Question about Bosch 24 in. SRS43C12 Classixx Slim-Line Free-standing Dishwasher
Bosch classixx slimline dishwasher not running through cycle
I have a bosch classixx dishwasher and it keeps trying to constantly drain even when is empty, it wont run through any cycle and even when reset still try's to drain, the only way to stop it is to unplug it, could anything be stuck in the system which is fairly easy to repair myself or do i call an engineer?
  • 5 more comments
  • Volamus Dec 25, 2007
    I have a Bosch SHX46B05UC/14 and the dishcharge cycle run continuously, even when there is no water present. Opening the door does not stop the pump from running.
  • johnp24 May 14, 2009
    bosch classix dishwasher seems to be stuck on drain, turns off when door opened.
  • Anonymous Mar 13, 2014
    the dishwasher is constantly trying to drain even though it has drained
    The dishwasher is stuck in the draining mode even though the dishwaher is empty
  • Anonymous Mar 16, 2014
    I have a Bosch sgs43to2gb/08 it runs the first part of a wash cycle then it fill and Empty 's until I stop it it did fill up and flood be for this started happening .
  • Anonymous Mar 17, 2014
    run cycle stuck on end on my bosch classic dishwasher
  • Anonymous Mar 18, 2014
    after the cycle the bottom of the dishwasher is flooded.
    President:
  • 1,462 Answers
Fault is that there is a leak. the tray at base of dishwasher is full of water which operates a float and turns on drain pump. tilt over 45deg and water will run out and then it will work or remove bottom front panel and mop out (better). then find leak
Posted on Mar 20, 2007
Bosch dishwasher gets stuck at 1 minute
New and highly targeted viral marketing campaigns can instantly place your product, service or brand in front of potential customers. See the best examples of viral marketing videos and social media strategies. Viral Marketing Company Plan Strategies and Resources Viral Shot
Mar 11, 2014 | Bosch 24 in. SGS43C12 Classixx...
Bosch classic xx diswasher not emptying
Open kick panel under front of dishwasher. With flashlight, observe drain selenoid during exhaust cycle. If it does not operate, it must be replaced.
Jan 05, 2012 | Bosch 24 in. SGS43C12 Classixx...
Bosch classixx
your absolutely right, remove kick panel and check for leak/ water. if there is none you may need to replace the control
Nov 25, 2011 | Bosch 24 in. SGS43C12 Classixx...
Hi I have a bosch classix maxi been great for the last couple of years but it has failed for the first time yesterday. The dishwasher did not start it just kept making a groaning noise and would not start...
Completely unplug the dishwasher and leave disconnected for at least 10 mins.
Also be sure to check the drain pipe is not kinked or obstructed and that the filter is also clean and empty
May 04, 2011 | Bosch 24 in. SGS43C12 Classixx...
Dishwasher fills and empties water but doesnt run any programm
Hello, welcome to FixYa. Can you elaborate on the actions which take place ? Does it fill and just sit idle until eventually drain or do you cancel the cycle manually to initiate the draining ? I should be able to help you with some more details. I will watch for your reply. macmarkus :)
Jun 24, 2010 | Bosch 24 in. SGS43C12 Classixx...
Dishwasher not draining after a power cut
I would run the heated dry cycle a few times to try and get rid of that residual water, then restart the cycle and see if it work now. If it still is a problem try cleaning out the drain line behind the dishwasher, this is a very common problem with draining. If not that then might need a valve or if you have a new garbage disposal you need to punch out a peice of the plastic or it wont drain. Hope this helped, good luck
Jul 14, 2009 | Bosch 24 in. SGS43C12 Classixx...
Bosch integrated dishwasher water pump wont go off
sounds like the drain pump stays on. take the kickplate off and check for water in the base. if no water then make that little red bar to the left of the watervalve in the base go up and down a few times. you could have a stuck microswitch on the pressure chamber
May 29, 2009 | Bosch 24 in. SGS43C12 Classixx...
Dishwasher just emptying
I am at the end of my tether. I have bought a new door latch for my Bosch SGS 43E02 GB45, so door now closes properly and have managed to stop the leak under the front left hand side of the machine. Howver it sounds as if it is constantly emptying. It does not go onto the new wash cycle just keeps pumping out the water. It did run a quick rinse yestreday but now is back to the constant emptying problem. Even when I open the door it still keeps running and staying on a emptying cycle despite there being no visible water left inside the machine. Please help!!
Sep 12, 2008 | Dishwashers
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Bosch classixx check water light
ok sounds like a drain promblem love your do it your selfness but one thing you must keep in mind its under warrenty and if you mess with it you could void your warrenty if you have a cancel drain option try that if it still doesnt drain call for service
Mar 18, 2008 | Bosch 24 in. SGS43C12 Classixx...
Bosch 24 in. SRS43C12 Classixx Slim-Line Free-standing Dishwasher Logo
2,568 people viewed this question
Top Bosch Dishwashers Experts
shaun taylor
Carmen Mikulic
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
