Question about Mitsubishi WD-52631 52" Projection HDTV
What are the best video settings for wd-52631 mitsubishi tv?
What are best settings?
billyjones69
  • 42 Answers
SOURCE: amber system light is on
The air flow is being blocked. Be sure that the sides of the set are not restricting air flow to the tv. If the unite is in a tight entertainment center it cannot get air flow.
Billy
Posted on Jan 14, 2008
  • 3422 Answers
SOURCE: Outer screen scratch
You can try for the parts from HERE or from HERE
Goodluck,
Please don't forget to rate the solution.
Posted on Mar 27, 2008
Luvlee
  • 59 Answers
SOURCE: smell from mitsubishi wd-52631
Hi...maybe I can help. Go back in and make sure your lamp is connected to the ballast. If it is not all the way in, it will smell like it is burning. Sometime it will even burn out you lamp and or ballast too. Good luck
Posted on Mar 28, 2008
SOURCE: Mitsubishi WD-52631 HD TV lamp problems
After contacting mitsubishi again i have found out the problem they say is a design fla the filter on the back the mesh gets filled with dust and then over heats .
Its funny that soon as I told Mits about what tv I had and how long i had the 2nd bulb they told me we will have on out to you as soon as 2-3 days?????
I do have a service guy looking into a new balace,, thats his thought. All I know is Mits has been put on my sh*t list of tv not to buy
Posted on Jul 17, 2008
SOURCE: WD-52631 Red Light-No Picture, still have Sound
unplug it from the wall, wait 30 seconds, then plug it back in. i had the same problem and this simple solution worked for me. Good Luck!!!!
Posted on Feb 17, 2009
Mitsubishi is currently offering the following parts
Model Number Model Description Part Number Part Description Price Available WD-52631 52" DLP TV I/B WD52631 OWNERS GUIDE $15.00 YES WD-52631 52" DLP TV I/QR WD52631 QUICK/REF WD52631/57731/65731 'G' $3.50 YES WD-52631 52" DLP TV 915P049010 LAMP (150W) (V33/V33Y/V33+) 'G' $249.00 YES WD-52631 52" DLP TV 290P137010 REMOTE 'G' $33.10 YES
Mar 27, 2008 | Mitsubishi WD-52631 52" Projection HDTV
How can you diagnose a failed lamp in a Mitsubishi DLP WD 52631
Remove the lamp and do a visual inspection.
If this is a DLP you may have a bad color wheel! whistling sound is a sign of color wheel.
Good luck to you
www.aaatvservice.com
May 08, 2012 | Mitsubishi TV Lamp 915P049010 for WD-52631...
Misubishi wd-52631 DLP TV, it shuts off suddeny. when turn it on again, the green power light is flashing, then steady green, then shut off again. the lamp light is NOT falshing or red. the status light...
Hi, have you replaced the lamp after 2-3 yrs of usage? The lamps used by mitsubishi tend to last around 4000 hrs 1-3 yrs.It is common for the green light to light up.Other common failures are the ballast which is the board that powers the lamp.Also check if its not overheatin, dust out the fans.Heres where u can get the lamp or ballast http://www.discount-merchant.com/SearchResults.asp?Search=wd-52631
Apr 19, 2011 | Mitsubishi WD-52631 52" Projection HDTV
My Misubishi WD-52631 DLP TV is off sudenly. I turn it on again, but no picture, no sound, nothing happened. I reset it, nothing happends. the green power light blinks for a while, then shut off itself....
Tv LED "LAMP" light indication is blinking?And ur tv projection lamp inside ur tv been used like 1 1/2 or 2 years.Yes.The tv projection lamp require changing,tv projection lamp life are ended.
My Mitsubishi WD-52631 went "POP"
No,probally a capacitor the help the power supply board to work or other boards to work is blown.Call some tv shops get a best quotes prices,get a tv tech out to it fix,if ur tv is out of warrenty.
Jun 17, 2010 | Mitsubishi WD-52631 52" Projection HDTV
Dec 13, 2008 | Mitsubishi WD-52327 52" Rear Projection...
Smell from mitsubishi wd-52631
Mar 28, 2008 | Mitsubishi WD-52631 52" Projection HDTV
Mitsubishi 52 " model WD-52631
Nope the bulb is fine. This set sucks up dust and contaminates the light engine. Rarley does blowing the set out with compressed air fix this, The light engine can be disassembled and cleaned but this is best left to someone who has done this once before. Because if it gets messed up you get to buy a $1500.00 light engine
Feb 13, 2008 | Mitsubishi WD-52631 52" Projection HDTV
Mitsubishi WD-52631 52" Projection HDTV Logo
134 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
