Question about Toshiba Satellite X205-S9349 Notebook
I have toshiba satellite x205-s9349 and yesterday i had internet access and today no...my wifi switch is on but red light...
  • cpctc1234 Dec 28, 2008
    I'll have the same problem. It says I'm still connected to the internet, but I have no connection.
  • 20 Answers
U can try by turning OFF and then ON your wifi switch on your laptop
Posted on Dec 15, 2008
I have a toshiba satellite x205-s9349. It won't boot at all, no beep codes or screen. The fans start and the hard drive lights go on for a bout 4 seconds and then the fans turn off and nothing....
Try this
unplug plug the power cord and remove the battery and hold the power button for 45 seconds,Then reinstall the battery and and try to start the computer,
if it fails to start
unplug plug the power cord and remove the battery and hold the power button for 45 seconds and
remove the memory and any usb devices that may be plugged in,then start it,
If it starts
Allow it to load completely and then shut it down and install one memory stick and restart, if all is well after if loads completely, shut down again and install the other memory stick and restart, if all is well again wait until it loads completely and then plug in and allow to load each of the usb devices you may have
Jun 29, 2011 | Toshiba Satellite X205-S9349 Notebook
Where is the jumper located on the Toshiba satellite x205-s9349 motherboard? i need to reset my bios password and on this model i cannot find it.
Pointing you to another FixYa member who had the same problem. Follow the steps outlined here!
http://www.fixya.com/support/t8428898-get
Mar 09, 2011 | Toshiba Satellite X205-S9349 Notebook
What brand bios does this model laptop use? X205-S9349
In the toshiba startup post display, should be a F key promting you to press for setup. Press that F key and it should take you into the bios menu, and your should be able to know what version or who the bios company is.
Jan 31, 2011 | Toshiba Satellite X205-S9349 Notebook
I have an x205-s9349 and the number pad doesnt work at all. i can get the key lock to light up if i press fn f11 but thats it. any ideas?
restart the laptop, if it did't help shutdown and take out the battery, put it back after a minute...
hope this helps...
Sep 06, 2010 | Toshiba Satellite X205-S9349 Notebook
Problem for Toshiba Satellite® X205-S9349 PC Notebook: i get power to the laptop, harddrive flashes a few times, then nothing. No beep sequence. took out ram strips, cleaned them, and reset them...
I have just recently experienced this same issue. My fix was easy. I removed the video card. removed the heat sync. Using a heat gun about 2" away from the backside of the video chip (bga) for about 30 seconds. Then immediately with a doubled up piece of cardboard, press down on the chip for 30 seconds. Let cool, then reassemble. I did this a month ago and still going.
Feb 01, 2010 | Toshiba Satellite X205-S9349 Notebook
I gt power to the pc but it does not boot and the
well on the satellite x205 it could be a couple things. there isnt any beep code? if there is no beep code then it would need atleast a main system board. i worked on 2 last week but they had beep codes (3beeps) which were video cards. in your case pull each stick of ram, then if thats not the case order a main system board.
Nov 05, 2009 | Toshiba Satellite X205-S9349 Notebook
Blank screen on my x205-s9349
when u power up press F8 key u get enble vga mode if it is your resolution problem then enter in wenable vga mode.
Mar 16, 2009 | Toshiba Satellite X205-S9349 Notebook
My toshiba satellite x205-s9349 cannot connect to internet
Despite wireless connections being susceptible to EMI, bluetooth signals do not tend cause the kind of interference that would prevent you from picking up a wifi signal. You say the wifi switch is on, but the bulb is red. (It is supposed to be red, that indicates its powered on). The things to check are to see if you are detecting the wireless signal, are you inputting the proper protocols for any known established wireless Security (WEP/WPA). Are you using a wired connection to get on the internet or another computer/location?
Dec 15, 2008 | Toshiba Satellite X205-S9349 Notebook
Toshiba Satellite® X205-S9349 bios beeping
the beep codes you are getting are for video but if the system boots and you have video im sure it is something with the ram on the video card. unfortunatly this will require a service from toshiba. these cards are intergrated and will require the motherboard to be replaced.
Sep 07, 2008 | Toshiba Satellite X205-S9349 Notebook
Open Questions:
Toshiba Satellite X205-S9349 Notebook Logo
142 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
