Question about Roper RAS6233KQ Top Load Washer
My Roper washing machine is not spinning the water out. It is washing normal but when it comes time to spin it just stops. Please any info would be great. Thanks
  • shonny06 Dec 19, 2008
    Thank you. Your suggestions help a great deal and saved me a lot of money!!!! Thanks
  • 750 Answers
Hello
Welcome to Fixya
My name is Huum,
Three possible reasons are:
Defective Lid Switch
Check lid switch for proper operation. Check the switch for continuity. If it is found to be open, replace the switch assembly.
Defective Motor
If the motor is not running, the pump will not work. Most washing machine use a reversible motor and it is possible for the machine to agitate and not spin or drain.
Defective Water Pump
If the motor is running and water is not pumping it could be a defective water pump. Ensure the tub to pump water hose is clear. If so, replace the pump.
Thank You For trusting us with your guestion
Please remember to leave a rating before you leave!
Posted on Dec 15, 2008
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
Bought used roper washer. worked for first load and now wont work. washes and then the dial satys in same place. Wont empty or spin, nothing.
Hello, Thank You for using FixYa. I will be helping you today. If the unit fills and agitates but wont spin or drain the yourlid switch is bad..Here is a link to order the part and a how to video
http://www.repairclinic.com/PartDetail/Lid-Switch-Assembly/3949247/547225
Thank You and please ACCEPT my answer and Rate my answer if it was helpful..
Jul 02, 2011 | Roper RAS8445KQ Top Load Washer
WASHER WILL WASH ON ALL CYCLES, BUT WILL NOT DRAIN OR SPIN ON EITHER CYCLE
If the timer advances normally thru the spin and drain steps of the cycle you selected, than the problem that would cause neither spinning or draining, is the wash motor is not reversing. The motors is a two direction motor. It spins clockwise for normal agitation, but counterclockwise to engage the wash drum clutch and operate the drain pump. I would ask you to check for motor sounds at all during the spin and drain cycles. The pump reversing in the spin or drain cycles can be a function of the machine's lid safety switch, or if not the motor switch or timer contacts. The lid switch is first thing to check here, for sure! If the machine seems to stop running when it comes time to drain or spin, the lid switch is your best bet!
Hope this helps.
kcomp1863
Jan 16, 2011 | Roper RAS8445KQ Top Load Washer
My roper washing machine will not empy out or spin. It agitates alright but stops when it comes to emptying the water and going into the spin cycle.
If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Replace the lid switch with this part.
Dec 27, 2010 | Roper RAS8445KQ Top Load Washer
Washing machine stops before rinsing
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 31, 2010 | Roper RAS8445KQ Top Load Washer
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
My washing machine wont spin
How do you open the top to replace the lid switch?
Oct 11, 2008 | Roper RAS6233KQ Top Load Washer
Roper (Whirlpool) Washer
ohm out the lid switch, with the switch closed it should read contunity if it does not then the lid switch is the issue
Apr 19, 2008 | Roper RAB2121KW Top Load Washer
Roper RAS6233KQ Top Load Washer Logo
147 people viewed this question
Top Roper Washing Machines Experts
Marvin
Marvin
Mike
Sal De
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
