Question about Sparkle Power SPI FSP300-ATX GT 300 Watt PS (fsp300-60btv) Power Supply
My pc shuts itself off
When i turn on my pc it will run for a few seconds and then it shuts itself down. then it will not turn back on until i unplug the the power slupply from the main mother board. then i can turn it back on for a few seconds untill it shuts itself off again.
  • Mike Fish
    Mike Fish May 11, 2010
    do you get any type of display on screen? it sounds like there is a short somewhere and its overloading the power supply, if your gettin something on screen your cpu could be overheating or the power supply could be near the end of its life
  • Anonymous Mar 12, 2014
    After running for 30 seconds or so the unit will go back into standby mode you can turn it back on however it returns back to standby after a few seconds
  • 35 Answers
Overheating
Posted on Dec 16, 2008
Dell Inspiron 8500 won't shut down, on/off button doesn't repond
Hold down the ON/OFF button for several seconds until it shuts off.
Mar 04, 2013 | Dell Inspiron 8500 Notebook
TV turns itself off??
Take a second look in the power supply where the power cord goes for bad caps----a few examples:
Good one on the left and puffed up one on the right
Extreme example of ones the arrows point to and notice all the perfectly flat tops on others
May 28, 2012 | Televison & Video
My dell xps 200 shuts down and the power light flashes amber. I try turning it back on and it does not respond. I have to unplug it from the outlet wait a few seconds then plug it back in. After I do this...
You can try unplugging the PC, removing the RAM and re-seating it. It could also be a power supply issue, either too much for it to handle or it's not functioning correctly. My first suggestion would be unplugging hardware that's not needed for a week or so and see if it keeps happening with only the HDD plugged in. If it doesn't continue plug one thing in at a time until you find the culprit... although because it does run for a bit when you have the so called culprit, unplug it and plug something in its place, if it continues then you may have over powered your power supply and need to get something a bit larger.
You may also have issues with the PC over heating or fans not running correctly, make sure to check these items while your PC is turned on. (please be careful).
Mar 07, 2011 | Dell XPS 200 PC Desktop
Dell studio one 19 not shutting down how to solve
First, press CTRL + ALT+ DELETE and bring up the task manager. If there is no response, you could try a hard reset. Either hold down the power button for a few seconds untill it shuts off, or switch the power button on back of pc off, or unplug the power. Although do this as a last result as you may lose any unsaved data. When you turn it back on it should say " windows did not shut down correctly " and it will give you a few options. Press enter on " Start Windows Normally ". See if that helps.
Apr 04, 2010 | Dell Studio One 19 PC Desktop
I turn the tv on and after a few seconds it shuts itself back off again. At that point I can't turn it back on until I unplug it and plug it back in. However, when I turn it back on it will again turn...
Possibly the main Power Regulator is damaged!!!
Open the case, then look for anything that burned out, replace it!!!
If still won't start, you need a multimeter, soldering iron, try locate output diode on power regulator board, then measure the voltages, it has 3-4 type of voltages;
first diode it should around 115V-130 V DC.
Second diode it should around 24 V DC.
Third diode it should around 11-16 V DC.
Fourth ( if exist), check diode and should around 5 V DC.
The problems usually start on second diode, if persist, follow the circuit board.
Oct 18, 2009 | Sharp 27K-S100 TV
Laptop shuts down in 6 seconds.
Most proably it is a main board problem. Contact authorized service center.
Jan 27, 2009 | Gateway MX6448 Notebook
Troubleshooting reddy heater 115,000btu
runs for awhile shuts down with a big puff of smoke comes out poured diesel 911 thought i had water in diesel fuel cans nothing help need solution ASAP
Oct 30, 2008 | Desa International ReddyHeater® R115DT...
Dell 2407 a04 Turns on (for 2 seconds) then off
your pc may be set to a resolution that is out of range for the monitor. Boot into "Safe mode" reset the Display settings to 640 x 480. reboot into normal mode then change the screen settings to your desired resolution.
Sep 07, 2007 | Dell UltraSharp 2407WFP 24" LCD Monitor
Sparkle Power SPI FSP300-ATX GT 300 Watt PS (fsp300-60btv) Power Supply Logo
291 people viewed this question
Top Sparkle Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a Sparkle Computer and Internet Expert? Answer questions, earn points and help others
