kdl-32cx520 32" Full Hd Multi-system...
I want to know factory code for haier tv just adjust to adjust vertical horizontal setting
You're in need to know to enter its service mode option; I presume. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jan 12, 2016 | Haier HYF-21 Remote Control TV-5620-04
LG 21"CRT TV FOULTS IS VARTICALY UP SIFTING ?
You have to enter its service mode to correct the vertical height, linearity. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Jan 03, 2015 | Televison & Video
What is service code for vertical alignment
Sep 22, 2014 | RCA Used Original 32V434TYX6 Remote...
What is theService mode code for sansui tv using IC TDA9370ps /N3/A/1839?
Jul 30, 2014 | Sansui Televison & Video
How do I unlock the setup options for horizontal & vertical adjustments on my 55" HDT 51M 2006 Plasma TV won't let me access the horizontal or vertical options in setup in RGB 1 mode.
You have to enter the service mode option to it, to do horizontal and vertical adjustments. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box.
May 25, 2014 | Hitachi 55HDT51 55 in. HD-Ready Plasma...
Unable to adjust the settings for brightness and contrast .
To adjust the display settings:
1. Press the flywheel control. The main menu appears.
The current display settings appear across the top of the main menu.
2. Rotate the flywheel to highlight an option. The name of the
highlighted option appears in the center of the menu.
3. Press the flywheel control to select the highlighted option, then
rotate the flywheel to adjust it.
Some options can only be enabled or disabled. There are also some
options that contain additional menus.
4. Repeat Steps 2 and 3 until you have made all your changes.
5. Rotate the flywheel control until Exit is highlighted, then press
it to exit the OSD control system.
OSD OPTIONS:
Contrast increases or decreases display image contrast.
Brightness increases or decreases display image brightness.
Horizontal Size increases or decreases the width of the display image.
Horizontal Position moves display image to the left or right side of
the screen.
Vertical Size increases or decreases the height of the display image.
Vertical Position moves display image to the top or bottom of the
screen,
Pincushion curves the sides of the display image inward or outward.
Trapezoid increases or decreases the trapezoid distortion of the
display image.
Degauss removes magnetic discoloration from the display image.
Recall returns most options to the original factory default settings
if the monitor is currently using a preset video mode. (See the “Video
modes” section in this guide for information about the factory preset
modes.)
Advanced Option opens the Advanced Option menu. Color opens the Color
Manager menu.
Language changes the display language for the OSD control system.
User displays information about the monitor’s preset modes.
OSD Manager moves the OSD control window on the screen.
Exit closes OSD control system.
Jun 21, 2010 | Gateway EV 910 19" CRT Monitor
C03ff
CAUSE: Incorrect setting. This can occur after a memory clear is performed.
SOLUTION: To correct the C-03FF code, set the machine to the correct speed by performing the following:
1. Enter the service mode.
2. Select 2 for the adjust mode.
3. Go to setting AD11.
4. Set AD11 to "1" for 18 cpm.
5. Exit the service mode.
to access the service mode .enter UTILITY KEY STOP 0 0 STOP 0 1 .GOOD LUCK
Jul 18, 2009 | Minolta DiALTA Di183 Copier
Vertical Stretch
You need to adjust "vertical height" in the service program. You need to put the set in "service mode" to do this adjustment. If you google "enter service mode RCA F32665" you should find the procedure. It will be listed in abbreviated letters such as VERT SIZE or VERT HT. Follow the instructions for entering service mode and saving the data closely!! The data you change will be listed as a number between 1 and 63. The number will only need to reduced by a small amount and you can still see the picture behind the data and watch it shrink as you adjust the number down.Always burn the new number to memory (if required) before exiting service mode. Good luck
barneyluc
Dec 01, 2008 | RCA F32665 32" TV
Panasonic CT-27SF25 27" TV Logo
714 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
