Question about HP Media Center m7060n PC Desktop
Power switch is broken
How can I obtain a new plastic power switch?
  • 111 Answers
From hp
Posted on Dec 21, 2008
I have a Samsung Galaxy 7.0 plus table and my power button is broken and so is the up and down volume button and I cant get my tablet on is there any other way I can get it on
Behind the plastic power button is a tiny metal switch. If just the button is broken, use a tiny plastic tool to push the switch. But if the switch is also broken, I recommend returning the tablet for a refund or replacement if it is still covered by the factory warranty.
Fixing a broken power switch is delicate work and may cost more than the value of the tablet.
Nov 27, 2017 | Samsung Tablets & eReaders
Samsung notebook N150 on/off switch broken
One of two things is broken. 1) the rear fork of the plastic switch is suseptable to bending a breakage. 2) The springloaded switch whick is soldered to the base circuitboard could also be broken.
Jun 05, 2011 | Samsung Tablets & eReaders
The plastic on/off switch behind which is the actual switch mechanism has come off and has been lost. Where can I obtain a replacement plastic part ?
Actually those parts are available at your product accredited service center, you can't find it on stores.
thanks & sorry if I can't provide any info, but its the only way to find replacement for your phone power button.
Mar 22, 2011 | Palm Pre Cell Phone
How do you reset a karcher pressure washer
The Knob is broken off of the Plastic Shaft..to the switch assembly.
A new switch assembly is available direct from Karcher.
May 24, 2010 | Karcher K2.26 Electric Power Washer
Power switch on off Acer 5720
If the plastic cover is broken or gone, you can order the part (bezel) from Acer. If the power button 'clicks' but the laptop won't power on then you probably need a new mainboard. If no power, try with another a/c adapter first.
Hope this helps!....let me know what happens.
Dec 12, 2009 | Computers & Internet
Red plastic cover over starter switch is broken. No power
If you can't get the power switch to work that is a good indication that it might be broken and the fuse has blown to protect you and the organ. At this point you have two choices. Get someone who knows what they are doing to have a look at it and replace the broken parts or if you feel comfortable with trying, do it yourself. You will have to unplug it from the wall and carefully take it apart until you can get at the switch. Before you do this though consider that you will at least need a new switch and fuse. The switch doesn't have to be an exact replacement it just has to be electronically equivalent. Make sure you have a place to buy the parts.Keep track of what you do and draw diagrams you can understand. Better yet if you have a digital camera take pictures. Once you have the switch out the info about the switch is usually stamped on the switch itself.Take the switch and fuse to the store and they should be able to sell you what you need. Replace the switch by reversing the steps you took to remove it. Do the fuse last and once the organ is assembled plug it back in and turn the switch on. I f you replaced the switch exactly the way it should be the organ will either work or the fuse will blow again. If the fuse blows you know there is something else wrong. At this point you will need help or if you are going further on your own you will need a schematic or a service manual. They are getting hard to obtain so you will probably be better off having a professional look at it. Please let me know if this helps.
Dec 02, 2009 | Boss Micro BR Digital Recorder
Power button won't stay locked when pushed on. If held in with a screwdriver then the tv will power up ok. Could it be the spring on the switch?
The spring is okay if the switch is coming back to the normal (Off) position by itself. It seems that the lock which hods the spring in position is broken or has worn out. In most of the cases the lock is not repairable and you will need to change the switch itself.
Jul 13, 2009 | Thomson 24WK25U 24" TV
Power Board Problem and Power Button Hinges Top Cover broken
It would be cheaper to have the power board repaired but the replacement is around $55 from ebay. I'd get a new moulding for it if its available or even if you got somthing plastic welded up.
http://cgi.ebay.com/Acer-Aspire-3050-3680-5050-Power-Board-w-dc-jack-usb_W0QQitemZ120415274982QQihZ002QQcategoryZ158887QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Hope this helps
May 06, 2009 | Acer Aspire 3680 Laptop
Dimension E510 LCD Monitor with broken power switch
Thanks for responding. Nothing happened when you pressed in the power button and the warranty had expired; Dell was no help so don't bother. I read that there were tab(s) on the plastic power button that had broken off and no longer engaged the power switch. I "solved" my monitor problem by drilling through the plastic case between the power button and the minus button, pulled out the plastic power button and pressed the switch with a flat screwdriver to turn on the monitor. Now I leave the power on all the time and put a piece of black masking tape over the space where the power button was. Not the best solution I'm sure, the hole isn't pretty, but it works. If anyone else wants to try this solution be careful when you drill through the plastic case because the switch you want to engage occupies the space between the buttons, exactly where you are drilling. If you drill through the switch you might as well throw the monitor into the recycle bin. I expected to find an actual button switch and was surprised to find a flat, 2 prong circuit switch instead. Good luck to all.
Matt
Aug 22, 2008 | Dell Dimension 2400 PC Desktop
Whirlpool Control Panel Repair
model # MH6150XLQ
LOST POWER. I CHECKED WALL RECEPTACLE. IT'S GOT POWER.
MICROWAVE IS DEAD. NO LIGHT..........NOTHING.
WHAT'S HAPPENED?
Apr 30, 2008 | Whirlpool GH7145XF Microwave Oven
HP Media Center m7060n PC Desktop Logo
77 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
