Question about Toshiba Satellite X205-S9349 Notebook
My toshiba satellite x205-s9349 cannot connect to internet
Can bluetooth cause this prob...my wifi switch is on but bulb is red
Despite wireless connections being susceptible to EMI, bluetooth signals do not tend cause the kind of interference that would prevent you from picking up a wifi signal. You say the wifi switch is on, but the bulb is red. (It is supposed to be red, that indicates its powered on). The things to check are to see if you are detecting the wireless signal, are you inputting the proper protocols for any known established wireless Security (WEP/WPA). Are you using a wired connection to get on the internet or another computer/location?
Posted on Jun 26, 2009
Where is the jumper located on the Toshiba satellite x205-s9349 motherboard? i need to reset my bios password and on this model i cannot find it.
Pointing you to another FixYa member who had the same problem. Follow the steps outlined here!
http://www.fixya.com/support/t8428898-get
Mar 09, 2011 | Toshiba Satellite X205-S9349 Notebook
What brand bios does this model laptop use? X205-S9349
In the toshiba startup post display, should be a F key promting you to press for setup. Press that F key and it should take you into the bios menu, and your should be able to know what version or who the bios company is.
Jan 31, 2011 | Toshiba Satellite X205-S9349 Notebook
I am working on a satellite X205-S9349. The backlight is working, but the screen is blank. The screen works on an external monitor. The battery is good and so is the power source. The memory doesn't seem...
switch off the laptop
press" o"(zero)and start laptop until start restore option .for windows XP
start and pres f-8 your system will soon start ,
Please follow the bellow link ,
Choice the brand and OS
http://www.pcrecoverydisks.com/toshiba/toshiba-system-restore-vista/
You can purchase your recovery disk follow the link.go step by step
http://www.restoredisks.com/findrestoredisk.aspx
Hope this helps.
If you are helped you can rate on the 4 thumbs and post a short comment,because,
this is the free side and I can get the chance, to help people like you .
Thanks for using fixya .
Jan 26, 2011 | Toshiba Satellite X205-S9349 Notebook
I have an x205-s9349 and the number pad doesnt work at all. i can get the key lock to light up if i press fn f11 but thats it. any ideas?
restart the laptop, if it did't help shutdown and take out the battery, put it back after a minute...
hope this helps...
Sep 06, 2010 | Toshiba Satellite X205-S9349 Notebook
Problem for Toshiba Satellite® X205-S9349 PC Notebook: i get power to the laptop, harddrive flashes a few times, then nothing. No beep sequence. took out ram strips, cleaned them, and reset them...
I have just recently experienced this same issue. My fix was easy. I removed the video card. removed the heat sync. Using a heat gun about 2" away from the backside of the video chip (bga) for about 30 seconds. Then immediately with a doubled up piece of cardboard, press down on the chip for 30 seconds. Let cool, then reassemble. I did this a month ago and still going.
Feb 01, 2010 | Toshiba Satellite X205-S9349 Notebook
I gt power to the pc but it does not boot and the
well on the satellite x205 it could be a couple things. there isnt any beep code? if there is no beep code then it would need atleast a main system board. i worked on 2 last week but they had beep codes (3beeps) which were video cards. in your case pull each stick of ram, then if thats not the case order a main system board.
Nov 05, 2009 | Toshiba Satellite X205-S9349 Notebook
Blank screen on my x205-s9349
when u power up press F8 key u get enble vga mode if it is your resolution problem then enter in wenable vga mode.
Mar 16, 2009 | Toshiba Satellite X205-S9349 Notebook
Toshiba Satellite® X205-S9349 bios beeping
the beep codes you are getting are for video but if the system boots and you have video im sure it is something with the ram on the video card. unfortunatly this will require a service from toshiba. these cards are intergrated and will require the motherboard to be replaced.
Sep 07, 2008 | Toshiba Satellite X205-S9349 Notebook
Open Questions:
Toshiba Satellite X205-S9349 Notebook Logo
192 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
