Question about EliteGroup P4VMM2 Motherboard
Help... i heard 3 beeps on, try changing my memory with new one but the problem still exist..need help badly...
  • joseph morris simbajon Mar 19, 2007
    sirs i've tried all of these but nothings happen..i suspect the motherboard is busted..tried new memory and graphics card but the problem still there..
  • 944 Answers
Here is the appropriate link for the manual and driver/bios downloads; http://www.ecs.com.tw/ECSWebSite/Products/ProductsDetail.aspx?CategoryID=1&TypeID=1&DetailID=277&DetailName=Feature&MenuID=1&LanID=9 Unfortunately nothing about error beeps. I would suspect the graphics card, try uninstalling and removing it and start from scratch. Try and update your bios if you can, http://www.ecs.com.tw/ECSWebSite/Support/Category_Support.aspx?MenuID=3&LanID=9 if you get no luck with this then try the Clr CMOS procedure as described in the manual, also remove the cmos battery and replace, ideally with a new one (should be a CR-2302) Hope this helps :)
Posted on Mar 17, 2007
  • Nigel Ridehalgh
    Nigel Ridehalgh Mar 19, 2007
    Unfortunately sounds like you are right. Sorry we couldn't fixya.
Beeps on motherboard can mean 3 things: 1. memory out (or corupted) 2. vga card out (or corupted) 3. mother board is corupted try to take out the memory and the vga card and place them back on you can go and read you motherboard manual and look exactly what 3 beeps means..
My computer does not boot
The reason with your laptop does not boot is power chord does not plug in...memory problem...operating system and corrupted hdd...
Check the power chord if properly plug to the outlet Check the memory if you heard 3 beep or 8 beep...if you hear 3 beep...the memory is not installed properly...check and install properly...if you hear 8 beep you need to replace the memory with new one...if you hear a continuous beep...the memory...discard the memory...open the laptop then off immediately...then install the memory again...
if the problem still exist...
Please go to the nearest repair center to fix the problem. Because it is very fatal and need assistance from a technician
Sep 21, 2011 | Toshiba Satellite P105-S6197 Laptop
What is the beep code asus p5ntws
AMI (American Megatrends International) BIOS Beep Codes.
AMI BIOS uses beeps of the same length and pitch. The error is displayed as a number of beeps. For example, 4 beeps indicated a timer failure.
BEEP CODE MEANING POSSIBLE CAUSE
1 Beep (No video) Memory refresh failure Bad memory
2 Beeps Memory parity error Bad memory
3 Beeps Base 64K mem failure Bad memory
4 Beeps Timer not operational Bad motherboard
5 Beeps Processor error Bad processor
6 Beeps 8042 Gate A20 failure Bad CPU or Motherboard
7 Beeps Processor exception Bad processor
8 Beeps Video memory error Bad video card or memory
9 Beeps ROM checksum error Bad BIOS
10 Beeps CMOS checksum error Bad motherboard
11 Beeps Cache memory bad Bad CPU or motherboard
Award BIOS Beep Codes
Award BIOS uses beeps of varying duration. A long beep will typically last for 2 seconds while a short beep will last only 1 second. Award BIOS also uses beeps of different frequency to indicate critical errors. If an Award BIOS detects that the CPU is overheating it may play a high pitched repeating beep while the computer is running.
1 Long, 2 Short Video adapter failure Bad video adapter
Repeating (Endless loop) Memory error Bad memory or bad connection
1 Long, 3 Short Video adapter failure Bad video adapter or memory
High freq. beeps (while running) CPU is overheating CPU fan failure
Repeating High, Low beeps CPU failure Bad processor
Phoenix BIOS Beep Codes
Phoenix BIOS uses beep code patterns to indicate problems. In the table below the '-' indicates a brief pause between beeps.
Example: 1 - 1 - 2 would sound like BEEP <pause> BEEP <pause> BEEP BEEP
1 - 1 - 2 CPU / motherboard failure Bad CPU / motherboard
1 - 1 - 3 CMOS read/write failure Bad motherboard
1 - 1 - 4 BIOS ROM failure Bad BIOS chip
1 - 2 - 1 Timer failure Bad motherboard
1 - 2 - 2 DMA failure Bad motherboard
1 - 2 - 3 DMA failure Bad motherboard
1 - 3 - 1 Memory refresh failure Bad memory
1 - 3 - 2 64K memory failure Bad memory
1 - 3 - 3 64K memory failure Bad memory
1 - 3 - 4 64K memory failure Bad memory
1 - 4 - 1 Address line failure Bad memory
1 - 4 - 2 Parity error Bad memory
1 - 4 - 3 Timer failure Bad motherboard
1 - 4 - 4 NMI port failure Bad motherboard
2 - 1 - 1 64K memory failure Bad memory
2 - 1 - 2 64K memory failure Bad memory
2 - 1 - 3 64K memory failure Bad memory
2 - 1 - 4 64K memory failure Bad memory
2 - 2 - 1 64K memory failure Bad memory
2 - 2 - 2 64K memory failure Bad memory
2 - 2 - 3 64K memory failure Bad memory
2 - 2 - 4 64K memory failure Bad memory
2 - 3 - 1 64K memory failure Bad memory
2 - 3 - 2 64K memory failure Bad memory
2 - 3 - 3 64K memory failure Bad memory
2 - 3 - 4 64K memory failure Bad memory
2 - 4 - 1 64K memory failure Bad memory
2 - 4 - 2 64K memory failure Bad memory
2 - 4 - 4 64K memory failure Bad memory
3 - 1 - 1 Slave DMA failure Bad motherboard
3 - 1 - 2 Master DMA failure Bad motherboard
3 - 1 - 3 Interrupt controller failure Bad motherboard
3 - 1 -4 Slave IC failure Bad motherboard
3 - 2 -2 Interrupt Controller failure Bad motherboard
3 - 2 - 3 <RESERVED>
3 - 2 - 4 Keyboard control failure Bad motherboard
3 - 3 - 1 CMOS batter failure Bad CMOS battery
3 - 3 - 2 CMOS configuration error Incorrect setting
3 - 3 - 3 <RESERVED>
3 - 3 - 4 Video memory failure Bad video card or memory
3 - 4 - 1 Video init failure Bad video card or memory
4 - 2 - 1 Timer failure Bad motherboard
4 - 2 - 2 CMOS shutdown failure Bad motherboard
4 - 2 - 3 Gate A20 failure Bad motherboard
4 - 2 - 4 Unexpected interrupt Bad processor
4 - 3 - 1 RAM test failure Bad memory
4 - 3 - 3 Timer failure Bad motherboard
4 - 3 - 4 RTC failure Bad motherboard
4 - 4 - 1 Serial port failure Bad motherboard
4 - 4 - 2 Parallel port failure Bad motherboard
4 - 4 - 3 Coprocessor failure Bad motherboard or CPU.
9 - 2 - 1 Video adapter incompatibility Use a different brand of video card
Apr 20, 2010 | ASUS P5NT WS (P5NT WS GREEN) Motherboard
My g40 will not boot up when i turn it on it beeps 3 time with equal time between beeps and then shuts off never getting the screen ti light up
The beeps indicate that you have a RAM memory problem. Did you install new RAM lately? If yes then try removing the new RAM module and try again. If not then maybe your existing memory module has gone bad. Try replacing the RAM memory.
Feb 03, 2010 | Computers & Internet
One long beep tone---NO Display on monitor(monitor checked ok)
Definitely not your monitor. It is either a CPU or a Memory problem, is this a new build or did an existing computer suddenly start doing this?
Is that your motherboard, the Gigabyte 7VM400M ?
Jun 26, 2009 | Gigabyte 7VM400M-RZ (GA-7VM400M-RZ)...
Ok i received my new pc yesterday and installed windows vista etc, it was working great. This morning i woke up and turned my computer on and i heard 3 short beeps which were continuous and never stopped,...
3-3 is either video card or memory related.  Try to reseat your video card and see if that helps.  If nothing still, try to reseat the RAM.  If that doesn't work, try another video card.  If that doesn't work, try different memory.  If all that doesn't work, let me know and I will see what else I can do to help you out.  But from my experience, it is almost always RAM related.
Mar 02, 2009 | Evga e-GeForce 8600GT, GeForce 8600 GT,...
I put a 1gb expansion ram in my toshiba satellite M35X-S149.  Did it with the battery out.  Put the new ram in the empth slot - - 256 mb in the other slot from the factory.  When I turned on the power, the...
Remove the 1 gig chip. Pull you battery out and unplug the laptop. Hold the power button in for 10 seconds. Put the battery back in and plug the laptop back in again and try booting it up. This should reset the BIOS and allow it to boot. The beep codes you are talking about are a memory beep code and it is normally caused by adding memory or a loose memory stick. Also try pulling the existing memory and resetting it.
Dec 20, 2008 | Toshiba Satellite M35X-S149 Notebook
BEEP ON START UP ,BLANK SCREEN
3 long beeps normally indicate defective memory or loose memory on DIMM so take out and insert it again or you need to replace with new memory module. Where as fast beeping indicates Graphics error and need to change the graphic card
If this dont fix please tell me
Best Luck!
Dec 05, 2008 | Computers & Internet
Memory Wrire Read error please please please help.
well sir/mam ...........................as there are 3 beeps heard when u insert da ram in the slot...it seems that u'r ram is not working ......and there is a need that u change the ram immediately without tryin da same procedure again ..............this wud surely help u get out oft this problem .
Sep 07, 2008 | Dell Dimension 4300 PC Desktop
No screen, 2 rounds of 1long beep+3 short beeps; doing for a while
It may be the cause of the video problem due to the single beep and following 3 beep.clean the memory slot and insert th memory again,that is also a remedy for the problem.check a new memory by inserting in the slot also.I think it may solve the problem
Feb 06, 2008 | Toshiba Satellite M35X-S163 Notebook
EliteGroup P4VMM2 Motherboard Logo
165 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Iqbal Husain
Iqbal Husain
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
