Question about AEG Lavamat 16810 Front Load Washer/Dryer
Washing Machines slowly fills with water over a few days
My AEG washing machines slowly fills with water over a few days when left alone. Any ideas what it could be and how it can be fixed? Thanks in advance!
    President:
  • 1,462 Answers
Could be leaking inlet valve or if drain is plkumbed in unbder sink, could be filling thro drain pipe when you emptyt sink
Posted on Mar 20, 2007
My aeg lavamat 73620 fills water in the wrong compartment. How do I take out the powder-dosing unit to clean it?
with all the machines ive had you pull it out and lift it up at the same time, then give it a good wash when you put it back you have it upright and slowly lower it as you push it in, don't try and force it.
Nov 22, 2014 | AEG Washing Machines
On my AEG Lavamat 62810 washing machine, when I start a wash cycle the motor (pump?) runs for 10–20 seconds then the machine switches off, with no error message and no water having entered the machine....
inside the waasher there is a fill level valve i think its blocked up with "gunk" if you look inside the washer you should see a small pipe from the bottom of the drum going up to a round type of valve with lots of wires fitted to it at the top of the washer,,,pull the pipe off this valve and "blow hard" down through it,,any "gunk" should be pushed out and the washer should wook ok after that,,,if it dont change the valve!!!
Aug 12, 2010 | AEG Washing Machines
I need a motherboard for a aeg lavamat l62622
I have an AEG WITH ERROR CODE C9 IT WONT SPIN OR WASH ,COUNTS DOWN THE CYCLE ,FILLS BUT CLOTHES ARE LEFT A STICKY MESS ,MOTOR AND BUSHES ARE FINE ,I HAVE RESET NUMEROUS TIMES BUT STILL GOES TO C9 ANY IDEAS
Feb 26, 2010 | AEG Washing Machines
Code E10 shown . Machine is in an outhouse.It's very cold.
Problems during water filling phase – washing
(Machine tries to fill for 10 min without reaching the level)
check pipes are not frozen... and valve is operational... should buzz when calling for water....
Jan 04, 2010 | AEG Washing Machines
AEG 62600 Will not fill. Hose from tap is clear. Help
Try filling with hot and cold water, the water valve solenoid may have failed.
Jun 01, 2009 | AEG Washing Machines
No water is entering our aeg lavamat 74600 any ideas welcome !
First check the obvious.
Make sure water is connected and turned on.
Make sure timer is set to correct position.
If everything is hooked up properly (it probably is) then check your fill solenoid assembly.
That is probably your problem.
Apr 16, 2009 | AEG Lavamat 72640 Front Load Washer
Washing machine growls slightly when filling with water but only on cold setting.
try shutting off water slowly till sound disappers if washer fills ok leave it alone a new fill valve may help but if works ok save your money
Jul 17, 2008 | Washing Machines
AEG washing machine stops without heating
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too. Check out yr user's manual.
Rate me pl.....if helped.
Jan 21, 2008 | Washing Machines
are the holes that spray out the water partially blocked? if so the water will spray out at every angle filling all the tray slots. try popping out the soap tray and cleaning above it with a stiff washing up brush and then reducing the water pressure by turning the tap off a bit.
May 18, 2007 | AEG Lavamat 72640 Front Load Washer
Aeg washing machine
you may have blockage in pipe from drawer to tub but more likely the soap drawer is clogged. take it right out and clean thoroughly
Mar 21, 2007 | AEG Lavamat W1050 Front Load Washer
AEG Lavamat 16810 Front Load Washer/Dryer Logo
192 people viewed this question
Top AEG Washing Machines Experts
shaun taylor
mikenearman
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
