Question about Frigidaire Washing Machines
My washer at the end of all the washing, spinning..etc...display the code EFO and all lights are opened...what does it mean. and I would to know if there is a listing of all the error codes and the meaning of each. Sorry if my English writing is not pefect...I'm a frenh Canadian and nowhere write french...
Posted on Apr 23, 2009
EFO code cameup.
Its not EFO its EF0 .Theremust be some thing blocking the pump .For example socks,underwear etc. The water was not cycling through properly. Cleaned it out and everything works fine.Use proper detergent mentioned for your model because even SUD formation can cause this error.
Jun 18, 2010 | Frigidaire Affinity ATF7000E Front Load...
While washing the letters EFO flash. what does this mean?
If your washer displays EFO it means that you are not using HE detergent. You must have used too much detergent on a particular load.You have to use He detergents to fix this issue or else not using it will ruin your washer because regular soap makes too much suds.
Thank you!
May 28, 2010 | Frigidaire Affinity ATF7000E Front Load...
Affinity ATF7000E Front Load Washer: where do i find what efo means on my affinity wash...
Frigidaire, Zanussi, AEG, & More....
EFO = Filter Blocked (low flow) and it is accessible from the bottom front of the machine.
1. there is a blockage in the filter or drain hose.takes too long to drain out.
2. over dosing of powder or liquid. again can cause an air lock in the pump which slows the drain pump down.
Check the filter and drain hose and test again. this fault will only come up at the end of a cycle.
You do not need to reset the machine to get rid of the fault code as this is automatically deleted.
Run an empty load with no detergent in an attempt to get rid of the code.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
May 16, 2010 | Frigidaire Affinity ATF7000E Front Load...
What does it mean when washer says efo on screen
Thank you!
May 10, 2010 | Frigidaire ATF6000ES Front Load Washer
EFO error code
Jul 04, 2009 | Frigidaire GLTF2940ES Front Load Washer
My front loader washer displays the letters "EFO", what does it mean
It can mean one of two things. You did not use an HE ( High energy detergent) or you used to much so there are too many suds in the washer. It can also mean that if you are using warm water, the hot water is not coming in, so you would need to make sure the hoses are connected correctly, the hot water is turned all the way on and that the little filter at the end of the hose (washer end) is clean.
Thanks
Jul 01, 2009 | Frigidaire Affinity ATF6000F Front Load...
EFO displayed on my machine while running and beeped.
EFO is not a Kenmore Error Code.
Zanussi & AEG EFO = Filter Blocked (low flow) and it is accessible from the bottom front of the machine.
May 15, 2009 | Kenmore 44102 Front Load Washer
Error code EFO or EF0 I can't tell the difference.
You need to refer to the owners manual in trouble shooting catagory, if you can't find yur answer there contact Fridgadaire ither by phone or e-mail and choose the help section.
Jan 05, 2009 | Frigidaire ATF6000ES Front Load Washer
What does efo mean
Electrolux Washer Fault Code for EFO or EF0
Drain Filter is Clogged. Resolution => Click lint filter for soap buildup or other debris. Check drain hose.
Oversudsing - A high efficiency detergent was not used.
Too much detergent was added. Resolution => Use only a high efficiency detergent. Follow manufacturer's recommendation for dosage. Amount may need to be adjusted for water temperature,
water hardness, load size and soil level.
Hot water doesn't enter washer - Hot water hose is connected to the wrong faucet. Hot water faucet is not turned on. Resolution => Connect hot water hose to hot water faucet and hot inlet on
washer. Be sure hot water faucet is fully opened. Check water heater.
Jan 03, 2009 | Crosley CW5000 Front Load Washer
Flashing EFO error code
spoke with electrolux and they tell me that it is over sudsing problem. The washer must use HE detergent or use only a the lowest amount on the cup.
Jul 19, 2008 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
597 people viewed this question
Top Frigidaire Washing Machines Experts
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
