Question about Kodak EasyShare C315 Digital Camera
Kodak 2gb memory card picture shows on camera but not computer
I have a Kodak Easy Share Cd1013 and a Kodak 2gb sd memory card. Most of the pictures on the card have transferred well, however, there are a few that won't. If I view the pictures on the camera I can see them, however when I transfer them from the memory card to the computer, only half the picture shows up. The other half is fuzzy green and gray lines. Is there anything I can do?
  • remya_tharun Jan 11, 2009
    ONLY HALF OF THE PICS SHOW UP AFTR UPLOADING..BUT I CAN SEE THEM WHILE REVIEWING IN THE CAM..PLS HELP TO SOLVE THE PROBLEM
    AND ALSO THE CARD WORKS WELL WHILE TAKEN TO TAKE PRINTS..SO I DONT THINK THE PROBLEM IS WITH CARD..
  • 684 Answers
The Memory card is defective if u continue to use the same memory card more pictures which u take may spoil so pls try to use a diffrent memory card it will work fine.........
Posted on Dec 15, 2008
Kodak easy share c183 memory card protected how to reset
Camera LCD: "Memory card is protected (Reset ... - Kodak
support.en.kodak.com/.../camera-lcd%3A-memory-card-is-protect...
KodakAug 25, 2010 - The camera screen displays "Memory card is protected (Reset switch on card). ... The memory card is locked so that data (pictures, videos, or files) ... The disk is write protected." when writing to or formatting an SD card. Share.
[PDF]KODAK EASYSHARE C183 Digital Camera
resources.kodak.com/support/pdf/en/manuals/.../C183_xUG_GLB_en.pd...
Kodak, EasyShare, Max, Perfect Touch, and Pulse are trademarks of Eastman Kodak. Company. ..... Access to more manual settings than Smart Capture mode. ..... NOTE: To delete protected pictures/videos, remove protection before deleting.
Jan 26, 2016 | Kodak Easyshare C183
I have a Kodak easy share z740 and it won't let me
What type and size memory card?
The Z740 works with MMC and SD cards, 2GB or smaller. I suspect you're trying to use an SDHC card, 4GB or larger.
Sep 05, 2014 | Cameras
Mi camara digital kodak c195 dice internal memory is full
The internal memory is very small and will only take a few pictures. Just enough to test the camera. Your camera also accepts SD and SDHC cards, which are not expensive. You can put lots of pictures on the SD or SDHC cards.
You also could connect the camera to a PC or MAC and send the pictures over after you installed Kodak Picture easy share.
After you backed up the pictures that way, you can delete the pictures in the camera. Always make sure you have at least 2 backups from your pictures.
May 02, 2014 | Kodak Easyshare C182 12MP Digital Camera
Memory card says full when i put new sd 2gb card in card won't work on my kodak easyshare cw330 camera
I was checking to see if your camera had a limit to the size of SD memory card and couldn't find a thing so what I suspect is that the SD card lock has been engaged here is a diagram to show you how to unlock it.
Also any new memory card needs to be formatted in the camera before the camera can "read" it.
After pictures have been loaded to the memory card and then downloaded to the computer the memory card needs to be formatted to clean the old pictures off and make the memory card ready to accept new pictures.
Dec 30, 2010 | Kodak EASYSHARE CW330 Digital Camera
I have a Kodak EasyShare camera and I'm having trouble downloading pictures.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program.
Nov 29, 2010 | Kodak EASYSHARE CD1013 Digital camera ...
Why can't my kodak easy share cd1013 download from my camera
Having gone over a month without a response, I assume this is no longer a problem.
Jun 27, 2010 | Kodak EASYSHARE CD1013 Digital camera ...
How to download pics. from my camera to my computer
Question :
How do I transfer pictures from the internal memory of my KODAK Digital Camera to a memory card? Answer :
Follow these steps:
  1. On the camera, press Review and then Menu.
  2. Select Image Storage.
  3. Change to Internal Memory.
  4. In the menu listing, scroll down to Copy, and select OK.
  5. Select a single picture, or select All.
When you have finished copying pictures, reset the Image Storage location to your original setting.
Once your pictures are transferred to the SD card it will be easy to transferre onto the computer.
Dec 12, 2009 | Kodak Easyshare C813 Digital Camera
SD Memory Card
Yes is should work you can used atmost 2GB SD card, but do not use more than 2GB SD card
Nov 19, 2009 | Kodak EasyShare DX7590 Digital Camera
Kodak Easy Share CD1013 pictures won't download on Vista
Hello and welcome to FixYa
Please go to a electronics store and buy a USB card reader. I bought one last week and it cost $0.5 so its cheap as dirt. Then simply remove the card from your camera , pop it into the reader and the pictures will appear on a drive like a flashdrive in your my computer folder.
This is a much better option than using the camera's cable as it is faster , safer , saves on your camera battery and you don't need to install any software or drivers.
The card reader will most likely also still be compatible with any new camera you buy in future.
Kind Regards
Andrea
Mar 24, 2009 | Kodak EasyShare One Digital Camera
Kodak EasyShare C315 Digital Camera Logo
240 people viewed this question
Top Kodak Cameras Experts
Tony
Are you a Kodak Camera Expert? Answer questions, earn points and help others
