Need drivers for modem
I need to replace a defective modem on a my pc but the modem am replacing it with I don't have the driver for it, I don't know who manufactured it, or the make. I have the model no. AM-56KI-LU
    Guru:
  • 133 Answers
This site will help you alot.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} http://www.edriverdownload.com/
Goodluck :)
Posted on Dec 11, 2009
  • 43 Answers
Go to http://www.driversdoctor.com/?key=Modem and key in that info.
Posted on Dec 15, 2008
I have a reconditionned DELL Precision M3400 laptop that was factory reset when I bought it. I have had to turn on all the hard drives etc. but I am having trouble getting the internal modem to turn on. It...
Usually the recondition, or refurbished product from Dell have been retested to ensure they meet all original factory specifications. I don't understand why your modem and cd rom drive don't work. How long had you purchased it? When you said you can't get internal modem to turn on, you meant it not working?
There are only two things could happen to each of them (modem and cd rom drive) For Modem: please check it through device manager, and modem to see if it has red x or yellow question mark, or says unknown device, if you do have one of these, you need to install correct driver. Please check your Dell service tag number (it is on white sticker on back of laptop), and go to dell.com, support, and select driver and downloads, key in your service tag number, and download the modem driver to install. If it still doesn't work, then the physical internal modem is the faulty one. For your CD rom drive, it should work with just standard driver preloaded by the OS, you don't need to install driver for. It is either dirty, needs to be cleaned by the CD room cleaner disc, or it is bad. You can try to reseat by trying to take whole thing out and insert it back in. If you have Dell diagnostic cd (usually comes with your laptop when ordered) to run hardware diagnostic to find out the faulty one.
This is the common issue with refurbished laptops (most common issue is with keyboard). When buying refurbished one, you have more chances to have some part issues. I suggest to reinstall modem driver to see if it works, and try to clean cd rom driver and reseat it, and hope for the best. Let me know the status Thanks
Jun 16, 2011 | Dell Computers & Internet
I need my pc modem driver.. i miss my driver cd.. my system config is hp compac
I don't know which specific driver you are looking for .. but I'm assuming internal modem driver of 56K so here's the link
http://download.cnet.com/Compaq-Internal-56k-PCI-Modem-Driver/3000-2109_4-15523.html
If it doesn't work try this site. just enter the model no and it'll give the list of drivers for you to download choose the one you need.
http://www.driverguide.com/
hope this helps. :)
Jun 13, 2011 | Computers & Internet
Not working only power and dsl display is glowing continuously. BSNL personal informed that modem has to be repaired. It is the line probliem or modem problem.
It can be one of two things : A material defect or your modem or a configuration error (modem or PC). Since the DSL indicator is on, it is most likely the problem is not with the line. Except if you are getting the ADSL signal meant for somebody else.
Can you give more details about the modem you are using ? It might help to guide you in verifications to do.
In the meantime, try the following generic steps:
1. If your modem requires a driver:
  • Make sure you have the driver CD which came with the modem;
  • Then, go to the Control Panel, then "Add or remove programs" (or "Programs and functionality" depending on your windows version);
  • In there, search anything related to your modem (generally, it contains the brand or model of your modem) and unsintall of them;
  • Use the driver CD and reinstall the software for your modem and reconfigure it as per your ISP settings (call them if you don't know the settings)
2. If your modem requires a connection set up on the PC:
  • Go to Start -> Control Panel, then click on either (1) Network Connections or (2)Network and Internet Connections -> Network Connections (it depends on the View of the Control Panel);
  • From there, delete all dial up and/or broadband connections;
  • Then, still in Network Connections, click on Create a new connection, in the "Network Tasks" section on the left;
  • Reconfigure a new connection as per your ISP settings. Call their hotline if you have to, to get instructions on how to configure the new connection.
3. If your modem functions as a router:
  • It might have been reset to factory defaults and you may need to reconfigure it as per your ISP settings.
In all cases, do a hard reset of the modem before proceeding. Il will be as if you were installing it for the first time.
I hope this will come in handy. good luck with your modem.
May 11, 2011 | Computers & Internet
Missing soft modem driver
Select CONTROL PANEL
Select SYSTEM
Select DEVICE MANAGER
(This will show you all your computer's hardware and peripherals)
Locate your modem "MODEMS"
Not listed?-Defective or no power.
Listed? right click it, see if it is DISABLED
Then, right click it again, select PROPERTIES
(Yellow triangle indicates error)
First tab GENERAL shows if it is working properly.
Then click on DRIVER tab to see if you just need to update the driver, or roll back to a previous driver.
Third tab DIAGNOSTICS can help determine if it working properly or not.
Hope this helps
Mar 04, 2010 | Everex IMPACT GC2500 PC Desktop
Message: unble to find modem device
Hello!
I don´t know so much from you about this problem, but I think that is trouble with integrated modem.
First try in bios, see if modem disabled, just enable modem, and you only need drivers.
If modem enabled in bios, try to do new system.
If you have still trouble, modem is problem.
Nov 02, 2009 | Acer Aspire 4315-2490 Notebook
Modem problems have to reinstall it every so often cause if I don
you have a driver problem .
all computer parts have a driver system which helps to run .Depending on the health of your pc , which needs to be cleaned up on regular basis ( delete temp. memory , defrag ) drivers needs to be updated to keep them running . Upgrade your drivers and your problem will dissapear .
Sep 26, 2009 | Computers & Internet
Modem Casn't Get A dile tone
If you are sure your modem drivers are installed (no YELLOW QUESTION MARKS when you access the device manager), try this;
My Computer/Right Click/Properties/Left Click/click Hardware tab/click Device Manager Tab/click Modem/go to properties/click TEST MODEM---this procedure should tell you that the modem PASSED or FAILED.
If the modem FAILED, it is defective and will need to be replaced.
Apr 11, 2009 | HP Pavilion N5250 (F2362M) PC Notebook
Downloading of nokia 6265 modem driver
1. Nokia website and download the latest PC suite. this would give you the modem drivers for your phone. you don;t have to look for only modem drivers.
Hope this would help you....
Mar 28, 2009 | Nokia 6265i Cellular Phone
I need modem driver for conexant hsfi ck11252-11
Try this drivers:
http://www.conexant.com/support/files/HSFp_WinXP.zip
or
http://www.conexant.com/support/files/HSFac97_WinXP.zip
or
http://www.conexant.com/support/files/HSFhda_WinXP.zip
or
http://www.conexant.com/support/files/HCFp_WinXP.zip
or
http://www.conexant.com/support/files/HSP_UniDriverSoftware_Win2kXP.zip
Try each one. If doesn`t work, try to install using the Windows Update and Automatic installation.
I have a few modens like this one here. Sometimes it installs with above drivers, sometimes with Windows Update.
Note: Before trying Windows Update, try to install all the drivers listed first. After you tried install those drivers, go to Windows Update attempt. I don`t know why, but allways works for me. I Don`t know if is a incompatibility with motherboard`s chipset, but still, i can`t wait to sell all my modens like this one, and never buy it again for resell.
best regards.
Dimitri Toledo
Brazil
Feb 24, 2009 | Conexant CX11252-11 Modem
No driver for my modem
Try downloading the driver from the website below..its only 560kb and compatible with Win 2000 to Win XP
http://www.helpdrivers.com/ingles/listado/dow.asp?codigo=78972
May 22, 2008 | Trendware (TFM-PCIV92A) (TFMPCIV92A) Modem
Computers & Internet Logo
83 people viewed this question
Alun Cox
David Payne
David Payne
